This Week Only 29/02/2012 - Special offers on a big range of products
22 Aug 2010
We have just launched our latest This Week Only deals which will be running until 7th March 2012. Some great products if you are looking to upgrade!
OcUK Tech Lab Silent PC Case - Cooler Master CM690-II Advanced Case - Black @ £116.39 inc VAT
nonl2brAt OcUK we strive for the perfect computer. <br>
<br>
The main issues with high end computers, both overclocked and none-overclocked are heat and noise. Noise can ruin any gaming session but the search for silence often leads to higher temperatures. The OcUK Tech Lab range of silent cases are assembled by expert technicians and pre-installed with state of the art, music industry grade noise dampening. Each case in the range is specially chosen for cooling performance and style. Whatever your tastes; brushed aluminium monoliths or rugged gamer cases, our range will offer something for everyone.<br>
You really can have the best of both worlds, exceptional cooling performance and whisper quiet noise output are now a very real option.<br>
<br>
The CM 690 II Advanced raises the bar again with practical improvements over the top-selling CM 690. The spacious mid-tower will keep enthusiasts happy with room for up to 3 vga cards, high-end CPU coolers, top or bottom mount water cooling radiator and 1.8"/2.5" drive adapter. It also features much improved airflow with oversized mesh and enough space for up to 10 fans. Maintenance will be a breeze with the tool-free drive bays, new cable management and CPU cooler retention hole.<br>
<br>
With no less than 13 Foam mats, with a finely punched imitation leather covering to ooze quality, will be pre-installed to ensure you're computing with no annoying buzzing or whirling.<br>
<br>
- Dimensions: 214 x 511 x 528mm<br>
- Motherboard Compatiblity: ATX, Micro-ATX, Mini-ITX<br>
- Room for 120 x 240mm Radiator inside the top and bottom<br>
- External SATA HDD dock<br>
- Includes SSD Adapter<br>
- Cable management and CPU retaining holes for easy maintainence<br>
- Support Tri-GFXs<br>
- 4 x 5.25" Drive Bays<br>
- 7 x 3.5" Drive Bays<br>
- I/O Panel: USB2.0, 1 x eSATA, 2 x Audio<br>
- Front Cooling: 1 x 140mm Blue LED Fan<br>
- Rear Cooling: 1 x 120mm Fan<br>
- Top Cooling: 1 x 140mm Fan<br>
- Bottom Cooling: 2 x 120mm Fans (optional)<br>
- Right Side Cooling: 2 x 120 or 140mm Fans (optional)<br>
- Left Side Cooling: 1 x 80mm Fan<br>
- HDD Cage Cooling: 1 x 120mm Fan (optional)<br>
- VGA Holder: 1 x 80mm Fan (optional)<br>
<br>
<div id="docview"><object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0" width="200" height="120"><param name="movie" value="http://www.overclockers.co.uk/LP/techlabs/icons/silent.swf" /><param name="quality" value="high" vmode=transparent /><embed src="http://www.overclockers.co.uk/LP/techlabs/icons/silent.swf
" quality="high" pluginspage="http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" width="200" height="120"></object></div></center>
Was £119.99 Inc. VAT
Only £116.39 inc VAT.
ORDER NOW
OcUK Tech Lab - QNAP Turbo NAS TS-259 PRO+ - 2 Bay 4TB NAS Solution @ £650.99 inc VAT
nonl2br
OcUK Tech Lab Performance Network Attached Storage is the perfect solution for all of your data needs. The OcUK Tech Labs Nas range includes the bestselling models from Synology and QNAP and come populated with ultra-reliable, <strong>Western Digital Caviar Green Hard Drives</strong>.<br>
<br>Each OcUK Tech Labs NAS Solution is assembled by an expert giving you peace of mind that the data you value is in safe hands. <br>
<br>Our entire NAS range is tested after installation to ensure that the hardware is functioning properly, after this a Senior Technical Supervisor is tasked with Quality Assurance to ensure that your Home or Business NAS solution reaches you in perfect condition, ready to configure your storage array.
<br><br>
<br>
QNAP TS-259 Pro+ 2-bay NAS Enclosure<br>
Key Features<br>
<br>
• Assembled In House by Expert OcUK Technical Staff<br>
• 4TB Storage Capacity (2X Western Digital Caviar Green 2TB Hard Drive) <br>
• NAS and iSCSI storage solution<br>
• Flexible multiple LUNs management<br>
• Secure IP SAN environment deployment<br>
• Designed for virtualized and clustered environments<br>
• VMware Ready certified iSCSI array / Citrix Ready certified iSCSI storage<br>
<br>
Modern business faces the challenge of dramatic growth of digital data, including documents, emails, applications, and so on. To deploy the IT environment with a reliable, affordable and expandable storage center to securely store, share, and back up the digital assets has become an important task for the server managers of the SMB and entry-level enterprise nowadays.<br>
<br>
TS-259 Pro+ houses up to two 3.5-inch or 2.5-inch SATA hard disk drives, incorporates Intel Atom 1.8GHz dual core processor and 1GB DDRII memory, and is capable of delivering ultra high performance, reliability, and lower power consumption during intensive data transfers. The NAS is an efficient and powerful business storage center with advanced iSCSI services, cross-platform data sharing, and all-in-one server applications. With VMware Ready and Citrix Ready certification, and proven compatibility with Microsoft Hyper-V environment, the NAS is an ideal shared storage solution in the virtualized and clustered environment.<br>
<br>
FTP Server<br>
You can set up Turbo NAS as an FTP server and share the files conveniently with your friends or customers.<br>
<br>
Encrypted Remote Replication<br>
The data on Turbo NAS can be backed up to or from other Turbo NAS or Rsync servers over the network.<br>
<br>
File Server<br>
Turbo NAS allows file sharing across Windows, Mac, Linux, and UNIX platforms. It also supports WebDAV for you to access the share folders via HTTP/HTTPS protocol remotely.<br>
<br>
Printer Server<br>
Turbo NAS supports USB printer sharing over the network (max. 3 USB printers).<br>
<br>
Backup Server<br>
Turbo NAS offers you the most complete backup solution with Apple Time Machine support, remote replication to an Rsync server, Windows client backup software NetBak Replicator, and third party backup software support, and so on.<br>
<br>
Virtual Host Supported Web Server<br>
You can host multiple websites on Turbo NAS with the built-in web server and virtual host feature. The NAS supports PHP, MySQL, HTTPS connection, and SSL authentication. It is the ideal solution for you to create your own websites, e-shops, blogs, content management system (CMS), wiki, and so on.<br>
<br>
Surveillance Station<br>
You can connect to maximum 2 IP cameras via Turbo NAS and set up a video surveillance system with comprehensive monitoring, recording, and playback features.<br>
<br>
IPv6<br>
Turbo NAS supports IPv6 (Internet Protocol Version 6) which makes your NAS a dual-stack IP host running IPv4 and IPv6 at the same time.<br><br>Our Tech Labs NAS Solutions are configured in house by our technicians. We endeavour to keep stock of all items at all times.
Should an item be in short supply or unavailable it will be exchanged for a suitable alternative.
Custom Units can take 24 to 48 hours<br>
Was £698.99 Inc. VAT
Only £650.99 inc VAT.
ORDER NOW
OcUK Tech Lab - V10 Watercooling Kit 360 @ £224.98 inc VAT
Designed with a small footprint in mind, the components in this kit maximising cooling capacity
The costs involved and the myriad of choices available can be confusing to newcomers who crave the high performance, silence and gorgeous aesthetics that a watercooled system provides.
In the past, Watercooling Kits have nearly always had cheap, low quality parts in the box that are prone to failure or were generally low quality.
OcUK have stepped in and solved this problem. With each OcUK Kit you get everything you need to watercool your PC along with full installation instructions. this means you cant go wrong. You don't run the risk of ordering the wrong parts, and you are assured out of the box compatibility.
Pair this with the Ultra High End performance of EK products and you have the quick and easy solution you need to gain those extra MHz
Ideal for first time watercooling enthusiasts and seasoned veterans alike.
Component List:
1X XSPC EX360 120mm Radiator - Black
Offering superb performance, build quality and value the XSPC EX range of radiators are the obvious choice for high end watercooled systems.
1X Laing 10W DDC-Pump 12V DDC-1T
The best small footprint watercooling Pump on the planet.
1X XSPC Acrylic Tank Reservoir for Laing DDC
A Reservoir that fits on the top of the DDC pump with proven performance.
1X EK Supreme HF CPU Waterblock - Copper Plexi
The most popular waterblock on the planet, and for good reason. A mixture of market leading performance and superb build quality. It's called the 'Supreme' for a reason!
3X Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin Fans
The most recognised performance fans for watercooling radiators.
1X Mayhems Ultra Pure H20 Watercooling Fluid
The purest water available - ensuring the best temperatures.
2X XSPC 7/16" ID [16/11mm] Clear
High quality watercooling tubing with a superb bend radius
2X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Black Nickel Finish
Trusted and reliable fittings. These fittings ensure a tight grip on your tubing for long lasting reliability.
IMPORTANT:
Kit is easy to install, use and maintain (thorough installation manual is available on our forums).
This kit can also be upgraded with an additional VGA waterblock!
You will need to buy two additional fittings alongside your graphics card block.
Please ask our friendly sales team for VGA block advice.
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
- AMD Sockets: 939, 754, 940
- AMD Sockets: AM2, AM2+, AM3
***NOTE***
Our Custom Watercooling Kits and Cases are configured in house by our technicians. We endeavour to keep stock of all items at all times.
Custom Units can take 24 to 48 hours if assembly of a component is required.
Whilst we endeavour to keep watercooling stock levels high for our watercooling systems, there may be some occasions where stock shortages mean that there will be a delay in completing your order. If this is the case, then our sales team are able to suggest alternative components to allow your order to be completed.
Was £234.98 Inc. VAT
Only £224.98 inc VAT.
ORDER NOW
Plantronics GameCom 777 USB 7.1 Surround Sound Headset @ £44.39 inc VAT
This open-eared headset with 7.1 Dolby Headphone technology gives you an unparalleled audio advantage that lets you hear your opponents before you see them. Connect with the Dolby USB sound card for a true 7.1 experience. But if needed, an analogue connection is also provided. Stay comfortable with a lightweight frame and specially designed ear pods that redistribute pressure. When you’re ready to fire off orders, unveil the hidden, noise-cancelling mic boom to strategize clearly with team members. Responses coming in? Adjust audio levels using in-line volume and mic-mute controls.
- Dolby Headphone technology delivers a 5-channel audio experience.
- Dolby USB sound card is the only way to get the 7.1 experience. If needed, an analog connection is also provided.
- Open-ear design keeps you connected to the game and your surroundings.
- Concealed mic boom stays hidden until you’re ready to use it.
- Specially designed ear pods redistribute pressure for maximum comfort.
- In-line volume and mic-mute controls allow for easy audio adjustment.
- Noise-cancelling microphone lets you communicate clearly.
- Rugged, military-grade design and extra-strength cables make your hardware hardcore.
Was £49.99 Inc. VAT
Only £44.39 inc VAT.
ORDER NOW
Creative Draco HS-850 Gaming Headset @ £32.78 inc VAT
The Creative Draco HS-850 gaming headset delivers sounds so real you'll get absorbed into another reality in no time. Designed and tuned by top acoustic and gaming designers, large Neodymium drivers produce explosive bass that will blow you away while full-size circumaural earcups in soft leatherette provide comfortable usage. For travel convenience, swivel earcups fold neatly for easy storage and to switch to music listening, simply detach the noise-canceling microphone and use it as a pair of headphones. Feel the game expand all around you with the Draco HS-850. Let the battle begin!
- Realistic sound, explosive bass
- Comfortable full-size earcups isolate noise
- Travel-friendly and easy to store
- Headset or headphones - it's your call
- Flexible noise-canceling microphone
- Convenient in-line volume controls
- 1 Year limited warranty
Was £33.98 Inc. VAT
Only £32.78 inc VAT.
ORDER NOW
Ozone ATTACK Stereo Gaming Headset @ £16.56 inc VAT
ATTACK is quick and efficient, is the gaming headset that came to win. Its compact leather cushions fit on your head with a light and tight feeling. The adjustable headband is built in soft materials for comfort during intense use. The revolutionary microphone allows setting the headset as a gaming intercom device or as a regular music and multimedia headphones.
