Hi folks,
Been away on holiday and came back yesterday. Switched on PC and everything was as per normal for the first 10 minutes or so. Then this thin purple vertical line appeared as shown below.
I switched off the PC and restarted it but it is still there. It shows up during the POST of the system and also in the BIOS screen. I'm guessing therefore that it is not a GPU issue but a problem with the 19" WS Octigen LCD I have?.
Is there any way to fix this?. Really strange as everything was working fine before I went on holiday and this is the first time I have seen the problem. Only thing I did differently was install a couple of Vista updates this morning but none of the updates as far as I can recall were anything related to visuals or display.
