Thermostatic radiator - head valve question
18 Oct 2002
Hi - I have a question relating to radiator valves
Some of the Thermostatic radiator heads in our house have started to break and I bought some replacements. However, it seems our radiators have smaller pins and the head controller pins are longer than the new replacements.
Does anyone know where I can get the head valves with the longer pins please?
See photo below for the new valves (left) Vs the current (old) valves (right) - the pins on the older valves are much longer, so reach the smaller pins on the radiators. The new valves don't reach
These are the radiator pins
you are sure pin on new one will not descend when external temperature and head rotation should dictate it engages
e: was looking at a few of mine this morning thinking I should clean dust and 'muck' out so they read temperature correctly.
It's a nightmare, based on my Hive smart TRV experience there are about 6 different standards. 5 quite common, the 6th meant an order to Hive HQ. I have a bunch I'll double check in the garage for you later.
Does the 'muck' really cause problems with reading the temperature? Most of ours are covered in paint from the previous owner. :rolleyes:
there is some dust inside the metal vaned head of the one in the bathroom and if that is stopping airflow getting to the bimetallic(?) strip I though it may take longer to respond
(I have never taken one apart)