The mini jack 3.5mm connector makes it easy to use and compatible with most portable music players. ATTACK uses braided cables to add quality and durability, and its in-line controller with volume control and microphone mute functions is the handy interface for this complete ATTACK.
- Comfort leather cushions
- Ergonomic Adaptive headband
- Revolution Adjustable mic
- Mini jack 3.5mm connection
- Easy In-line Controller
Microphone
- Mic Dimensions: ø6.0 x 5.0mm
- Directivity: Omnidirectional
- Impedance: ?2.2K?
- SPL: -38dB±3dB
Headphones
- Driver Dimensions: ø40mm
- Impedance: 32?
- Frequency: Response 15~25kHz
- Sensitivity (SPL): 98dB±3dB
General
- Cord Length: 2.5m
- Plug: 3.5mm jack x2 (headphones + mic)
- Net Weight: 258g
Was £16.98 Inc. VAT
Only £16.56 inc VAT.
ORDER NOW
Steelseries Siberia v2 Gaming Headset - Green (51120) @ £62.76 inc VAT
Based on the award-winning SteelSeries Siberia Full-size Headset, the v2 features major enhancements in sound quality, comfort and its microphone. Every element of the v2 has been optimized for pro gaming, making the headset a preferred piece of equipment for the worlds' best competitive PC gamers - the most demanding headset users in the world.
Sporting 25% larger 50mm driver units, the SteelSeries Siberia Full-size Headset dramatically boosts overall acoustic performance. Experience a rich and detailed soundscape from immersive atmospheric background music to precise 3D positional sounds of footsteps, gunfire and more.
The close type ear cups feature thick leather padded cushions built from sound dampening foam, designed to offer passive noise reduction from loud surroundings and improve comfort over prolonged use. A virtually invisible uni-directional microphone can be retracted from the left ear cup, optimized for essential voice communications.
The v2 remains lightweight and its trademark headband suspension construction makes it extremely comfortable for use over long periods of time.
- Closed type headphones.
- Pull-out microphone.
- Crystal clear high, low and mid-tones.
- 50mm driver units.
- Lightweight suspension construction.
- Integrated volume control located on the cord.
- 2 years warranty
Was £69.98 Inc. VAT
Only £62.76 inc VAT.
ORDER NOW
SpeedLink Medusa NX Stereo Gaming Headset v2 @ £17.99 inc VAT
Enjoy outstanding sound with detailed trebles and intensive bass: the Medusa NX Stereo delivers first-class stereo sound for action-packed PC games, while the flexible noise-cancelling microphone makes it easier to communicate with your teammates. The adjustable headband allows you to achieve the perfect fit, while the practical in-line remote offers convenient control of the volume and sound levels. What's more, the Medusa NX Stereo's low weight and comfortable padding offers maximum comfort - making it the first choice for long gaming sessions.
- Gaming headset
- Maximum comfort and lightweight
- Flexible noise-cancelling microphone
- In-line remote
- Breathtaking sound quality
- Outstanding stereo sound
- Weight: 602g
- Packaging Dimensions: 512 (W) x 254 (H) x 108 (D) mm
Was £19.98 Inc. VAT
Only £17.99 inc VAT.
ORDER NOW
Razer Chimaera 5.1 Wireless PC & Xbox Gaming Headset @ £155.99 inc VAT
The Razer Chimaera 5.1 Wireless Gaming Headset for Xbox 360 gives you a true-to-life surround sound experience. Building on our extensive gaming audio expertise from PC gaming, this wireless headset offers pinpoint tournament grade 5.1 positional audio with extra large circumaural ear cups for maximum comfort.
The base station doubles up as a charging dock and audio processing unit, giving you the option to adjust the game sound and link up to four base stations to talk to your teammates over a lag-free, local communication channel.
5.1 Channel Dolby Surround Sound for Pinpoint Positional Audio
Offering the full range of surround sound, with drivers tuned for 3D positional audio the Razer Chimaera 5.1 Wireless Gaming Headset for Xbox 360 will allow you to anticipate your enemies every step and hear the true game sound in full detail.
5.8 GHz Frequency Headset for Interference-free Wireless Performance
The Razer Chimaera 5.1 allows a true wireless Xbox experience for up to 8 hours with no cables restricting your movement. Using the 5.8 GHz frequency protects this headset against almost all wireless interferences
Dedicated Lag-free Local Team Communications
Up to four Razer Chimaera 5.1 base stations can be connected to create a lag-free, crystal clear voice channel for dedicated team conversations
• Wireless Headset:
• Circumaural Design with 50mm Driver Units
• Volume & Mic Control Buttons on the Headset
• 3 Preset EQ
• Detachable 2.5mm Microphone Cable
• Dimensions: 200mm(W) 204mm(H) 88mm(D)
• Headphones:
• Radio Frequency: 5.8GHz
• Dolby Headphone / Dolby Pro Logic II / Dolby Digital
• Wireless Range: 33ft / 10m
• Frequency Response: 20 - 20,000 Hz
• Impedance: 32O at 1kHz
• Sensitivity (@1kHz, 1V/Pa): 105dB +/- 2dB
• Drivers: 50 mm, with Neodymium Magnets
• Batteries: 2 AAA Batteries (Up to 8 Hours Battery Life)
• Charging Time: 3 Hours
• Warranty: 1 Year Manufacturer Warranty
Cables Included
Razer Chimaera 5.1:
- Digital optical cable
- RCA to RCA cable
- 3.5mm to 3.5mm cable
- 2.5mm to 2.5mm cable
- AC power adapter
Was £158.99 Inc. VAT
Only £155.99 inc VAT.
ORDER NOW
Microsoft LifeCam Studio Webcam for Business @ £55.39 inc VAT
The closest to being there. Experience the vivid sights, sounds, and colors of real life with HD video.
- Full 1080p HD sensor for superior sharpness and image quality
- Auto Focus to ensure crisp, sharp images
- Wide-angle glass element lens for advanced, high-precision optics
- TrueColor Technology to deliver bright and colorful video, in virtually all lighting conditions
- ClearFrame Technology for smooth, detailed video
- High-fidelity microphone for more natural, detailed audio
- Tripod Compatible
- Windows Live Movie Maker compatible
- Windows Live Photo Gallery compatible
- Windows Live Call Button
- Works with popular instant messengers such as Windows Live Messenger, Yahoo!, AOL Instant Messenger, and Skype.
- 3-Year Warranty
Requires a PC that meets the requirements for and has installed one of these operating systems: Windows 7, Windows Vista® with Service Pack 1 (SP1) or higher, Windows XP
VGA video calling:
Intel Dual-Core 1.6 GHz or higher
1 GB RAM
For 720p HD recording:
Intel Dual-Core 3.0 GHz or higher
2 GB RAM
Was £58.99 Inc. VAT
Only £55.39 inc VAT.
ORDER NOW
CyberPower GreenPower 800VA UPS with AVR @ £65.83 inc VAT
The GP Series UPS with Automatic Voltage Regulator (AVR) is the best solution for SOHO to supply a clean and stable power. The GP series UPS is compatible with many different operating systems, including Microsoft Windows 98/Me/2000/NT/XP/Vista. PowerPanel® Personal Edition management software included for USB Port shows versatility of a UPS, like power voltage, scheduled shutdown, and remaining battery capacity?remaining battery runtime?battery status ...etc. GP Series UPS can save upto 75% of electricity and save your electricity bill.
- Energy-Saving UPS
- Automatic Voltage Regulator (AVR)
- Auto scheduled software
- USB & Serial connectivity ports
- 3 Output Connectors
- Compact design with highest power output
- Power Management software included
- Green Power Technology
- Auto restart / Auto charge
- Save upto 75% of electicity
- Equipment Protection Policy up to 25,000 Euros
- 800VA / 480W
- Cables Included: 1 x power cable - integrated
Was £69.43 Inc. VAT
Only £65.83 inc VAT.
ORDER NOW
Philips Longlife R6 (4) Zinc AA (R6L4B/10) @ £0.47 inc VAT
Top low-drain device batteries
For your low-drain products, choose LongLife batteries. Zinc-Chloride technology is perfect for your clocks, radios, calculators and remote controls.
Top Performance
- High-quality Zinc-Chloride technology ensures long life
- The battery remains fresh for use for up to 3 years
Environmentally Responsible
- Philips ZnC batteries contain 0% harmful heavy metals
Was £0.89 Inc. VAT
Only £0.47 inc VAT.
ORDER NOW
Hardware Labs Black ICE Radiator SR1 120 - Black @ £43.79 inc VAT
The Black Ice SR1 120 takes ultra-stealth performance that silences the competition. Utilizing the new Black Ice SR-1 platform, the SR1-120 provides superior cooling using sub-1000rpm fans with performance scaling effectively up to 2000rpm. This gives PC enthusiasts an unprecedented option to run their systems at ultra-silent levels with additional heat exchange capacity in reserve.
• Two-pass u-flow configuration utilizing high-flow tubes for up to 40% increase in internal flow rates.
• Custom compressed core width to maximize airflow and enhance heat exchange.
• Optimized custom 9 FPI (Fins Per Inch) 45 micron copper maximized conductivity.
• Yields up to 30% more heat exchange capacity than the Black Ice® GTX in ultra-stealth operation (sub-1000rpm fan).
• Built-in 15mm deep plenum for equalized core air pressure distribution.
• M4 Threaded Screw Holes for easier mounting and greater adaptability.
• Standard G 1/4" female threaded fittings.
• Full high-temper brass structural construction for weight reduction and superior corrosion resistance.
• Fully RoHS compliant.*
• Full electrostatic polyurethane painting finish for uniform coating with high temperature curing for increased finish durability.
• Carbon Black Finish
• Renowned Black Ice® quality.
Was £44.99 Inc. VAT
Only £43.79 inc VAT.
ORDER NOW
Hardware Labs Black ICE SR-1 240 Radiator @ £67.58 inc VAT
The Black Ice® SR1-240 bridges the gap between ultra-stealth and extreme high performance allowing it to effectively utilize sub-1000 rpm fans and scale performance up to 2000rpm. Ultra-stealth operation with increased thermal capacity, and from the industry's standard bearer for quality and craftsmanship.
Features:
- Two-pass u-flow configuration utilizing high-flow tubes for up to 40% increase in internal flow rates.
- Custom compressed core width to maximize airflow and enhance heat exchange.
- Optimized custom 9 FPI (Fins Per Inch) 45 micron copper maximized conductivity.
- Yields up to 30% more heat exchange capacity than the Black Ice® GTX in ultra-stealth operation mode up to 2000rpm.
- Built-in 15mm deep plenum for equalized core air pressure distribution.
- M4 Threaded Screw Holes for easier mounting and greater adaptability.
- Standard G 1/4" female threaded fittings.
- Full high-temper brass structural construction for weight reduction and superior corrosion resistance.
- High performance compact radiator compatible as an upgrade to the Black Ice® Xtreme III, Black Ice® GTX240 and most 3x120mm fan form factor radiators.
- Uses 100% Non-corrosive water-soluble fluxing process.
- Fully RoHS compliant.
- Full electrostatic polyurethane painting finish for uniform coating with high temperature curing for increased finish durability.
- Carbon Black Finish.
- Renowned Black Ice® quality.
- Patent Pending Design.
Was £69.98 Inc. VAT
Only £67.58 inc VAT.
ORDER NOW
5 Pack - Verbatim BD-RE 2x 25GB Blu-ray 5pk JC (43615) @ £19.19 inc VAT
The advent of Blu-ray technology has led to the introduction of high capacity storage discs to meet the demand cause by the rapid growth of high definition television (HDTV). Blu-ray discs get their name from blue laser technology. The shorter wavelength of the laser is the reason it is blue in colour. The blue laser has a wavelength of 405nm compared with the wavelength of 650nm for DVD which utilises red laser technology. The benefit of having a blue laser with a shorter wavelength means it is possible to write smaller data pits and therefore vastly increase the amount of data on the disc. Blu-ray discs offer 3 to 5 times the storage capacity of a standard recordable DVD disc, enabling the recording, rewriting and playback of high definition video (HD).
Key Features
• Hard Coat protective layer.
• Extremely long archival life.
• For use in BD writers and recorders.
Rewritable Blu-ray Disc with Hard Coat Protection for a longer lifetime and 1000 rewrites. BD-RE discs come with SERL (Super Eutectic Rcording Layer). The recording layer is returned to perfect condition on every erase cycle, leaving a flawless disk for the next recording.
