Does anyone know of any brands that make 120mm fans thinner than the standard 25mm?? preferable about 20mm thick. I seem to recall a few companies making 18mm thick ones at one time??
Cheers
Edited for being n00b-like
Cheers
i have a OrigenAE H7 htpc case and as said above a thermalright si-128. basically a normal 25mm deep fan is literally a few mm too thick to get the lid on the case properly but could do with a bit of airflow over the heatsink so something that is about 20mm thick or less should fit nicely
