Thief :Deadly Shadows.
Caporegime
8 Nov 2008
Hi,
I appear to be running into compatability issues with this one. I'll be playing quite happily and then the screen locks up, also get a sound loop. After a few seconds it seems to sort itself out until fifteen minutes later when it repeats it again. When I've gone back to desktop there is a vpu recover message. I've tried disabling cat a.i. but it doesn't help. If there's someone who knows of a fix or a patch that would be much appreciated. I did reinstall 9.4 simply because I've had a very minor issue with the 9.5 on something else, but evidently it hasn't helped.
Hi,
I maybe able to help as I had issues running this last week in XP home, may also work in Vista but I never tried.
Firstly there is a patch for the game v1.1 link below
http://browse.files.filefront.com/Thief+Deadly+Shadows+Official+Patches/;1319051;/browsefiles.html
I also had issues with running the game till I ran it with the affinity set to one core. But I found I couldn't alt-tab out of the game as it always quickly switched from task manager back to the game. I found I had to set the affinity after clicking the game icon but fast so I could set the affinity before the game fully loaded.
I also think I disable the audio hardware as I though that may have been the issue and I can't remember if I turned it back on after doing the affinity thing.
Hope that helps. Also some links below that maybe of interest or of use to you.
Texture Pack (Fully recommend you get this).
http://www.strategyinformer.com/pc/thiefdeadlyshadows/mod/23515.html
Guide &Walk-through (In case you get frustratingly stuck)
http://http://uk.faqs.ign.com/articles/520/520923p1.html
Here's a link to TweakGuide's article for Thief 3, that may help you configure the game further.
http://www.tweakguides.com/TDS_4.html
Thanks warnea1984, cheers for the help. Will give it another go and see if it runs smoother. :D
*Have now installed and begun playing again. Looks quite a bit better so thanks for the link. Did you get the sky flashing different shades of blue (this was before and after I used your link). Anyway it hasn't given me any other problems yet so fingers crossed :)
