Thicker or Thinner Radiator.
3 Jun 2005
Bristol/Portsmouth, England
Hi im about to purchase a watercooling kit at the end of the week and i am wondering what radiator is best to go for.
Both have the same basic dimensions but one is 250mm thick and the other is 400mm thick.
Im thinking the 400mm thick one would be better for cooling, and is about half the price of the thinner one.
Any help would be very greatful.
Cheers
What radiator's are you looking at?
It's not so much the thickness but the density that matters. The more dense the rad the deeper fan you need.
the 2 radiators im looking at are the:
Alphacool NexXxoS Xtreme II
and the
Asetek DYO DUAL Radiator RDT02 120 mm [1/2" Fittings]
I wouldn't bother with the Waterchill.
The best rad's are:Thermochill then Swiftech
I have no experience of the Alphacool rads but I guess they are pretty good.