This disc complies with BD-RE Specification Version 2.1.
For use in drives or recorders that support 25GB Blu-ray Discs without cartridges.
Was £19.99 Inc. VAT
Only £19.19 inc VAT.
ORDER NOW
10 Pack - Mirror BluRay 4x Inkjet Full Face Printable 25GB @ £8.88 inc VAT
Blu-ray Disc is the next-generation optical disc format that was developed to enable recording and playback of high-definition video (HD), as well as storing large amounts of data. A single-layer Blu-ray Disc can hold 25GB, which can be used to record over 2 hours of HDTV. Blu-ray uses a blue-violet laser to read and write data while current optical disc technologies such as DVD use a red laser. The shorter wavelengths of the Blu-ray technology make it possible to record more data on the same space. These discs are safeguarded by a super hard coat which protects against everyday wear and tear. With the rapid growth of HDTV, Blu-ray will meet the consumer demand for recording HD programming and is expected to replace VCRs and DVD recorders over the coming years.
- Brand: Mirror
- Format: Blu-Ray
- Capacity: 25GB Single Layer
- Top Surface: Full Face Inkjet Printable
- Packaging: 10 Discs in a Cakebox / Spindle Tub
Was £8.99 Inc. VAT
Only £8.88 inc VAT.
ORDER NOW
10 Pack - Verbatim DVD+R Double Layer 8x (43666) @ £8.52 inc VAT
Verbatim Double Layer Discs provide a massive 8.5GB (2.6 for 8cm products) storage capacity. The double layer of recording has been made possible by the creation of a new substrate layer that sits in between each recording layer, that allows the laser beam to record on both layers. Once the first layer has been recorded, the laser re-focused to record on the second layer.
- Write-Once Double Layer DVD+R
- 8.5GB Native Capacity
- 8x Write Speed
- Spindle
- Matt Silver Disc Surfacer
Was £8.99 Inc. VAT
Only £8.52 inc VAT.
ORDER NOW
50 Pack - Verbatim DVD-R 16-Speed 4.7GB (43548) @ £10.79 inc VAT
Verbatim's DVD-R was designed to meet the needs of users who demand a higher capacity. Therefore designed primarily for businesses and consumers for data archiving, video, audio, multimedia imaging and more!
- AZO Recording Layer
- 4.7GB Native Capacity
- 16x Write Speed
- Lifetime Warranty
Was £10.99 Inc. VAT
Only £10.79 inc VAT.
ORDER NOW
25 Pack - TDK CDR-80 52x 25pc Cakebox (T18767) @ £4.79 inc VAT
Developed for ultimate performance, and manufactured to the most exacting standards, TDK CD-R media is the ideal digital storage solution. CD-R disks are write once, meaning a CD-R can be fully recorded one time, but can't be erased or rerecorded.
Key Features
• Write-Once CDR
• Native Capacity 700MB
• Write Speed 52x
• Package Type Spindle
• Disc Surface Silver
Was £4.99 Inc. VAT
Only £4.79 inc VAT.
ORDER NOW
50 Pack - TDK CD-R 52-Speed 700MB Printable (T19514) @ £9.95 inc VAT
With TDK PrintOn CD-R, you can personalize every aspect of a disc by inkjet printing eye-catching images, text and graphics directly on the disc's label-side surface. Because it gives every recording a professionally produced appearance, TDK PrintOn CD-R media is the ultimate alternative to labeling kits and marker pens.
- Product Features
- Capacity: 700MB
- Speed: 52x
- Pack Style: 50 Pack (Spindle)
- Disc Surface: Full Face Inkjet Printable
Specifications
- Capacity 700MB
- Format CD-R
- Speed 52x
- Pack Size 50
- Pack Type Spindle
- Disc Surface Full Face Inkjet Printable
Was £9.98 Inc. VAT
Only £9.95 inc VAT.
ORDER NOW
Edimax BR-6574N Wireless-N 300Mbps Gigabit Broadband Router @ £52.58 inc VAT
Edimax BR-6574n is a high performance broadband router which complies with gigabit Ethernet ports and wireless 11N solution. With advanced wireless11N MIMO technology, it’s wireless data transmission rate can be 12 times better (up to 300Mbps) and 6 times better coverage than a
standard 802.11g/b router.
BR-6574n supports Edimax EZView management system which allows you to manage your router locally or remotely. UPnP compatible devices are automatically detected and information about the device will be listed in the management interface of the router. EZMax is a unique Multi-language
Setup CD Wizard. You can setup the router to the Internet within minutes by following the simple animated steps.
The BR-6574n is a high cost-efficiency router for Small office / Home office users, all computers and network devices can share a single xDSL / cable modem internet connection at high speed.
- Complies with 2.4GHz IEEE802.11n and IEEE 802.11b/g standards
- Complies with IEEE802.3/802.3u/802.3ab 10/100/1000Mbps Ethernet standards
- Supports EZMax Multi-language Setup Wizard
- Supports EZView management
- Supports NAT/NAPT IP sharing
- WAN Protocols: PPPoE/Static IP/PPTP/DHCP/L2TP
- Supports advanced 2T3R MIMO technology to enhance the throughput and coverage range
significantly
- High speed data rate – up to 300Mbps.
- Supports Virtual Server and DMZ
- Supports Wi-Fi Protected Setup ( WPS ) with reset button
- Supports 64/128-bit WEP encryption and WPA-PSK, WPA2-PSK security
- Supports WMM function to meet the multimedia transmission requirement
- Supports WDS and Universal Repeater mode
- Supports Special Applications (Port Triggers)
- Supports DDNS (DynDNS, TZO), and QoS
- Supports VPN pass through (IPSec/PPTP)
- Supports MAC/IP filtering and URL blocking
- Supports DHCP server and Anti-Dos firewall
- Web user interface (remote configuration)
- Firmware upgradeable
Was £54.98 Inc. VAT
Only £52.58 inc VAT.
ORDER NOW
Edimax EW-7811UN 150Mbps High-Gain Wireless-N USB Micro Adapter @ £10.79 inc VAT
EW-7811Un is a nano USB wireless adapter that supports maximum range and speed. Despite the size, this tiny USB adapter supports higher data rate of up to 150Mbps when connecting with wireless 802.11n device which is 3 times faster than your normally 11g connection. You can just plug it into computer's USB port and enjoy incredible high-speed wireless network access. This is for sure the trendiest piece of upgrade you can make to your wireless network.
- Complies with wireless 802.11b/g/n standards with data rate up to 150Mbps
- Green Power Saving : supports smart transmit power control and auto-idle state adjustment
- Increases wireless coverage 3 times further.
- Includes multi-language EZmax setup wizard
- Supports 64/128-bit WEP, WPA , WPA2 encryption and WPS-compatible
- Supports QoS-WMM, WMM-Power Save mode
Was £11.98 Inc. VAT
ORDER NOW
TP-Link AV200 200Mbps Mini Powerline Starter Kit (TL-PA211KIT) @ £35.99 inc VAT
nonl2br
<b>What This Product Does</b><br>
TP-LINK's powerline adapter TL-PA211 takes advantage of your home's existing electric wires to transfer data while transferring traditional power. That means, with no additional wiring required, users can simply plug the TL-PA211 into existing power sockets and establish networking infrastructure in a flash. With high-speed data transfer rates of up to 200Mbps, you can enjoy HD video streaming, online gaming, VoIP or any other high bandwidth intensive tasks.<br><br>
<img src="http://www.tp-link.com/Resources/UploadFiles/Image/products/overview/PLC/nonewwirespa211.jpg"><br><br><br><br>
<b>Super Small Design</b><br>
With the new ultra-compact housing design, TP-LINK TL-PA211 is much smaller than most other 200Mbps Powerline Products. At just 30mm thick and with its high quality, elegant white shell, it almost blends in completely in front of any power outlet and additionally can be placed anywhere in the room.<br><br>
<img src="http://www.tp-link.com/Resources/Up...uct Features/[Features]super small design.jpg"><br><br><br><br>
<b>Up to 200Mbps, 300 Meters</b><br>
With advanced HomePlug AV technology, TL-PA211 provides users with stable, high-speed data transfer rates of up to 200Mbps on a line length of up to 300 meters. Together with its built-in Qos and powerful AES encryption, the TL-PA211 is a great choice for a whole home solution to connect all network compatible devices--from computers and game consoles to set-top boxes for IPTV to printers and NAS hard drives.<br><br>
<img src="http://www.tp-link.com/Resources/UploadFiles/Image/products/overview/PLC/PA211022.jpg"><br><br><br><br>
<b>Twin Pack Design</b><br>
The PLC connection is transmitting the data through the electric wire between two outlets, so it at least requires two PLC adapters pluged into the outlet to transform the data streaming. With twin pack design, the starter kit ensures to establish a powerline network for the first time.<br><br><br><br>
<b>Reduces Power Consumption Up to 65%</b><br>
The TL-PA211, a new-generation Powerline Adapter, with its logical practical product design and sophisticated Power-Saving Mode, it now consumes less power when compared with existing Powerline Adapters. When there is no data transmission or reception occurs over a certain period of time, it will automatically switch from its regular "Working" Mode to "Power-Saving" Mode that will reduce the energy consumption by up to 65%.<br><br><br><br>
<b>Pair Button for Easy Network Security</b><br>
Simply by pushing the Pair button on the adapters, users can set up a hassle-free Powerline network within minutes, complete with 128-bit AES encryption for network security and data protection.
It's that simple!
1. Plug the adapter into the power outlet
2. Connect the device via the network cable to the adapter
3. Press the encryption buttons—and you're done<br><br><br><br>
<img src="http://www.tp-link.com/Resources/Up...ct Features/[Features] PLC 'Pair' Button .jpg"><br><br><br><br>
- HomePlug AV standard compliant, high-speed data transfer rates of up to 200Mbps <br>
- Twin Pack design helps establish a powerline network initially <br>
- Super small design with a new exterior, blends in completely in front of any power outlet <br>
- No new wires, Easy Plug and Play operations, No configuration required <br>
- <b>UK Standard Plug <br></b>
- Patented Power-Saving Mode automatically reduces power consumption by up to 65%<br><br>
Was £39.98 Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
TP-Link 8-Port Gigabit Desktop Switch (TL-SG1008D) @ £23.99 inc VAT
The TL-SG1008D 8-port Gigabit Ethernet Switch provides you with a high-performance, low-cost, easy-to-use, seamless and standard upgrade to improve old network to 1000Mbps network. Increase the speed of your network server and backbone connections, or make Gigabit to the desktop a reality. Power users in the home, office, workgroup, or creative production environment can now move large, bandwidth-intensive files faster. Transfer graphics, CGI, CAD, or multimedia files and other applications that have to move large files across the network almost instantly.
- Supports IEEE 802.3x flow control for Full Duplex mode and backpressure for Half Duplex mode
- Non-blocking switching architecture that forwards and filters packets at full wire-speed for maximum throughput
- Supports MAC address auto-learning and auto-aging
- LED indicators for monitoring power, link, activity
- Plastic case, desktop or wall-mounting design
- External power adapter supply
Was £24.98 Inc. VAT
Only £23.99 inc VAT.
ORDER NOW
Edimax EW-7416APN 300Mbps Wireless-N Access Point @ £29.99 inc VAT
Acting as a bridge between the wired Ethernet and the 2.4GHz wireless IEEE 802.11b/g/n, this wireless access point let your wireless client stations access both the wired and the wireless network nodes. The Universal Repeater function could extend the coverage and signal strength for the current wireless environment. This standardized function is compatible with other wireless APs and Routers.
- Compliant with IEEE 802.11b/g/n standards
- Increases the wireless speed up to 12 times faster and extends the coverage up to 5 times further
- Supports WDS repeater mode, universal repeater mode and AP client mode
- Supports point-to-point and point-to multi point bridge function
- Supports WPA, WPA2 security enhanced function and WPS configuration button
Was £31.98 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Samsung 64GB SSD 830 Desktop Series SATA 6Gb/s KIT with Norton Ghost - (MZ-7PC064D/EU) @ £83.99 inc VAT
nonl2brThe Samsung SSD 830 Series boasts superior random read speeds (up to 80,000 IOPS) and faster
sequential read and write speeds (up to 520 MB/s & 400 MB/s respectively). It’s the ideal solution for
your everyday computing needs, such as web browsing, document creation, viewing or editing
multimedia files, playing PC games, etc.
