Thermostat - Aube or Heatmiser?
7 Nov 2006
Stockton on Tees
I was wondering if anyone can help.
The house that i have bought has underfloor heating in the lounge. It is controlled by an Aube TH132-F thermostat (which is now discontinued and replaced by the TH232-F).
I don't like the look of the Aube and would rather have a much nicer looking Heatmiser neoStat thermostat.
Im not sure if they they both use the same floor sensor....cant find any info online.
Can anyone tell me if this would be a straight swap?
I don't really want to be ripping out the wooden flooring to lay a new sensor.
Just use the temp sensor built into the thermostat that detects the room temp and not worry about if the floor sensor works?
