Thinking of wall mounting my screen?
All mnaufacturers usually have a standard 100mm VESA wall mount bracket connector on the back of the screen which the stand is fixed to , you simply remove the stand the connect to the bracker
Only plasma's very heavy screens require VERY heavy duty wall mount fixings
Of wall mounts? They all follow the same standards so it's just up to personal preference. Just like digi cables, a cheap one will do the same job as an expensive one.
