This ok? - Temps
12 Jun 2005
Hi there,
Just running an orthos test as i don't think my CPU is stable anymore.
Just wanted to check the temperatures:
Code:
Temp1: 58
Temp 2 : 69
Temp 3: 52
Temp: 2
HDO: 35
Temp 1: 59
Core: 70 (this seems to jump from 59 to 70 in one hop and then back again shortly after)
Are those temperatures ok?
Thanks.
I have set the Vcore to 1.475V in bios but from speedfan the cores appear at *** voltages as follows
Vcore1: 1.42v
Vcore2: 1.26v
Should they be at different voltages
Is there a program that will give me more accurate readings?