<br><br>
Samsung’s SSD Magician software eliminates the confusion and uncertainties of SSD management,
making it simple for users to maximize the performance and lifetime of their Samsung SSD. The
software helps to maintain the SSD at its peak condition, giving you the same great performance and
reliability throughout the life of your PC. In addition to its performance maintenance features, SSD
Magician also provides system information and facilitates performance benchmarking, performance
optimization, OS optimization, firmware updates, secure erasing, and over provisioning.<br>
<br><br>
- Capcity: 64GB<br>
- Dimensions (LWH): 100 x 69.5 x 7 (mm)<br>
- Samsung Toggle NAND<br>
- Sequential Read: 520MB/s<br>
- Sequential Write: 160MB/s<br>
- 4K Random Read: 75,000 IOPS<br>
- 4K Random Write: 16,000 IOPS<br>
- Warranty: 3 years<br>
- Norton Ghost<br>
- SSD 2.5"-3.5" tray<br>
<br><br>
<object width="640" height=" boi" name="cfc979bon" classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000"><param name="movie" value="http://p.castfire.com/FrZKr/video/812619/812619_2011-12-06-112719.720p.flv"><param name="allowFullScreen" value="true"><param name="allowScriptAccess" value="always"><embed width="640" height="400" src="http://p.castfire.com/FrZKr/video/812619/812619_2011-12-06-112719.720p.flv" id="cfc979bei" name="cfc979ben" type="application/x-shockwave-flash" allowFullScreen="true" allowScriptAccess="always" /></object>
Was £89.99 Inc. VAT
Only £83.99 inc VAT.
ORDER NOW
Samsung 128GB SSD 830 Desktop Series SATA 6Gb/s KIT with Norton Ghost - (MZ-7PC128D/EU) @ £149.99 inc VAT
multimedia files, playing PC games, etc.<br>
<br><br>
<br><br>
- Capcity: 128GB<br>
- Sequential Write: 320MB/s<br>
- 4K Random Read: 80,000 IOPS<br>
- 4K Random Write: 30,000 IOPS<br>
- Norton Ghost<br>
<br><br>
Was £161.99 Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Samsung 256GB SSD 830 Desktop Series SATA 6Gb/s KIT with Norton Ghost - (MZ-7PC256D/EU) @ £275.99 inc VAT
<br><br>
<br><br>
- Capcity: 256GB<br>
- Sequential Write: 400MB/s<br>
- 4K Random Write: 36,000 IOPS<br>
- Norton Ghost<br>
<br><br>
Was £319.99 Inc. VAT
Only £275.99 inc VAT.
ORDER NOW
Samsung 512GB SSD 830 Desktop Series SATA 6Gb/s KIT with Norton Ghost - (MZ-7PC512D/EU) @ £581.99 inc VAT
<br><br>
<br><br>
- Capcity: 512GB<br>
- Norton Ghost<br>
<br><br>
Was £589.99 Inc. VAT
Only £581.99 inc VAT.
ORDER NOW
Intel 520 Series 60GB 2.5" SATA-3 Solid State Hard Drive - Retail @ £89.99 inc VAT
Get Fast. Play Fierce.
Faster game and application loads, less lag, smoother visuals.
Stay ahead of the competition when you level up to 6.0 gigabits per second (Gb/s) performance
Cherryville Solid-State Drives (SSDs) continue to evolve with the Intel®
SSD 500 Family. Available in a wide range of capacities, Cherryville SSDs
offer built-in data protection features and deliver exceptional
performance over hard drives.
New Level of Performance
Built with compute-quality Intel 25 nanometer (nm) NAND Flash Memory, Cherryville SSDs accelerate PC performance where it matters most. With random read performance up to 50,000 input/output operations per second (IOPS)1 and sequential read performance of up to 550 megabytes per second (MB/s)2, your PC will blaze through the most demanding applications and will handle intense multi-tasking needs. Couple that read performance with random writes up to 80,000 IOPS3 and sequential writes of 520 MB/s2 to unleash your applications. With Cherryville SSDs, Intel continues to deliver solutions designed to satisfy the most demanding gamers, media creators and technology enthusiasts.
Superior Data Protection Features
The new Cherryville SSDs offer the best security features of any Intel® Solid-State Drive to date and comes pre-configured with Advanced Encryption Standard (AES) 256-bit encryption capabilities. In the event of theft or loss of your computer, you have the peace of mind that your personal data is secured by an advanced encryption technology. Additionally, the Cherryville SSDs contain “End to End Data Protection” ensuring integrity of stored data from the computer to the SSD and back.
Proven Reliability with Lower Operating Costs
With no moving parts, the Cherryville SSDs reduce your risk of data loss due to laptop bumps or drop, all while consuming less power than a traditional hard drive—so you can stay mobile longer. Now that your work is safe, use the world-class performance of the Cherryville SSDs to dominate your gaming competition or to reach new levels of creativity and productivity. The choice is yours!
- Capacity: 60GB
- Controller: SandForce SF-2281
- Maximum Read: 550MB/sec
- Maximum Write: 475MB/sec
- Max I/O Per Second (IOPS): 80000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 5 years
Was £103.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Intel 520 Series 120GB 2.5" SATA-3 Solid State Hard Drive - Retail @ £149.99 inc VAT
- Capacity: 120GB
- Maximum Write: 500MB/sec
- Warranty: 5 years
Was £163.99 Inc. VAT
ORDER NOW
Intel 520 Series 180GB 2.5" SATA-3 Solid State Hard Drive - Retail @ £221.99 inc VAT
- Capacity: 180GB
- Maximum Write: 520MB/sec
- Warranty: 5 years
Was £259.99 Inc. VAT
Only £221.99 inc VAT.
ORDER NOW
Intel 520 Series 240GB 2.5" SATA-3 Solid State Hard Drive - Retail @ £275.99 inc VAT
- Capacity: 240GB
- Warranty: 5 years
Was £365.99 Inc. VAT
ORDER NOW
Intel 520 Series 480GB 2.5" SATA-3 Solid State Hard Drive - Retail @ £639.98 inc VAT
- Capacity: 480GB
- Warranty: 5 years
Was £719.99 Inc. VAT
Only £639.98 inc VAT.
ORDER NOW
"Titan 610a" AMD 970 DDR3 Ready Barebones (Socket AM3+) @ £193.18 inc VAT
The "Titan 610a" offers the performance needed for a pure gaming machine. The AMD 970 DDR3 barebones will accept all AMD socket AM3+ compatible processors and any dual channel DDR3 Memory kits. Pre-built and ready to accept your hardware the "Titan 610a" is perfect for keen gamer who wants to add their personal taste to their system with out the hassle of building it from the ground up. Just add your CPU, RAM, HDD, Optical Drive and your GFX card of choice you are ready to go.
System Specification
- Case: BitFenix Shinobi Windowed Gaming case - Black
- Motherboard: Asus M5A97 AMD 970 (Socket AM3) DDR3 Motherboard
- Power Supply: OCZ ZS 550W PSU
- Cooler: Cooler Master Hyper 212 EVO Cooler (note: the cooler isn't installed only backplate it installed onto the motherboard for ease of installation)
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
The lead time on all pre-built barebones is between 24-48 hours.
Was £209.98 Inc. VAT
Only £193.18 inc VAT.
ORDER NOW
"Titan 610i" Intel Sandybridge Z68 DDR3 Ready Barebones (Socket 1155) @ £245.98 inc VAT
The "Titan 610i" offers the performance needed for a pure gaming machine. The Intel 1155 DDR3 barebones will accept all Intel 1155 socket compatible processors and any dual channel DDR3 Memory kits. Pre-built and ready to accept your hardware the "Titan 610i" is perfect for keen gamer who wants to add their personal taste to their system with out the hassle of building it from the ground up. Just add your CPU, RAM, HDD, Optical Drive and your GFX card of choice you are ready to go.
- Motherboard: Asus P8Z68-V GEN3 (Socket 1155) DDR3 Motherboard
Was £269.98 Inc. VAT
Only £245.98 inc VAT.
ORDER NOW
"Primo 500i" Intel G41 DDR3 Ready Barebones (Socket 775) @ £60.79 inc VAT
The "Primo 500i" offers the performance needed for home and business use at a low price. The Intel Core 2 Duo/Quad barebones will accept all Intel Core 2 Duo.Quad socket 775 compatible processors and any dual channel DDR3 Memory kits. Pre-built and ready to accept your hardware the "Primo 500i" is perfect for the home and business user who wants to add their personal taste to their system. Just add your CPU, RAM, HDD and any Optical Drive and you are ready to go. No external graphics card required thanks to the Onboard Intel graphics.
- Case: OcUK IMP microATX case - Black
- Motherboard: Gigabyte GA-G41MT-S2P Intel G41 (Socket 775) DDR3 microATX
- Power Supply: OcUK Value 500W PSU
Was £67.99 Inc. VAT
Only £60.79 inc VAT.
ORDER NOW
"Primo PLUS 510i" Intel H61 DDR3 Ready Barebones (Socket 1155) @ £192.98 inc VAT
Introducing our range of "PLUS" series barebones systems. Like a barebones system, just a little more complete! Our "PLUS" barebones ship complete with: CPU, CPU cooler, memory, motherboard, case and power supply all pre-installed and ready to go. All that is require is a Hard drive or SSD and an optical DVD drive and you are ready to go. Designed and specified by our in house team of professionals for ease of use, performance and reliabilty. Start off your custom system build with an OcUK "PLUS" barebones!
- Motherboard: Asus P8H61-M Intel H61 (Socket 1155) DDR3 Motherboard
- CPU: Intel Core i3 2120 3.30GHz (Socket 1155) CPU
- Memory: Kingston HyperX Genesis Grey 4GB 1600MHZ C9
Was £204.98 Inc. VAT
Only £192.98 inc VAT.
ORDER NOW
"Ultima 720i" Intel X79 DDR3 Ready Barebones (Socket 2011) @ £553.98 inc VAT
The "Ultima 720i" offers the performance needed for a pure gaming machine. The Intel X79 DDR3 barebones will accept all Intel 2011 socket compatible processors and any dual/quad channel DDR3 Memory kits. Pre-built and ready to accept your hardware the "Ultima 720i" is perfect for keen gamer who wants to add their personal taste to their system with out the hassle of building it from the ground up. Just add your CPU, RAM, HDD, Optical Drive and your GFX card of choice you are ready to go.
- Case: Corsair 600T case - White
- Motherboard: Asus P9X79 PRO (Socket 2011) DDR3 Motherboard
- Power Supply: OCZ ZX 850W PSU
- Cooler: Corsair H80 CPU Cooler (note: the cooler isn't installed only backplate it installed onto the motherboard for ease of installation)
Was £589.98 Inc. VAT
Only £553.98 inc VAT.
ORDER NOW
Acer E-Machines ET1862 Intel Core i3 540 3.06GHz DDR3 Full System @ £289.19 inc VAT
Push your play and creativity further with the eMachines® ET1862 Desktop delivering multitasking performance and expansion possibilities with the eMachines® quality and price you expect. Intel® Core i3 processing, Genuine Windows® 7 Home Premium 64-bit, 3GB memory fuel your everyday computing needs so you can listen to music, edit digital photography, manage finances and multitask with ease.
Comes complete with Mouse and keyboard
- Form Factor - Micro tower
- Processor - Intel Core i3 540 3.06GHz Dual Core
- RAM - 3072 MB
- Chipset - Intel H57 Chipset
- Hard Drive - 500 GB
- Optical Drive - DVD-ROM
- Operating System - Windows 7 Home Premium
- 1 Year Acer RTB Warranty
Was £299.99 Inc. VAT
Only £289.19 inc VAT.
ORDER NOW
"Nano 100a" AMD Hudson 1.60GHz Dual Core System @ £256.39 inc VAT
Introducing the new "Nano" range of ultra small, energy efficient, media systems. With VESA mounting compaitbilty and silent operation making for a system perfectly suited to the home or in the office as a business system. A small size means that less space is taken up allowing for a cleaner, clearer working environment, when utilising the VESA mount, the Nano can stay tucked away out of sight. Utilising the latest AMD Fusion onboard APU for ultra low power consumption whilst providing excellent dual core processing power with sharp, fluid DX11 cinematic graphics.
Why You Should Buy This System?
- AMD Fusion APU E-350 1.60GHz offers power saving hyperthreading performance
- 8 Hours stressed tested and quality controlled
- 160GB hard drive gives a solid and reliable storage capacity.
