Ok, I have a MBP with an SSD at the moment for normal stuff but I was thinking of a Mini for multiple use:
a) Plex media centre with direct attached drive for storage.
b) NAS box - easy to add storage. I already have a load of drives that I can add in USB caddies.
c) My own OSX based MIDI drum application where it will be sat next to my drum kit with a monitor, FW MIDI interface and drive my existing monitor placed so I can drum from the display.
This means it's get a lot of vibration hence my thought about putting an SSD onboard instead and running all the media etc via an external unit.
It may also be downgraded to run Leopard so I can test with 10.5 and 10.6 on my MBP then upgraded next year using the SL that came with it. I want to sell this app, although at a lowish price, so I need the ability to support 10.5 for a while.
The switch between Plex/NAS and (c) would be just shutdown, unplug & move then restart. I'll have separate user accounts or split the local drive into a 10.5 and 10.6 disc and select on startup.
So I assume it's straight forward to replace the internal mini drive? Has anyone tried an SSD in a Mini?
