- 28 Oct 2018
Hello,
I have a Lenovo Thinkpad L512 where the integrated webcam had a fault that was causing a BSOD. Neither updating the driver or disabling the camera helped so I decided to disconnect the camera. As I was doing that the internal display fell forwards and the cable was pulled out the back of the screen. I reconnected it but the internal display would then not work. So far I have tried the following:
- replaced the screen cable (as I thought the connector must have been damaged when it was pulled out)
- replaced the screen (same reason as above)
- reset the BIOS to defaults including making sure that Thinkpad LCD is set as the boot display
- updated the BIOS
- updated the video driver
- confirmed that the lid close switch is working (the laptop goes into sleep mode when the lid is closed)
- Fn + F7 seems to work in terms of switching the video output but nothing displays on internal screen
- internal screen is off completely, not just very dim
Any ideas about what the problem might be and what else I can try?
Thanks in advance
Guy
- updated the BIOS
Thanks in advance
Guy