- 4GB of 1600MHz DDR3 RAM allows for snappy and precise processes to be made.
- Case: Antec ISK110 - Black
- Power Supply: 90W AC Adaptor
- CPU: AMD Fusion APU E-350 1.60GHz Dual Core
- Motherboard: AMD FCH A50 DDR3 Motherboard
- RAM: 4GB DDR3 1600MHz Single Channel Kit
- Hard Drive: 160GB HDD
- Graphics Card: Integrated ATI Radeon™ HD 6310 GPU
- Sound: 7.1 channel HD Audio
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Ultra small size, perfect for putting behind your monitor or TV. Excellent streaming capabilities and low power consumption make the "Nana 100a" the intelligent choice.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £268.39 Inc. VAT
Only £256.39 inc VAT.
ORDER NOW
Zotac Z-Box Nano VIA U4025 - Mini PC @ £144.00 inc VAT
Experience the pinnacle of computing value with the palm-sized Zotac ZBOX nano VD01 mini-PC powered by the VIA Nano X2 U4025 dual-core processor. The Zotac ZBOX nano VD01 combines a VIA Nano X2 processor with the VIA VX900H Media System Processor with VIA Chrome 9 graphics processor for enhanced video playback capabilities that accelerates streaming Internet video and high-definition Blu-ray decoding.
High performance energy-efficient computing is only a couple thumbscrews away with the Zotac ZBOX nano VD01 mini-PC thanks to a user-friendly design that makes mastering the mini-PC quick and easy. Space for a 2.5-inch hard drive and a 204-pin DDR3-1066 SO-DIMM slot enables users to customize the internals of the Zotac ZBOX nano VD01 to their own needs while USB 3.0 and USB 2.0 ports, a 6-in-1 memory card reader (SD/SDHC/MS/MS Pro/xD/MMC) and eSATA port provide greater external expansion capabilities for perfect palm-sized energy-efficient computing.
Features:
- VIA Padlock hardware security;
- Advanced dual-core processing;
- Hardware video decode acceleration;
- Hardware virtualization capable;
- Microsoft DirectX 9 compatible;
- Integrated 802.11n WiFi & Bluetooth 3.0;
- 2 Years Manufacturers Warranty;
Full Specification:
- Specifications: VIA Chrome 9 GPU, VIA Nano X2 U4025 CPU (dual-core, 1.2 GHz), VIA VX900H chipset;
- Internal Expansion: 1 2.5-inch SATA 3.0 Gb/s hard drive, 1 204-pin DDR3-1066 SO-DIMM (up to 4GB);
- Display Outputs: HDMI (1080p w/2-channel audio), DisplayPort, HDCP compliant, Dual simultaneous displays;
- Front Ports: Power button, Hard drive LED, WiFi LED, IR receiver, 6-in-1 Memory card reader (MMC/SD/SDHC/MS/MS Pro/xD), Headphone/Audio out jack, Microphone jack;
- Rear Ports: Power connector, 2 USB 3.0 ports, 10/100/1000 Ethernet (RJ45), 2 USB 2.0 ports, eSATA connector, WiFi antenna connector;
- Inside the box: Zotac ZBOX nano VD01, Power brick & cable, VESA monitor mount (w/4 screws), MCE compatible remote w/ 2 CR2032 batteries, USB IR receiver, WiFi antenna;
- Warranty: 2 Years Manufacturers Warranty;
Was £180.00 Inc. VAT
Only £144.00 inc VAT.
ORDER NOW
Xenon AMD Bulldozer FX-6 6100 3.30GHz Bundle - Six Core @ £202.98 inc VAT
Designed by experts the "Xenon AMD Bulldozer FX-6 6100 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Xenon AMD Bulldozer FX-6 6100 Bundle" offers you speed and silence in perfect combination.
Why You Should Buy This Bundle?
- Prebuilt and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers fast load times
- Six Core processing performance
Bundle Specification
- CPU: AMD Bulldozer FX-6 6100 3.30GHz
- Motherboard: Asus M5A78L-M LX AMD 760G (Socket AM3+) DDR3 Motherboard
- RAM: 4GB DDR3 1600MHz Dual Channel
- Cooler: AMD Stock Cooler
Service Package
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Was £214.98 Inc. VAT
Only £202.98 inc VAT.
ORDER NOW
"Primo 6100a AMD Llano A4-3300 2.50GHz DDR3 Dual Core System @ £310.75 inc VAT
The "Primo 6100a" offers the performance needed for home and business use at a low price. The AMD Llano A4-3300 2.50GHz combined with 4GB of 1600MHz DDR3 RAM, offers a quick and easy multitasking experience.
- AMD Llano A4-3300 2.50GHz (Socket FM1) offers multitasking performance.
- 500GB Western Digital hard drive gives a solid and reliable storage capacity.
- 4GB of 1333MHz DDR3 RAM allows for snappy and precise processes to be made.
- All systems with an operating system selected ship out with a pre-installed 180 day trial of Panda Antivirus 2012
- CPU: AMD Llano A4-3300 2.50GHz (Socket FM1)
- Motherboard: AMD A55 Chipset (Socket FM1) DDR3 Motherboard
- RAM: 4GB or 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: 500GB HDD
- Graphics Card: Integrated HD 6410D Graphic
- Sound: ALC662 6-channel High Definition Audio CODEC
- Optical Drive: LG GH22NS50 22x DVD±RW SATA ReWriter
Service Package
Compact, reliable and smart. The "Primo 6100a" give you everything you need in a entry level home/business system.
Was £329.95 Inc. VAT
Only £310.75 inc VAT.
ORDER NOW
"Primo 6100i" Intel Core i3 2100 3.10GHz DDR3 Dual Core System @ £377.96 inc VAT
The "Primo 6100i" features a Intel Core i3 550 3.20GHz processor seamless multi-tasking capabilities which is perfect for home/office use. Awesome power contained within a small chassis the "Primo Ignition" has the option to upgrade to one of many of the latest Low Power, energy efficient Nvidia series graphics cards for extra graphical punch. Utilising Hyper threading technology the "Primo Ignition" makes short work of video encoding and multitasking.
- Intel Core i3 2100 3.10GHz (Clarkdale) Processor with Hyperthreading technology for 4 Virtual cores
- 500GB Hard drive gives massive storage capacity including DVD Re-Writer Make this system perfect for data backup
- Case: OcUK IMP microATX Case
- Power Supply: OcUK 500W PSU
- CPU: Intel Core i3 2100 3.20GHz (Clarkdale)
- Motherboard: Intel H61 (Socket 1155) DDR3 microATX Motherboard
- Cooler: Intel Approved Cooler
- Graphics Card: Onboard Intel GMA graphics or a choice of energy efficient graphics cards
- Sound: High Definition 7.1 Onboard Sound Card
- Optical Drive: LG GH22NS50 22x DVD+RW SATA ReWriter
Service Package
With multiple video outputs, compact size and advanced hyperthreading technology the "Primo 6100i" is perfect for the user looking for a highperformance system for a low price.
Was £401.96 Inc. VAT
Only £377.96 inc VAT.
ORDER NOW
Krypton X79 820i Intel Core i7 3960X 3.30GHz @ 4.40GHz DDR3 Overclocked Bundle @ £1,276.98 inc VAT
Designed by experts the "Krypton X79 850i Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.40GHz overclock has the processing power and speed unseen at this price point ever before. The "Krypton X79 850i" will accelerate your computer experience into the next level.
- A solid, optimised 4.40GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 16GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- USB3, SATA 6GB/s and Intel Ethernet for next gen computing
- CPU: Intel Core 3960X 3.30GHz @ 4.40GHz CPU
- Motherboard: Gigabyte X79-UD3 Intel X79 (default choice)
- RAM: G.Skill RipJawZ 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Quad Channel
- Cooler: Phantek PH-TC14PE CPU Cooler
- Artic Silver 5 Thermal Compound
Service Package
Was £1,324.98 Inc. VAT
Only £1,276.98 inc VAT.
ORDER NOW
Krypton Z68 600i Intel Core i5 2500K 3.30GHz @ 4.60GHz Overclocked Bundle @ £400.97 inc VAT
Designed by experts the "Krypton Z68 600i Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.60GHz overclock has the processing power and speed unseen at this price point ever before. The "Krypton Z68 600i" will accelerate your computer experience into the next level.
- A solid, optimised 4.60GHz overclock profile provides outstanding processing performance
- 4GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- USB3, SATA 6GB/s, Intel Ethernet and EUFI graphical BIOS for next gen computing
- CPU: Intel Core i5 2500K 3.30GHz @ 4.60GHz Sandybridge CPU
- Motherboard: Asus P8Z68-V Intel Z68 (default choice)
- RAM: Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Corsair A50 CPU Cooler Cooler
Service Package
Was £415.37 Inc. VAT
Only £400.97 inc VAT.
ORDER NOW
Krypton Z68 650i Intel Core i7 2700K 3.50Ghz @ 4.60Ghz Overclocked Bundle @ £496.37 inc VAT
Designed by experts the "Krypton Z68 650i Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.60GHz overclock has the processing power and speed unseen at this price point ever before. The "Krypton Z68 650i Bundle" will accelerate your computer experience into the next level.
- CPU: Intel Core i7 2700K 3.50GHz @ 4.60GHz Sandybridge CPU
- Motherboard: Asus P8Z68-V (default choice)
- RAM: Kingston HyperX Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
Service Package
Was £520.37 Inc. VAT
Only £496.37 inc VAT.
ORDER NOW
Radon 500a AMD Llano A6-3670K 2.70GHz @ 3.20GHz Overclocked Bundle @ £231.19 inc VAT
Designed by experts the "Radon 500a Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Radon 500a Bundle" will accelerate your computer experience into the next level.
- 4GB/8GB of Dual Channel DDR3 memory delivers unlimited bandwidth
- Advanced APU graphics
- CPU: AMD Llano A6-3670K 2.70GHz @ 3.20GHz
- Motherboard: Asus F1A75-M AMD A75 (Socket FM1) DDR3 Motherboard
- RAM: Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel (8GB Upgrade available)
- Cooler: Cooler Master Hyper 212 EVO CPU Cooler
Service Package
Was £243.19 Inc. VAT
Only £231.19 inc VAT.
ORDER NOW
Radon 510a AMD Llano A8-3870K 3.00GHz @ 3.50GHz Overclocked Bundle @ £253.99 inc VAT
Designed by experts the "Radon 510a Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Radon 510a Bundle" will accelerate your computer experience into the next level.
- CPU: AMD Llano A8-3870K 3.00GHz @ 3.50GHz
Service Package
Was £265.99 Inc. VAT
Only £253.99 inc VAT.
ORDER NOW
Radon 530a AMD Llano A8-3870K 3.00GHz HYBRID Crossfire Bundle @ £295.99 inc VAT
Designed by experts the "Radon 530a Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Radon 530a Bundle" will accelerate your computer experience into the next level. Designed to utilise the awesome power of Hybrid Crossfire giving excellent DX11 gaming performance.
- Advanced APU graphics with HYBRID Crossfire enabled
- Cooler: Stock AMD Cooler
- Graphics Card: Asus ATI Radeon HD 6670 SILENT EDITION 1024MB GDDR3
Service Package
Was £307.99 Inc. VAT
Only £295.99 inc VAT.
ORDER NOW
Krypton 700a AMD Bulldozer FX-4 4100 3.60GHz @ 4.00GHz Overclocked Bundle @ £251.98 inc VAT
Designed by experts the "Krypton 700a Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Krypton 700a Bundle" will accelerate your computer experience into the next level.
- 4GB of Dual Channel DDR3 memory delivers unlimited bandwidth
- Quad Core processing performance
- CPU: AMD Bulldozer FX-4 Quad Core 4100 3.60GHz @ 4.00GHz
- Motherboard: Asus M5A97 PRO AMD 970 (Socket AM3+) DDR3 Motherboard (Upgrade Options available)
- RAM: Kingston HyperX Genesis Grey (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
Service Package
Was £261.58 Inc. VAT
Only £251.98 inc VAT.
ORDER NOW
"Cataclysm Hogger" Intel Core i3 2100 3.10GHz DDR3 MMO Dual Core Gaming System @ £560.36 inc VAT
The "Cataclysm Hogger" is the perfect starting point for any avid MMO player with all the features to play the latest expansion straight out of the box. Equipped with a GTX 550Ti 1024MB graphic cards as standard you can immerse yourself in the fantasy world with no need to worry about the FPS dropping. Whether you are a new player or a seasoned raider the "Cataclysm Hogger" is your stepping stone to epicness.
