17 Jul 2011 at 20:27 #1 rogueblade rogueblade Associate Joined 12 Oct 2010 Posts 2,319 Location Stratford, London Trying to get my rig in my sig.....might be a bit long edit: nope, that didn't work....
17 Jul 2011 at 20:29 #2 rogueblade rogueblade Associate OP Joined 12 Oct 2010 Posts 2,319 Location Stratford, London How do you guys get your rig to fit in your sig around here
17 Jul 2011 at 20:31 #3 Jony27 Jony27 Soldato Joined 15 Aug 2010 Posts 8,897 Location N. Ireland reduce the font size theres a sub-forum where you can post/test your sig http://forums.overclockers.co.uk/forumdisplay.php?f=37
17 Jul 2011 at 20:31 #4 FARGO FARGO Associate Joined 5 Aug 2010 Posts 1,990 Hey there, just so you know there is a forum to test out sigs and other things here: http://forums.overclockers.co.uk/forumdisplay.php?f=37 As you can tell by my post, I've not fiddled with sigs so I can't help you, sorry!
17 Jul 2011 at 20:31 #5 RJC RJC Don Joined 29 May 2005 Posts 29,094 Location Kent Use the smallest font and the then use commas instead of space bar and only single return.
17 Jul 2011 at 20:36 #6 rogueblade rogueblade Associate OP Joined 12 Oct 2010 Posts 2,319 Location Stratford, London aha almost! Thanks for the tips and link
17 Jul 2011 at 20:48 #7 RJC RJC Don Joined 29 May 2005 Posts 29,094 Location Kent Your sig is too big, max 4 lines of text, you need todo what I have done in my sig.
17 Jul 2011 at 21:04 #8 rogueblade rogueblade Associate OP Joined 12 Oct 2010 Posts 2,319 Location Stratford, London got it. thanks
17 Jul 2011 at 21:08 #9 EniGmA1981 EniGmA1981 Soldato Joined 14 Sep 2010 Posts 2,910 Location Port Talbot - Wales [delete me]
