It should take a laptop drive, but you may need an adaptor. In saying that most ITX cases support laptop drives anyway since it helps save space. Check on the manufacturers website.
the laptop drive screws directly to the bottom of the case, but as you want it as cheap as possible and are not fitting a gfx card you would be cheaper putting in a 3.5 hard drive and get a faster drive and more storage to boot.