- Featuring the Nvidia GeForce GTX 550Ti 1024MB Graphics card
- Precision built and cabled by Overclockers UK expert technicians
- Optimised for intense raiding and WOW gameplay mechanics
- Case: Antec 300 - Black
- Power Supply: OCZ ZS 550w PSU
- CPU: Intel Core i3 2100 3.10GHz Clarkdale
- Motherboard: Intel H61 (Socket 1155) PCI-Express DDR3 Motherboard
- Cooler: Intel Stock CPU Cooler
- RAM: 4GB DDR3 1600MHz Dual Channel Kit
- Graphics Card: OcUK GeForce GTX 550Ti 1024MB
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
Utilising the latest Nvidia GeForce Series of graphics cards, the "Cataclysm Hogger" is the starting point for the perfect World Of Warcraft gaming machine.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
Was £569.96 Inc. VAT
Only £560.36 inc VAT.
ORDER NOW
Battlefield War Rush Intel Core i5 2500K 3.30GHz @ 4.40GHz DDR3 Limited Edition Quad Core System @ £615.96 inc VAT
Ready the Scud missiles, arm the Tomahawks and prime the Nukes. Fire up the tanks, scramble the jets and roll in the artillery! Control the Battlefield in the palm of your hand with the "Battlefield War Commander", designed and engineered for hardcore gaming. During the heat of the battle the "Battlefield War Commander" will complete the mission no questions asked. Featuring the multiple award winning Gigabyte Z68AP-D3 motherboard for ultimate reliability and overclocking performance. With a choice of DX11 graphics cards to choose from, you can equip yourself with the right weapon for the mission ahead.
- A guaranteed 4.40GHz performance for the price of 3.30GHz
- Choose from a selection of graphics cards to meet your performance needs
- USB3, SATA 6GB/s, Intel Ethernet for next gen computing
- Case: Antec 300 Gaming Case
- Power Supply: OCZ ZS 650w PSU
- CPU: Intel Core i5 2500K 3.30GHz @ 4.40GHz Sandybridge CPU
- Motherboard: Intel Z68 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Graphics Card: Choice of DX11 Compatible Graphics Cards
Service Package
Command, control and dominate the battlefield with the "Battlefield War Rush" system.
Was £629.96 Inc. VAT
Only £615.96 inc VAT.
ORDER NOW
"Titan 8000a Krypt" AMD Bulldozer 3.60GHz Quad Core System @ £497.57 inc VAT
The "Titan 8000a Krypt" features a AMD Bulldozer FX-4 Quad Core 4100 3.60GHz Processor, combined with a selection of high performance, handpicked components designed to meet your desire for the perfect gaming system.
Why Should You Buy This System?
- Includes the superb AMD Bulldozer FX-4 Quad Core 4100 3.60GHz Processor
- 8GB of high performance gaming memory guarantees the smoothest possible experience when multitasking and ensures you never have a break in the action
- Case: Antec 300 Gaming Case (default choice, options available)
- CPU: AMD Bulldozer FX-4 Quad Core 4100 3.60GHz Processor
- Motherboard: AMD 760G Chipset (AM3+) Motherboard
- RAM: 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drives: 1TB HDD
- Graphics Card: AMD 760G Onboard (default choice, options available)
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: OcUK 22x DVD±RW SATA ReWriter (Black)
- Cooling: x2 White LED 120mm Fans
Service Package
If your after the latest in AMD technology then this system is for you. Quad core technology and DDR3 performance at an excellent price point.
Was £521.95 Inc. VAT
Only £497.57 inc VAT.
ORDER NOW
"Titan 8200a Punisher" AMD Bulldozer 4.00GHz DDR3 Six Core System @ £758.96 inc VAT
The "Titan 8200a Punisher" features an AMD FX-6 6100 overclocked and guaranteed to a stable 4.00GHz. With six processing cores and dual channel DDR3 memory the "Titan 8200a Punisher" powers through applications and games with equal ease. Designed for gaming on the edge, the "Titan 8100a Punisher" delivers blistering performance and amazing DX11 visuals from a choice of DX11 graphics cards.
- A guaranteed 4.00GHz performance for the price of 3.30GHz
- Six Core processing and DX11 performance.
- USB 3.0 compatible system
- Case: Cooler Master HAF 912 Gaming Case (default choice, options available)
- Power Supply: OCZ ZS Series 650W '80 Plus Bronze Certified' Modular Power Supply
- CPU: AMD FX-6 6100 3.30Ghz overclocked to 4.00Ghz
- Motherboard: Asus Sabertooth 990FX DDR3 Motherboard
- Cooler: OcUK H2 Flo Extreme Cooler w/ x2 Sharkoon Silent Eagle Fans
- Graphics Card: ATI Radeon HD 5450 SILENT 512MB (default choice, options available)
Service Package
Annihilate all with AMD six core. The "Titan 8200a Punisher" provides unrelenting performance at an amazing price.
Was £806.96 Inc. VAT
Only £758.96 inc VAT.
ORDER NOW
"Titan 8300i Supersaurus" Intel 4.60GHz Quad Core System @ £900.73 inc VAT
The Supersaurus was the largest Herbivore to roam the World in times once gone by, now embrace the power of the legendary dinosaur with the "Titan 8300i Supersaurus". Featuring the Intel Core i5 2500K overclocked to a storming 4.60GHz and can be equipped with the most powerfull graphics cards available, the "Titan 8300i Supersaurus" is literally armed to the teeth. For the extreme among you, you can upgrade to a GTX 580 enabling you to dominate all the opposition.
- A guaranteed 4.60GHz performance for the price of 3.30GHz
- DX11 cinematic graphics for the ultimate performance
- SATA 6GB/s, Intel Ethernet for next gen computing
- Case: Coolermaster CM 690 II Dominator Lite - Black (default choice, options available)
- CPU: Intel Core i5 2500K 3.30GHz Overclocked to 4.60GHz Sandybridge CPU
- Motherboard: Gigabyte Z68X-UD5 Intel Z68 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Hard Drive: 1TB + OCZ 60GB Sata 6GB/s Solid State Drive
- Sound: Asus Xonar DG PCI Sound Card
- Optical Drive: DVD+/-RW SATA Drive
Service Package
Embrace the power of the "Titan 8300i Supersaurus" with DX11 graphics and Intel Sandybridge technology. Take the advantage with the "Titan 8300i Supersaurus".
Was £924.73 Inc. VAT
Only £900.73 inc VAT.
ORDER NOW
"Ultima 9400i Tyrannosaur" Intel 4.80GHz Quad Core System @ £1,674.95 inc VAT
The "Ultima 9400i Tyrannosaur" is the our Sandybridge flagship system. Named after the fearsome Dinosaur, strike fear into the hearts of your enemies with the ferocious power the "Ultima 9400i Tyrannosaur" has to offer. Equipped with the powerful GTX 580 graphics card delivering cinematic DX11 graphics and smashing through even the most demanding of games. The heart of the system is powered by the brand new Intel Core i7 2700K CPU overclocked to a massive 4.80GHz. With 4 cores and hyperthreading you will experience a seamlessly smooth computing experience. A choice of SSDs allows you to increase the speed of your system by ten fold. A massive 1TB Seagate drive brings in the storage for all your films, games and photos. Lay waste to all, with the "Ultima 9400i Tyrannosaur".
- A guaranteed 4.80GHz performance for the price of 3.50GHz
- Case: NZXT Phantom Enthusiast Full Tower Case - Orange/Black (default choice, options available)
- Power Supply: OCZ ZX 850 Gold Rated PSU
- CPU: Intel Core i7 2700K 3.50GHz Sandybridge overclocked to 4.80GHz
- Motherboard: Asus Maximus IV Extreme -Z Intel Z68 (Socket 1155) DDR3 Motherboard
- Cooler: OcUK H²Flo Extreme Liquid Dual Fan CPU Cooler w/ x2 Sharkoon Silent Eagle Fans
- RAM: 8GB (2x4GB) DDR3 Dual Channel Kit
- Hard Drive: 1TB HDD
- Graphics Card: Nvidia GeForce GTX 580 1536MB GDDR5 PCI-Express Graphics Card (SLI option available)
- Sound: Onboard 7.1 Audio
- Optical Drive: Samsung SH-B123L/RSBP 12x BD-ROM / 16x DVD Writer Drive - Black
Service Package
Harness the power of the "Ultima 9400i Tyrannosaur" with the all new Intel Sandybridge CPUs and Intel Z68 Chipset. Hunt down your prey with the "Ultima 9400i Tyrannosaur" and be the ultimate predator.
Was £1,794.95 Inc. VAT
Only £1,674.95 inc VAT.
ORDER NOW
"Ultima 9500i Monolith" Intel 4.20GHz Hex Core System @ £1,783.94 inc VAT
Introducing a new game changer, the "Ultima 9500i Monolith", harnessing the all powerful Intel Core i7 3960X Hex Core CPU. Unlocking the true potential of the CPU with a mental 4.20GHz overclock. The Intel X79 chipset allows for quad channel memory an industry first allowing for unlimited bandwidth and ultra high capacities to be utilised. Choose your favourite DX11 compatible graphics card for the ultimate gaming experience. Consider pairing the "Ultima 9500i Monolith" with an optional SSD upgrade, to provide split second boot times and lightning fast transfer speeds.
- A guaranteed 4.20GHz performance for the price of 3.30GHz
- Quad Channel DDR3 memory for unlimited bandwidth
- Hex core processing for seamless multitasking
- Case: Coolermaster HAF X Case
- CPU: Intel Core i7 3960X 3.30GHz Sandybridge - E overclocked to 4.20GHz
- Motherboard: Asus P9X79 PRO Intel X79 (Socket 2011) DDR3 Motherboard
- RAM: 16GB (4x4GB) DDR3 Quad Channel Kit
- Graphics Card: DX11 GFX Options
- Optical Drive: OcUK 22x DVD±RW SATA ReWriter - Black
Service Package
Weild the power of Intel X79 and next generation Hex core i7 power with the "Ultima 9500i Monolith".
Was £1,903.94 Inc. VAT
Only £1,783.94 inc VAT.
ORDER NOW
OcUK Tech Lab - "Ultima 9550i TUNDRA" Intel i7 4.80GHz Quad Core System @ £1,579.97 inc VAT
Winter is a time for many things; gifts, family, celebration and GAMING! Stay warm inside and pwn your friends whilst all the noobs play around in the snow! The latest games releases are what Winter is about for most gamers. We have a special edition range of systems designed just for that sole reason. Providing excellent performance at any price point to keep you entertained through out this Christmas and beyond! DX11, SATA 6GB/s, USB 3.0 aren't just cool acroynms, they are all standard features of our extreme gaming systems. Whether it is taking to the skys in a fighter jet, racing down Laguna Seca raceway or storming through the streets of Russia, our extreme range of gaming systems will see you through!
- True DX11 gaming performance available from a choice of compatible graphics cards
- SATA 6GB/s and Intel Ethernet for next gen computing
- Case: Corsair 600T - White
- Power Supply: PC Power & Cooling Silencer MK III 600w PSU - White
- CPU: Intel Core i7 2700K 3.60GHz @ 4.80GHz Sandybridge
- Cooler: Custom Watercooling Loop
- Hard Drive: 2TB HDD
- Graphics Card: Choice of the latest DX11 Graphics cards
Service Package
Ultimate performance for the ultimate gamer. Custom watercooling keeps you cool in the heat of the moment and dyanamic white & black styling makes you stand out in the crowd.
Was £1,639.97 Inc. VAT
Only £1,579.97 inc VAT.
ORDER NOW
Workstation PRO Z68 Intel Core i7 2600K 3.40GHz @ 4.50GHz Overclocked Bundle - 16GB @ £537.98 inc VAT
Designed by experts the "Workstation PRO Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.50GHz overclock has the processing power and speed unseen at this price point ever before. The "Workstation PRO Bundle" will accelerate your computer experience into the next level. Designed for intense workstation applications, with a total 16GB of RAM at your disposal you can run even the most demanding of programs
- A solid, optimised 4.50GHz overclock profile provides outstanding processing performance
- CPU: Intel Core i7 2600K 3.40GHz @ 4.50GHz Sandybridge CPU
- Motherboard: Asus P8Z68-V GEN3 Intel Z68 (Socket 1155) DDR3 Motherboard
- RAM: Kingston HyperX Genesis Grey 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel
Service Package
Was £549.98 Inc. VAT
Only £537.98 inc VAT.
