- 3 May 2014
Hey. I'm not exactly well up in all this and before I go and purchase a graphics card, I'll rather know if I can use it without having to upgrade anything else in my Computer to do so. The computer was a build I purchased off Overclockers themselves, AMD Raid X4 (no longer available).
It was kind of a rush build, I didn't have the money for a decent graphics card with it so figured I'll upgrade that part eventually.
Here is my current specs;
8GB RAM
GeForce GT620 2GB (part I'm wanting to upgrade)
AMD Athlon II X4 Quad Core 3.00GHz
Corsair Builder Series CX 430W V2
Gigabyte GA-78LMT-S2P 760G (Socket AM3+) DDR3 Micro ATX
BitFenix Merc Alpha Case (this is just so you can tell what kind of graphics card can fit in there)
I'm thinking of this graphics card as it is right in my budget. It'll be nice to know if I can use this. I mainly want to stick to Nvidia graphics cards so please don't give me AMD suggestions.
I'm not sure if this PC has a PCI-E connecter (the graphics card I have selected before doesn't require this according to the description).. I did look around for one but I believe Overclockers have stuffed a good few of the wires in the back.
Sorry if I sounded like a complete noob but I rather check before purchasing so thanks for any help in advance
And I'll need it with something that has a DVI output as I do eventually want to get ASUS 29" screen, which requires that output.
Another piece of information I forgot to mention, I mainly use consoles for gaming with. At the moment I play mainly Guild Wars 2, other free MMO, but do eventually want to play FFXIV on this as well.
8GB RAM
