- 4 Jun 2010
current rig in sig in cm storm scout the whole rig is around a month old, I would LOVE a 700d and have a £200 spend limit inc p&p so case would be £159.21 and i would buy a cable braiding kit from a competitor for £48 so a total of £207.21 but I have a few questions
1) Would my PSU reach though the cable management and onto the board mobo is aus p7p55d-e full ATX PSU is: ocz modXstream pro 600w
2) Is it worth the upgrade? I will be using air but pretty sure i will water cool in the future after I have figured out how to set up a watercooled rig (i cant understand the loop ie rad-pump-cpu-gpu-pump etc..)
3) Would it be just the case of putting psu in case, feeding cables though holes, then placing mobo in, screw down, the plug in?
thats all!
thanks for your help greatly appreciated!
thats all!
