this temp hot hot
i would say my room is average lol. its been a hot day and i did the test when i posted it.
my vcore is 1.45 accoridng to cpu-z but im pretty sure its 1.49 or something in bios. the fans are pretty **** but they do the job got 2 in a push-pull set up they are akasa cost me like £10 on ****** ages ago
The temps arent too bad, ibt tends to push temps a bit more than prime95, more powerful fans will help a bit, also as you say, try lowering the volts a bit.
