This score okay, for 3DM06
Permabanned
31 Dec 2006
Xbox 360
I know, another one of these threads, but i'm curious.
I ran 3DMark 06 and I got 5440.
My Specs:
  • AMD64 X2 Dual Core 3800+ @ Stock
  • ASUS A8N-E
  • ATi X1900XT @ Stock - Running 6.12 CCC
  • 2GB Dual Channel Mushkin Memory
Thanks
That looks good to me - especially with everything at stock! :)
I get 8278 with my gpu in sig overclocked and my cpu @ 2.5ghz 1:1 with the ram.
Sure an XT owner will be round any time to confirm for you! :D
gt
Edit: Looking on futuremark they do look good. Lots of XTX's are scoring between 5200 and 5500 or so! :)
Not bad i get about 6690 in 3D mark with the rig in my sig :). Also considering my GFX card shows up as a generic card :(.
I get this in '06
That's with a HIS 256MB x1950 pro. No idea if the 1900xt is supposed to bench higher or lower though.
I got about 4900 (ish, cant remember exactly) with an x1900XT overclocked a bit (25 mhz on core & mem), but my proccessor sucks pretty badly so I crashed and burned at the CPU test (Athlon 64 4000+ 939 @ 2.4GHz).
Good score all at stock. I'm sure you could easily make 6k with a slight o/c on the graphics card and processor. ;)
Check out the 3800+ X2 Overclocking thread in the CPU section
My Specs:
  • ASUS A8N-E
Thanks
thats over 300points more than what i score.