ORDER NOW
Asus Sabertooth 990FX AMD 990FX (Socket AM3+) DDR3 Motherboard @ £126.00 inc VAT
Was £134.98 Inc. VAT
Only £126.00 inc VAT.
ORDER NOW
Asus M5A99X EVO AMD 990X (Socket AM3+) DDR3 PCI-Express ATX Motherboard @ £105.60 inc VAT
ASUS has announced a new line up of AMD based motherboards that support the 990FX/990X/970 chipsets and AM3+ CPUs, the first company in the market to provide fully compatible AM3+ motherboards. The new motherboards will be the first on the AMD chipset based platform to support both multi-GPU technologies AMD CrossFireX™ and NVIDIA® SLI™.
The M5A99X EVO series offers unsurpassed compatibility with new AMD AM3+ socket CPUs, whilst also being backwards compatible with the previous generation AM3 CPU. The M5A/99 core series is equipped with DIP2, which features DIGI+ VRM technology in addition to the TPU and EPU. DIGI+ VRM power delivery allows users to precisely adjust and control power settings digitally for precise power control and flexible tuning of their system, perfectly serving the AM3+ CPU specification’s power demand. Digital control differs from analogue controls by eliminating digital to analogue conversion lag, which helps to improve overclocking capabilities. This means precise power flow adjustment and management as well as easy and flexible tuning including extra DRAM power control for the AMD platform. It is the most precise power delivery available, providing the best-in-class in power efficiency, performance and stability while also helping to maximize the overall overclocking potential.
Also included on the M5A99X EVO is the intuitive UEFI BIOS menu interface. UEFI BIOS allows a user to control and adjust their BIOS settings through the use of a mouse-enabled interface for more user-friendly navigation. The built-in EZ Mode option also provides a drag-and-drop boot priority option, for easier management of boot devices.
ASUS Unique Selling Points:
ASUS Dual Intelligent Processors 2 with DIGI+ VRM:
DIGI+VRM - Industry leading Digital 6+2 Phase Power Design
EPU with Switch -
TPU with Auto Tuning and TurboV: Providing simple steps to easy overclocking.
UEFI BIOS(EZ Mode): Flexible & Easy BIOS Interface.
Front Panel USB 3.0 Support: Easy storage access.
MemOK!: Quickly ensures memory boot compatibility.
AI Suite II: One-stop Access to All Innovative ASUS Software.
Ai Charger+: Ensure reliable mobile phone charging.
ASUS Q-Connector: Easily access your PCI-E connectors.
ASUS Q-Shield: Protect yourself from EMI.
ASUS Q-LED (CPU, DRAM, VGA, Boot Device LEDs)
ASUS Q-Slot: Make Connection Quick and Accurate!
ASUS Q-DIMM: Make Connection Quick and Accurate!
O.C. Profile: Allows you to store multiple Bios images.
EZ Flash 2: Easily update your systems bios firmware.
ASUS MyLogo 2: Customize your boot screen.
Precision Tweaker 2: Easily tune your PC system performance.
Fan Xpert: Smart thermal control via fan speed detection.
Key specification:
- Form Factor: ATX Form Factor, 12”x 9.6” (30.5cm x 24.4cm)
- Socket: AMD Socket AM3+ for FX™ / Phenom™II / Athlon™II / Sempron™ 100 Series Processors Including 8-Core.
- Chipset: AMD 990X / SB950 Chipset
- Graphics interface: 2 x PCIe 2.0 x16 slots (Single@x16 speed; Dual@x8/x8 speed)
- Expansion Slots: 1 x PCIe 2.0 x16 slot (Black@x4 speed), 2 x PCIe 2.0 x1 slots, 1 x PCI slot.
- Multi GPU: Supports NVIDIA® Quad-GPU SLI™ and ATI® Quad-GPU CrossFireX™ Technology.
- Memory: 4 x DIMM, max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 MHz, ECC and non-ECC, un-buffered memory, Dual channel memory architecture
- Audio: Realtek® ALC 892 8-channel High Definition Audio CODEC
- LAN: Realtek® 8111E Gigabit LAN controller
- Storage: 6 x SATA 6Gb/s ports with RAID 0, 1, 5, 10, 2 x SATA 3Gb/s ports, 1 x Power eSATA 3Gb/s port, 1 x eSATA 3Gb/s port.
- USB: 2 x USB 3.0/2.0 ports at mid-board for front panel support, 2 x USB 3.0/2.0 ports at back panel (blue).
- Manageability: WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Was £111.98 Inc. VAT
Only £105.60 inc VAT.
ORDER NOW
Gigabyte GA-880GM-USB3 AMD 880G (Socket AM3+) DDR3 MicroATX Motherboard @ £57.60 inc VAT
The GA-880GM-USB3 introduces revolutionary Gigabyte Ultra Durable 3 Classic technology on AMD platform featuring a 2oz copper PCB and further helps to reduce the system temperature and dramatically enhance the performance. Based on AMD 880G chipset, the GA-880GM-USB3 is integrated ATI Radeon HD 4200 (DX10.1) graphics engine and supports AMD Phenom II quad-core processors, DDR3 memory modules, HyperTransport 3.0 technology links, PCI Express 2.0 graphics interface and more. With the innovative Gigabyte Easy Energy Saver technology, GA-880GM-USB3 is able to provide user friendly computing, reach the maximum system performance easily while still able to save the power and environment in real life at the same time.
- AMD 880G Chipset with 6 core support
- Hybrid Crossfire Support
- Onboard GFX with HDMI output
- MicroATX Form Factor
- 3 Year Warranty
Was £64.98 Inc. VAT
Only £57.60 inc VAT.
ORDER NOW
gigabyte ga-78lmt-s2p 760g (socket am3+) ddr3 microatx motherboard @ £33.60 inc vat
was £35.99 inc. vat
only £33.60 inc vat.
order now
intel dx79si intel x79 (socket 2011) ddr3 motherboard @ £222.00 inc vat
intel is at it again when it comes to the performance and bandwidth that extreme gamers, digital media creators, and ultimate multitaskers need most. the intel® desktop board dx79si provides unmatched performance in production and editing, as well as digital media rendering and real-time audio/video preview capabilities. the massive data throughput and support for the intel® core™ i7 processor extreme edition runs more applications simultaneously, with less wait time. superspeed usb 3.0, sata 6.0 gb/s, quad channel ddr3 memory and full support for amd crossfirex* and nvidia sli* technology are just a few of the many features supported on this board.
product description - intel desktop board dx79si extreme series - motherboard - atx - lga2011 socket - x79
manufacturer warranty - 3 years warranty
product type - motherboard - atx
chipset type - intel x79 express
compatible processors - xeon, core i7
audio - hd audio (8-channel)
processor socket - 1 x lga2011 socket
environmental standards - energy star qualified
microsoft certification - compatible with windows 7
max supported memory - 64 gb
ram supported - 8 dimm slots - ddr3 sdram , non-ecc, ecc
storage ports - 2 x sata-600 (raid), 4 x sata-300 (raid)
lan - gigabit ethernet
usb / firewire ports - 2 x superspeed usb + 1 x firewire + 6 x hi-speed usb + (1 x firewire + 8 x hi-speed usb via headers)
was £229.38 inc. vat
only £222.00 inc vat.
order now
asus p8z68-v gen3 intel z68 (socket 1155) ddr3 motherboard @ £134.40 inc vat
asus is proud to introduce the p8z68-v/gen3 motherboard taking the award winning asus p8z68 series to the next level with support for the latest pci express 3.0 technology providing users with up to 32gb/s bandwidth and double the performance of pci-express 2.0, pcie 3.0 will become a must-have feature for users who wish to improve and optimize graphic performance, as well as have the latest technology available to them.
the p8z68-v/gen3 motherboard brings users intel® smart response technology while also delivering the most flexible tuning of the core, graphics and memory.
smart response technology allows users to experience the benefits of both ssd & hdd. the board combines ssd responsiveness with the capacity of hdd. this in turn results in a faster system boot and faster data retrieval!
users can benefit from a free gpu performance upgrade via two simple methods using igpu. the first method is through the on-board gpu boost switch and the second method is via the easily adjustable settings in the friendly ui. users can enhance gpu performance by a massive 34%*.
the asus p8z68-v/gen3 features lucidlogix® virtu, which is specifically designed for the intel® sandy bridge platform's powerful integrated graphics. its gpu virtualization dynamically assigns tasks to the best available graphics resources, providing greater flexibility and efficiency.
exclusive asus features also include, dual intelligent processors 2 which features digi+ vrm providing high system stability and efficiency, precise adjustment under bios &ui and an active cooling micro-processor. epu provides system energy saving and real time power management. tpu delivers a second micro-processor to free cpu resources as well as easy o.c. and an instant performance boost through an on-board switch or the easy o.c. tool, turbov evo.
uefi bios (ez mode) offers users a flexible and simple bios graphical interface and mouse control.
this model is also rich in spec, including quad usb 3.0 & dual sata 6gb/s ports and one intel® lan, allowing users to experience the thrill of faster data transfer rates.
asus unique selling points:
dual intelligent processors 2 with digi+ vrm: industry leading digital 16-phase power design (12-phase for cpu, 4-phase for igpu)
asus epu & epu switch: automatically provides the most appropriate power usage to save power and money.
asus tpu with auto tuning and turbov: providing simple steps to easy overclocking.
gpu boost: upgrade your graphics performance by up to 48%
bt go! (bluetooth): folder sync, bt transfer, shot & send, bt to net, music player, personal manager
bt turbo remote: exclusive smartphone interface supporting iphone, android, windows mobile and symbian systems
memok!: quickly ensures memory boot compatibility with failsafe settings.
ai suite ii: one stop access to all asus features.
ai charger: faster usb charging speed.
anti-surge protection: this special design prevents expensive devices and the motherboard from damage caused by power surges.
asus efi bios(ez mode):the most flexible and easy to use bios.
disk unlocker: allows support for 2.2tb hdd and above.
fanless design: silent heat-sink solution
fan xpert: smart thermal control via fan speed detection
asus q-shield: extra secure i/o shield
crashfree bios 3: restore corrupted bios data from a usb flash disk
ez flash 2: easily update your systems bios firmware.
asus q-slot: easy access expansion slots.
asus q-dimm: easy access dimm slots.
asus q-led (cpu, dram, vga, boot device led):
asus q-connector: easy access front panel connector
key specification:
- form factor: atx form factor, 12”x 9.6” (30.5cm x 24.4cm)
- socket: intel® socket 1155 for 2nd generation core™ i7/core™ i5/core™ i3/pentium®/celeron® processors supports intel® 22 and 32nm cpu
- chipset: intel® z68 express chipset
- memory: 4 x dimm, max. 32gb, ddr3 2200(o.c.)*/2133(o.c.)/1866(o.c.)/1600/1333/1066 mhz, non-ecc, un-buffered memory, dual channel memory architecture
- graphics: integrated graphics processor hdmi/dvi/rgb ports maximum shared memory of 1748 mb
- multi gpu: supports nvidia® quad-gpu sli™ technology/ ati® quad-gpu crossfirex™ and lucidlogix® virtu™ technology
- expansion slots: 2 x pcie 3.0/2.0 x16 (x16 or dual x8), 1 x pcie 2.0 x16 (x4 mode, black), 2 x pcie x1, 2 x pci
- storage 1: intel® z68 chipset : 2 x sata 6gb/s port(s), gray, 4 x sata 3gb/s port(s), blue, supports raid 0, 1, 5, 10 and intel® smart response technology
- storage 2: jmicron® jmb362 controller: 1 x esata 3gb/s port(s), red
- audio: realtek® alc892 8-channel high definition audio codec
- lan: intel® 82579, 1 x gigabit lan controller(s)- intel® lan- dual interconnect between the integrated lan controller and physical layer (phy)
- bluetooth and wifi: bluetooth v2.1+edr, no wifi
- usb 1: asmedia® usb 3.0 controller: 4 x usb 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
- usb 2: intel® z68 chipset: 12 x usb 2.0 port(s) (6 at back panel, black+red, 6 at mid-board)
- manageability: wfm 2.0, dmi 2.0, wol by pme, wor by pme, pxe
- bios: 64 mb flash rom, uefi ami bios, pnp, dmi2.0, wfm2.0, sm bios 2.5, acpi 2.0a, multi-language bios, asus ez flash 2, asus crashfree bios 3, f12 printscreen function
back panel i/o ports:
1 x bluetooth module(s)
1 x dvi
1 x d-sub
1 x hdmi
1 x esata 3gb/s
1 x lan (rj45) port(s)
2 x usb 3.0
6 x usb 2.0
1 x optical s/pdif out
6 x audio jack(s)
internal i/o connectors:
1 x usb 3.0 connector(s) support(s) additional 2 usb 3.0 port(s) (19-pin, moss green)
3 x usb 2.0 connector(s) support(s) additional 6 usb 2.0 port(s)
2 x sata 6gb/s connector(s)
4 x sata 3gb/s connector(s)
2 x cpu fan connector(s) (4 -pin)
2 x chassis fan connector(s) (1 x 4 -pin, 1 x 3 -pin)
2 x power fan connector(s) (3 -pin)
1 x s/pdif out header(s)
1 x 24-pin eatx power connector(s)
1 x 8-pin atx 12v power connector(s)
1 x front panel audio connector(s) (aafp)
1 x system panel(s) (q-connector)
1 x memok! button(s)
1 x tpu switch(es)
1 x epu switch(es)
in the box:
user's manual
asus q-shield
2 x sata 3gb/s cable(s)
2 x sata 6gb/s cable(s)
1 x sli bridge(s)
1 x q-connector(s) (2 in 1)
support dvd
drivers
asus utilities
asus update
anti-virus software (oem version)
was £144.98 inc. vat
only £134.40 inc vat.
