This isnt right, is it?
Permabanned
26 Jan 2009
Installed my E8400 and loaded Windows 7 (untill Vista arives).
Ran CPU-Z and my clock speed was at 2000Mhz...is that right or?
Used Biostars V8 OC setting in bios, its now at 2100Mhz...
First question, is it a borked chip?
Second is it 'cos its idle?
KbW
It'll be because it's idle. Speedstep is on :)
Open SuperPI (or anything remotely demanding) and CPU-Z and see if the CPU clock increases with the CPU usage.
It'll really create some heat. If you haven't got sufficient cooling, it'll show when you use this test.
I get an extra 10-15 degrees core temp on an E8400 with IBT compared to orthos beta.
What are you using to monitor temps?
