Third Monitor?
JR1
JR1
5 Feb 2008
West Sussex, England
I've got a 9800 GX2 sitting in the first PCI Express slot of an Intel D975XBX2 motherboard, which supports 2 monitors when running in multi-display mode. I'd like to run a third monitor. I have an 8600 GT, which also has the ability to run two monitors.
Can I add the 8600GT and use it to run two monitors, leaving the 9800GX2 to focus on one monitor (perhaps running in multi-GPU mode).
At the moment when I try put the 8600GT in the second slot the PC fails to boot at all. I wonder if there is a BIOS setting I need to get right.
If I can get it to boot I'm wondering if the use of two drivers will be reconciled correctly.
Any advice would be warmly welcomed.
It should be as simple as plug the card in, install the driver and you're away. What OS are you on though first?
