Thinking of improving my build...
22 Nov 2010
Current Specs
Case: Cooler Master HAF X
Mobo: Asus Crosshair IV Formula
Processor: AMD Phenom II X6 1090T Black Edition 3.2GHz
RAM: OCZ Reaper 8GB 1600MHz DDR3 Dual Channel (2 x 4 GB)
Graphics card: HIS iCooler Radeon HD 5870 1GB GDDR5
SSD: Corsair 40GB SATA II SSD (for operating system ONLY)
Hard Drive: Western Digital 2TB SATA II 7200rpm Black Edition
Optical: Samsung 12x BD ROM/ DVD+/- RW drive
PSU: Cooler Master Silent Pro 850W Power Supply
What I'm getting next
For two way crossfire (for now): Asus Radeon HD 5870 1GB GDDR5
Cooling: Swiftech H20-220 Apex Ultima XT Plus
HELP
I need some help with overclocking...I understand it (kind of) but whenever I overclock something the system crashes (apart from the GPU: I overclocked it to 1000MHz but when I started playing a game it crashed - probably something to do with the fact that on idle the GPU core clock is 150MHz but is ran to it's full capable 900MHz when playing on a game.
There's a guide on overclocking in the Overclocking and Cooling sub-forum.
Its easy to follow and tells you all you need to know :)
http://forums.overclockers.co.uk/showthread.php?t=17612922
Also, that is one kick-ass PC
Thanks.
By the way, used Asus Turbo program to automatically OC the system but it couldnt get it past 203MHz. Then I tried changing it in the BIOS manually and I get a "Overclocking failed" after POST when I restart.
Thanks.
Might be you need to up the voltages a bit :)
