- 19 Jan 2005
- Oxford/Bristol
I've been happily crunching on a Q6600 for around two years now but the other day it started turning itself off.
Looks like the problem was due to dust buildup in the HSF but unfortunately after cleaning it out I didn't reseat it properly and the PC powered off 3 seconds after power on.
Anyway after fitting it properly, now It won't even go into the BIOS and I get no beeps during startup.
So assuming I've killed it I need a new CPu and possibly mobo.
Having a hunt around it looks like the newer chips are mostly dual core with hiper threading to emulate 4 cores. Does this hurt performance at all compared to a true quad core?
I was eyeing up an i3 or i5 dual core and motherboard for around £150 as a potential replacement /upgrade. Is that a wothwhile improvement? Presume these chips are all 64bit?
Or am I better off looking for second hand Q6600 and skt775 board which seems to be around the same cost?
