Due to the horrible hard drive bays vibrating in my mirage 62, I have moved a couple of hard drives (the noisest ones) to the 5.25" bays using convertors. however with 5 hard drives in my PC its considerably increased my CPU temperature - even with installing an extra side fan (my case has 3 intakes, and 2 exausts - note that 2 of the intakes have hard drives infront of them).
I was wondering due to the hard drive bay in the antec p182 being isolated at the bottom of the case with the PSU and holding 4 hard drives, would this help my temperature problem as I would only have 1 (and eventually 2) hard drives in the main section of the case.
Another reason I am thinking of this case is because it has rubber grommets for hard drive mounting (just like my antec solo case for my old PC) and I like this idea as it seems to help reduce vibration to the case.
What are your views on the P182? The case costs about £90 which is a lot (I paid £105 for my Mirage DOH), so obviously I dont want to spend any more than the P182 - regarding my requirements for cooling (without lots of noise), and rubber mounted hard drives, what else is there on offer for the same price if anything?
