Thinking of upgrading my monitor
9 Jul 2012
Nottingham
Hi, so christmas is around the corner, and i'm thinking of buying 3x monitors as I am wanting to play dragon age:I in eyeinfity. Could anyone recommend a monitor please. i'm thinking of spending £200-300 each and would prefer it to be above 1080p and high refresh rame if possible and my current monitors(only have two:( is Asus VE247 if that helps)
MY system spec ( if needed)
i5 [email protected], Gigabyte ATi Radeon HD 7950 Windforce, corsair vengeance 8GB, Corsair 600T, Pc power&cooling 600W, p8z68 mobo
Thanks guys and merry almost xmas:P
I think you want a monitor that doesn't exist!
At least if there is a 24" screen with >60Hz refresh and a higher resolution than 1080p I've never heard of it.
24" 1080p 144Hz gives you a range of choices, though. You're not likely to be interested in g-sync as you have an Nvidia card, but Freesync monitors are coming soon(ish) if you want hold fire for a few weeks (possibly until the new year, I'm not sure if it's all completely clear yet) and there might be some more competition in the gaming monitor world then.
Like the dude above says your options are limited, generally most 24s will be hd. However you mention eyefinity and the game you mentioned in eyefinity with slim bezels would look fab!
Benq have some nice slim bezeled ones, so do dell.
If you can wait though dell are planning on releasing the u2515h which is wqhd as you were looking for, and thin bezels for eyefinity. However no fast refresh rate.
I think you will have to pick what's most important in a monitor for you.
Handy thread - I've just upgraded GPU and want a more immersive experience, but it's looking like the newer ultra widescreen monitors might be a better bet than eyefinity?! I work all day with 3 screens and bezels annoy me!
Yeah the ultra widescreens look pretty fab! i dont think you would get quite as much fov as with eyefinity, but imo the trade off is worth it for bezel-less immersion! /melts
