This ok for Core 2 Duo compatibility?
28 Dec 2004
Derry
CP-135-IN Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM (CP-135-IN)
£97.99 £97.99
MY-013-GS G.Skill 2GB DDR2 HZ PC2-6400 (2x1GB) CAS4 Dual Channel Kit (F2-6400PHU2-2GBHZ) (MY-013-GS)
£174.99 £174.99
MB-152-AS Asus P5W DH Deluxe WiFi (Socket 775) PCI-Express DDR2 Motherboard (MB-152-AS)
£134.99 £134.99
Aiming to buy it all tomorrow, is the ram ok with this board?
If you get the DS3, don't get the G.Skill because it won't boot..
There is a thread with a list of compatible RAM for the S-Series but I don't seem to be able to find it.
See, this is why I'm getting a bit worried. :(
What is regarded as the most compatible/clockable motherboard/memory combination for the 6300?
Thanks for that, BIOS flashes shouldn't be a problem, I have some crucial DDR2 and a Celeron in a spare machine I could probably use if it doesn't boot.
harris1986 said:
my 6400 and p5b deluxe is running does 3.4ghz windows on stock volts lol, and 3.2ghz orthos stable on stock! my geil 667mhz overclocks to 850mhz - http://valid.x86-secret.com/show_oc.php?id=129920
I think I'll probably go for the P5B you've recommended, along with some of this: GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) (MY-058-GL)
Just need to find a Tuniq tower now :(
