Thinking of upgrade, Advice pls.
25 Mar 2010
Hello hoping i could get some advice on upgrading my PC.
I'm looking to get back into PC gaming and hoping a new graphics card and more ram will do it.
Is my processor up to it?
Intel(R) Core(TM) i5-2500K CPU @ 3.30Ghz
Motherboard MSI MS-7681
Will this with a decent graphics card and 8-16 gig or ram be any good?
or will i really have to start from scratch?
Thanks for any advice.
It should be ok for a 290. Will also run a 780 or the newer 970 (the latter more easily, and would be what I'd go for if budget allows).
Here are two options.
The GTX 970 and the GTX 780. The 970 is better performance with newer software ect.. but the 780 is a stunning price and will be great value for money, it isn't too far behind the 970.
YOUR BASKET
1 x GALAX GeForce GTX 970 OC 4096MB GDDR5 PCI-Express Graphics Card (97NQH6DNB4UX) £269.99
1 x KFA2 GeForce GTX 780 3072MB PCI-Express Graphics Card - OEM (78XNH5DN9IST) £199.99
1 x TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (TLRED38G2133HC11ADC01) £65.99
Total : £545.57 (includes shipping : £8.00).
Thanks both for the advice.
would you say the 970 is worth the extra money over the 780?
and is the 970 linked the best one to buy if you were to spend up to about £300?
I take it the ram linked there is the best bang for the buck also?
Thanks again.
