I have a thermal take core v71 case which can apparently take up to a 420mm rad up top if necessary.
I currently have a noctua dh15 but I'm not overclocking cpu at all so I'm thinking of just going with an AIO, but I'd like the best performing AIO that is equal or better than the noctua to give a little headroom should I change my mind about overclocking or so and overdrive can make the most out of the feature. I can also only use one fan on the noctua because of ram clearance which bums me out a little.
So naturally I'm looking at rads with 3 fans for performance reasons, but I know that fans, pumps, reliability and rad thickness come into it as well.
Any recommendations on products to look at would be greatly received. I'm not averse to changing out some fans if the pump and rad are decent. But last time I had an AIO cooler, a cheapish aftermarket cooler outperformed it by quite a margin so I'm a little dubious of going AIO water-cooling but I do realise times have moved on.
I used to run an i7 980x with a coolit eco ALC 240? I think. I won an alpenfohn brocken to review it was loads better than the swiftech with my i7.
Thanks in advance
Thanks in advance
