thin Bezel monitors?
22 Oct 2006
Setting up a video wall at work.
4x 24/23" screens.
in a 2x2 config.
What i'm after are some screens with as thin as possible bezels, the Dell monitors are about 17mm. and because of there full square share are looking best.
anything wiht a round bottom is out as it needs to be flat.
Any ideas?
Cheers
Samsung Syncmaster MD230 is aimed at video wall usage with a <10mm bezel
[edit]
Oh yeah, important detail.. whatever you get in the end, stay away from TN panels. Sure they're cheap, but with a videowall you're going to have different viewing angles and TN-panels don't look too great from a slight angle.
The samsung uses a PVA panel
Nice extra of this particular monitor is that you can daisy chain the power cable, only need one wall outlet.
