Thinking of going SLI
I am thinking the same but going crossfire and i have a 5850 and i am tempted by another at the current price
1680x1050. depends what im doing on the other monitor tho
samsung t220 22" and BenQ G2220HD LCD TFT 21.5
Also, what psu do you currently have?
For me the pros and cons are, higher frame rates and the ability to use higher levels of aa/af, cons, increased power usage and temps, though the latter can be easily sorted with decent case cooling.
You'd get a decent price for your 460 if you sold it. Add that to the cost of another one and you won't be that far off an equivalent one card solution. Plus you get less heat and power drain. Plus sli can take a bit more messing around to get working well.
