Thin edged monitors
12 Sep 2005
Grundisburgh
I'm looking for some thin edged monitors to set up a three way display. I would prefer 24", 1920*1080 and LED if possible.
Andi.
Some samsung 24" have their power pack like a laptop brick instead of inside the casing might be worth looking at those.
I'd decide on a budget and just get the best screens for that budget though instead of basing it on how thin.
Things move so fast in the monitor world not sure the samsung BX2440 and BX2450 are even good value any more.
Thanks guys I tend not to set a budget until I've found the ultimate answer then see if I can get a lower price.
The LG looks good, I'll investigate.
Andi.
heres a pic if it helps, the outer monitors can be placed behind the cener monitor for thiner bezels but i found it looked a bit messy, the bezels are 15mm if thats any help
Thanks for that, can't make up my mind now. LG seems to have a dodgy pixel history, I've always liked the Samsung range. If OCUK did a pixel check service might sway my mind.
Andi.
i bought all 3 from ocuk and no dead or stuck pixels, ive used samsung in the past and they are good monitors but i found ive always had to mess about with callibrating them to get them to my liking
