This tv tuner card
2 Feb 2015
NW
** No competitors **
has an RF loop out.
Does the PC need to be powered up for it to work? Would it work when the computer is asleep?
I want to connect my rooftop aerial to this card and loop out to the tv.
So if I wanted to watch tv using the tuner in the tv, the PC needs to be turned on. Sleep isn't good enough?
from a google search said:
One problem though is that although the card has an aerial pass through for a TV it seemingly doesn't pass the signal through whilst off/in standby. You may need to use an aerial splitter or something to overcome this.
The Loop out is for an additional card, not to a TV.
Buy a passive or amplified splitter and have one going to your card and the other to your TV.
