- 18 Oct 2005
- Swansea
first things first my setup
AMD Opty 146 @ 3ghz; 1.55v
idle - 36c
load - 45c
DFI LanParty NF4 SLI-DR
Crucial 2GB (2x1GB) DDR PC4000 Ballistix Dual Channel Kit
ATI Radeon X1800 XT 512MB
2x 160gb HDD in RAID-0
Enermax Liberty 620W
CoolerMaster Stacker RC-810
Thermalright xp120
Iv been toying with the idear to go with watercooling for some time know so i thought id get some info b4 i take the dive.
first question would watercooling enable me to clock my opty anymore?
how much is this going to cost me to get a good WC setup?
i have a CM stacker case with 5x120mm fans in i take it that that will be adequte air flow for WC
is it worth cooling the northbrige chip with water or is the stock HSF good enough?
what make of watercooling hardware should i be looking at? iv read that danger den and swiftech are good makes?
thanks for the help if u need any info off me just ask
idle - 36c
load - 45c
Thermalright xp120
