Thinking Of Upgrading?
2 Oct 2007
Uttoxeter,Uk
At The Moment I Got
Os:Window Vista 32
Cpu: AMD Athlon 64 X2 5200+ 2.6GHz Socket AM2
MotherBoard: MSI K9N SLI-2F, nForce 570 SLI, DDR2,
Socket-AM2, 2xGbLAN, ATX, 2xPCI-Ex16
Cpu Cooler: Thermalright Ultra-120 Extreme With Scythe S-FLEX 1200RPM Ultra Quiet 120mm Fan
Psu: Ocz 700Watts
Ram: Corsair 2GB DDR2 XMS2-6400C4 TwinX
HardDrive: Western Digital Caviar SE16 400GB SATA2
VideoCard: Msi 8800 GTS OC
Screen:Samsung 22" LCD Syncmaster 226BW
KeyBoard,Mouse And Speaker
Here What I Was Thinking Of Having
OS:Windows Vista 64
Cpu:Intel Core 2 Quad Pro Q6600
Ram: Another Corsair 2GB DDR2 XMS2-6400C4 TwinX To Make 4GB
MotherBoard: I Dont What I Should Get Yet.So U Decide PLZ
I Have Been AMD All My Life,So I Dont No What Spect From Intel Core 2 Quad Pro Q6600,Is There Any Pro And Con Or Not.
Am Happy With Rest Stuff I got.So What Do U Think Of It Or Shall Stay What I Got At Moment?
As above, what are you finding slow?
We can't tell you if it is a decent upgrade without knowing what is needed.
It'd also help if you use standard english, unnecessary and hard to read when you capitalise every word.
Just kinder want a new toy to play with really,will i feel the different between AMD Athlon 64 X2 5200 and Intel Core 2 Quad Pro Q6600.
But if think it really not worth upgrading yet and save money untill something come out,just say it. thanks
If the applications you use aren't coded to take advantage of multiple cores or you don't have at least 3 different programs running at any given time you probably won't notice a huge difference. I'd be inclined to suggest overclocking if all you want is for it to be a bit faster.
