Thin 360 in Pull to Thick 360 in Push Pull
30 Dec 2013
GPS signal not found. (11)
Due to some re arranging I can now fit a much thicker rad in my case.
Was looking at the lower FPI rads, like alphacool nexxxos, Coolgate and EK XTX so I can lower fan speeds.
Will this actually make any difference?
Temp wise:
Given the same fan config, it should, however small the difference would be :p
Noise wise:
You already know the answer right :cool:
Don't go crazy on 80mm thick rad.
So what you are saying is don't get the alphacool monsta? :cool:
Probably get the Alphacool UT60 as I love my current alphacool rads. Unless something happens to pop up cheap on the MM.
