This cooler
specs as follows
Specification:
Reserator (Reservoir+Radiator+Water Pump)
1. High Performance Ultra Quiet Water Cooling System
2. Active/Passive Hybrid Cooling Design
- Active Cooling: 140mm Fan (Forced Convection Cooling)
- Passive Cooling: Anodized Aluminum Heatsink Chassis (Natural Convection Cooling)
3. Automatic/Manual Control Modes
- Automatic Mode: Coolant Temperature is monitored for Automatic
Control of Fan Speed and Coolant Flow Rate.
- Manual Mode: Front Panel Control Knob allows the user to manually optimize
performance and minimize noise
4. Warning & Alarm System
- Coolant Flow Monitoring: Warns the user when coolant flow is problematic.
- Coolant Level Monitoring: Warns the user when the coolant level is low.
5. Comprehensive Visual Monitoring Display
- Coolant Temperature (viewable in °C or °F)
- Ambient Temperature (viewable in °C or °F)
- Coolant Level Warning Icon (Lights Up When Coolant Level Is Low)
6. Coolant Flow Rate
- Coolant Flow Indicator
- Light Switch
7. Automatic Power ON/OFF In Sync with the Computer
8. Quick Couplings for Fast, Convenient, and Leak-Free Installation &
Maintenance
- Weight : 7kg
- Dimensions : 350(L) x 210(W) x 180(H) mm
- Materials : Anodized Pure Aluminum
- Maximum Coolant Capacity : Max. 1.25ℓ
- Integrated Water Pump : 6W, DC 12V, 300L/Hr
- Maximum Lift : 1.8m
- Color Options
I believe the hose comes with the kit
review http://www.virtual-hideout.net/reviews/Zalman_Reserator_XT/index.shtml
http://xbitlabs.com/articles/coolers/display/zalman-reserator-xt.html
