Thinking of new project!
2 Jan 2009
Hi im thinking of a new project, will i fit a quad in the bottom and a triple tfc rad in the top on a silverstone TJ07 case? cheers in advance has anyone got some pics of this?
With minimal modding (hardly any infact).
Feser 120.3 in the bottom, Black Ice 120.2 in the top.
You can fit a triple to the roof but it would need modding. It's not the length that will cause you too many problems, it's the thickness of the rads. You can also squeeze two rads in the bottom if you wanted.
Yea, you can get the roof modded easily to accept a triple rad, it already accepts a double so its just a case of extending the current hole.
Like Webbo said, they'll fit fine length wise, but your pretty much limited to using a Black Ice rad as pretty much any other will be to thick and get in the way of the mobo. Think XSPC rads may fit as well but will be getting tight!
