Right firstly what i'm cooling
I5 2500k at 4.5GHz with 1.36v on load (might be able to further tweak this but not by much)
Then the loop
EK-Supremacy - CPU Waterblock - Nickel Acetal
EK DCP 4.0 Pump (12v) + res combo
XSPC EX120 120mm Radiator
XSPC EX240 Crossflow Radiator
3 Scythe 1850s at full speed
Pump is running off a fan header and runs at 1290rpm instead of 1930rpm but this is adjusted with temps, so higher the temp the quicker the pump runs.
Temps on full load (LinX) after a few mins average low 60s (61, 64, 62, 58)
Does that seem normal for the CPU used and the voltages?
I want to add the 670 to my loop in the future and want to make sure everything looks fairly normal before I do. I know the pump isn't the greatest but for the price i'm happy with it.
I run the pump slower to keep the vibrations and noise down, is it better to run it full speed or does it not make much difference?
Due to case size I can't really alter the radiator sizes as I don't want to start cutting stuff up. I could fit a top 140mm radiator to help but from what i've read it doesn't appear to be worth it. I choose the crossover radiator on front (intake) purely because it means the tubing is neater for me, the 120mm radiator is on the rear as an extrator. Is it better having this as an intake too and leaving the top 140mm as the sole extractor?
Then the loop
