I have done some reading around on the forum, and thinking i may try my first over clock.
My main worry is if something breaks. Its all new gear
I am looking for some advice if possible and what more experienced people think i should do.
All i do with this PC is WoW and basic browsing.
The spec is as follows
MB: Gigabyte - GA-MA790FXT-UD5P
CPU: AMD Phenom(tm) II X4 970 Processor (Black Edition) 3.5
Ram: Corsair DDR3 XMS Ram. 4gb
Graphics: Gigabyte HD5770 (OC version)
PSU: 900w Evo Labs (fan faces outwards)
Case: Xigmatek Utgard Midi Tower Case (3 Fans)
After market CPU Cooler thermaltake ISGC-300
CPU Temps
Idle sits at 30 max (depends if heating is on) but right now, heating on and sitting at 29 degrees C
Under load 43 degrees (again heating is on in the house)
Got the following off Easytune 6.
CPU 3527mhz
BUS 2016mhz
FSB 201mhz
Multiplier 17.50
Voltage 1.35v
I have never done an over clock before, and i am not 100% it needs it. I run wow on ultra, without any problems. But i am the kind of person that always wants more!
Any advice would be appreciated, Would it be worth over clocking? Should i just forget the idea. If i should, Any advice is much appreciated
CPU Temps
CPU 3527mhz
BUS 2016mhz
FSB 201mhz
Multiplier 17.50
Voltage 1.35v