order now
gigabyte z68ap-d3 intel z68 (socket 1155) ddr3 motherboard rev 1 @ £78.98 inc vat
was £84.98 inc. vat
only £78.98 inc vat.
order now
asus p8h61-m intel h61 chipset (socket 1155) ddr3 motherboard **b3 revision** @ £47.40 inc vat
the p8h61-m delivers users fantastic graphics performance in an intel® lga1155 package with memory and pci express controllers integrated to support 2-channel ddr3 memory and 16x pci express 2.0 lanes. ddr3 supports data transfer rates of 1333 / 1066 mhz to meet the higher bandwidth requirements of the latest 3d graphics, multimedia and internet applications. the intel® h61(b3) express chipset is the latest single-chipset design to support the new 1155 socket intel® core™ i7 / i5 / i3 2nd generation processors. it provides improved performance by utilising serial point-to-point links, allowing increased bandwidth and stability.
the p8h61-m features a multitude of exclusive asus features. asus epu (energy processing unit) provides total system power management by intelligently moderating power usage in real time saving power and money. asus ai suite ii, this all-in-one software offers diverse and ease to use functions, with no need to switch back and forth between different utilities. ai suite ii allows users to supervise overclocking, energy management, fan speed control, voltage and sensor readings.
anti-surge protection detects over voltage conditions to prevent voltage surges from spreading in real time. fan xpert intelligently allows users to adjust the cpu chassis fan speeds according to differing temperature and climate conditions, offering flexible control of fan speeds to achieve a quiet and cool environment.
asus turbov provides the adrenaline rush of real time oc without exiting or rebooting the os. the asus oc profiles in turbov provide the best oc settings in different scenarios. the p8h61-m uses all high-quality conductive polymer capacitors on-board for durability, improved lifespan and enhanced thermal capacity. gpu boost overclocks the integrated gpu in real time for the best graphics performance with a user friendly ui that facilitates flexible frequency and voltage adjustments.
the bios c.p.r, (cpu parameter recall), feature automatically restores the cpu default settings when the stystem hangs due to an overclocking failure. c.p.r. eliminates the need to open the system chassis and clear the rtc data. users can simply shut down and reboot the system. the on-board 8-channel hd audio (high definition audio) codec enables high-quality 192khz/24-bit audio output. jack detect feature, automatically identifies peripherals and notifies users of any inappropriate connection.
- gpu boost: upgrade your graphics performance by up to 48%
- 100% solid capacitors: provides the motherboard with improved durability, improved lifespan and enhanced thermal capacity.
- protect 3.0: protects the planet, your hardware and you.
- memok!: quickly ensures memory boot compatibility with failsafe settings.
- anti-surge protection: this special design prevents expensive devices and the motherboard from damage caused by power surges.
- epu: automatically provides the most appropriate power usage to save power and money.
- anti-emi: reduces electro magnetic interference by up to 50%
- turbov: providing simple steps to easy overclocking.
- asus efi bios(ez mode):the most flexible and easy to use bios.
- ai suite ii: one stop access to all asus features.
- crashfree bios 3: restore corrupted bios data from a usb flash disk
- my logo 2: easily customize your start up screen.
- ez flash 2: easily update your systems bios firmware.
- fan xpert: smart thermal control via fan speed detection.
key specification
- form factor: matx 9.6 in x 8.0 in (24.4 cm x 20.3 cm)
- socket: lga1155 socket for intel® 2nd generation core™ i7/ core™ i5/ core™ i3 processors
- chipset: intel® h61 express
- graphics interface: 1 x pci express 2.0 x16 slot
- memory: 2x dimm, max. 16gb, ddr3 1333/1066 mhz, non-ecc, un-buffered memory
- audio: alc887 8-channel high definition audio codec
- lan: realtek® 8111e gigabit lan
- storage: 4 x sata 3.0 gb/s ports
- usb: 10 x usb 2.0/1.1 ports (6 ports at mid-board, 4 ports at the back panel)
- 1 x ps/2 combo port (keyboard & mouse)
- 1 x s/pdif out port(optical)
- 1 x hdmi port
- 1 x dvi port
- 1 x d-sub port
- 1 x lan (rj45) port
- 6 x usb 2.0/1.1 ports
- 3 x audio jacks
- 2 x usb connectors support additional 4 usb ports
- 4 x sata 3.0gb/s connectors
- 1 x cpu fan connector
- 1 x chassis fan connector
- 1 x lpt connector
- 1 x front panel audio connector
- 1 x com port
- 1 x s/pdif out header
- 1 x 24-pin atx power connector
- 1 x 4-pin atx 12v power connector
- 1 x system panel connector
in the box
- 2 x serial ata 3.0gb/s cables
- 1 x i/o shield
- 1 x support dvd
- user's manual
- drivers
- asus utilities
- asus update
- anti-virus software (oem version)
was £49.99 inc. vat
only £47.40 inc vat.
order now
epson stylus photo p50 - photo inkjet printer - colour @ £120.00 inc vat
this hi-definition photo printer uses epson claria photographic ink to produce photos that look better, and last longer, than those from the lab. you can print borderless photos up to a4 size, and 10x15 cm photos print in as little as 12 secs.
the powerful software supplied makes it easy to enhance images and remove imperfections such as red-eye. you can also add a personal touch to your discs by printing directly onto suitable cds and dvds. it’s cost-effective too, because with individual inks you only have to replace the colour used.
this product meets the strict energy star® guidelines set by the european commission. epson is a global manufacturer committed to protecting the environment for future generations by offering a range of energy star® products. this is achieved by significantly reducing electricity usage, which saves energy, money and the environment, without compromising quality.
was £129.98 inc. vat
only £120.00 inc vat.
order now
intel core i5-2550k 3.40ghz (sandybridge) socket lga1155 processor - oem @ £167.99 inc vat
intel's new sandybridge based cpu's is a complete new refresh that requires new socket lga1155 mainboards. the new sandybridge k series processors also feature immense overclocking as well. this 2550k edition no longer has the onboard graphics but sports a faster clock speed and has incredible overclocking levels.
- unlocked multiplier
- lithography process: 32 nm
- cores: 4
- threads: 4
- frequency: 3.40 ghz (turbo mode 3.80ghz)
- cache: 6 mb shared l3
- memory controller: dual channel ddr3 800/1066/1333/1600 mhz
- tdp: 95w
- socket: lga1155
- compatible with socket 1156 heatsinks
- 1yr warranty
***overclocking guidelines***
- do not exceed 1.425v core voltage, doing so could limit lifespan of the cpu
- aim to keep temperatures below 70c underload if at all possible
- do not overclock with bclk, again doing so could limit lifespan of the cpu
- recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher than 1.60v could limit lifespan of the cpu
- these recommendations come from ocuk and intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your cpu lifespan is un-affected
- all sandybridge cpu's worldwide should be run at the above or lower voltages, no higher!
was £173.99 inc. vat
only £167.99 inc vat.
order now
intel core i5-2550k 3.40ghz (sandybridge) socket lga1155 processor - retail @ £179.99 inc vat
- cores: 4
- threads: 4
- tdp: 95w
- socket: lga1155
- 3yr warranty
was £184.99 inc. vat
only £179.99 inc vat.
order now
intel core i7-3820 3.60ghz (sandybridge-e) socket lga2011 processor - oem @ £218.39 inc vat
dominate your gaming competition the unleashed and uncompromised intel core i7 series. thanks to the latest ultra-threaded, killer combination of smart features, including intel turbo boost technology and intel hyper-threading technology, the intel core i7 is intel’s most capable and downright devastating pc processor ever.
- core size: 32nm
- socket: lga2011
- quad core
- frequency: 3.60ghz (3.90ghz turbo)
- multiplier: 36x (upto 43x available)
- l2 cache: 4x 256kb
- l3 cache: 10mb
- tdp: 130w
- 1yr warranty
was £224.99 inc. vat
only £218.39 inc vat.
order now
intel core i7-3820 3.60ghz (sandybridge-e) socket lga2011 processor - retail @ £239.99 inc vat
- core size: 32nm
- socket: lga2011
- quad core
- l3 cache: 10mb
- tdp: 130w
- heatsink & fan not included!
- 3yr warranty
was £259.99 inc. vat
only £239.99 inc vat.
order now
intel core i7-3930k 3.20ghz (sandybridge-e) socket lga2011 processor - oem @ £455.99 inc vat
dominate your gaming competition with the unlocked, unleashed and uncompromised intel core i7 k series with unlocked multiplier. thanks to the latest ultra-threaded, killer combination of smart features, including intel turbo boost technology and intel hyper-threading technology, the intel core i7 is intel’s most capable and downright devastating pc processor ever.
- c2 stepping
- core size: 32nm
- socket: lga2011
- six core
- frequency: 3.20ghz (3.80ghz turbo)
- multiplier: 32x (upto 40x available)
- l2 cache: 6x 256kb
- l3 cache: 12mb
- tdp: 130w
- does not include cooler
- 1yr warranty
was £461.99 inc. vat
only £455.99 inc vat.
order now
corsair vengeance 16gb (2x8gb) ddr3 pc3-12800c10 1600mhz dual channel kit (cmz16gx3m2a1600c10) @ £99.98 inc vat
the new 16gb vengeance ddr3 kits operates at 1.5v for compatibility with the new 2nd generation intel® core™ processor family and is guaranteed to operate at 1600mhz. providing 8gb of rigorously-screened dram on a single module allows gamers and performance enthusiasts to build systems with 32gb of high-performance memory.
"vengeance ddr3 memory is the premier choice for reliable, overclockable dram for system builders on a budget," said giovanni sena, director of memory products at corsair. "our kits based on 8gb modules give builders, system integrators, and gaming enthusiasts the power to break the 16gb barrier."
features
- 8gb modules
- each twin module set is tested at 1600mhz
- vengeance heat spreader for styling and performance
- packaged together immediately following system test
- tested together at 1600mhz, vdimm = 1.50v, at latency settings of 10-10-10-27 on intel ddr3-based motherboards.
- spd programmed at: jedec standard 9-9-9-24 values at 1333mhz.
- xmp 10-10-10-27 values at 1600mhz, 1.50v
- 16384 megabytes of ddr3 memory
- two matched 4gb modules
- 100% tested at 1600mhz in intel based motherboards
- supports intel extreme memory profiles (xmp)
- lifetime warranty
- sandybridge compatible
was £131.99 inc. vat
only £99.98 inc vat.
order now
corsair vengeance 8gb (1x8gb) ddr3 pc3-12800c10 1600mhz single channel module (cmz8gx3m1a1600c10) @ £49.98 inc vat
the new 8gb vengeance ddr3 memory operates at 1.5v for compatibility with the new 2nd generation intel® core™ processor family and is guaranteed to operate at 1600mhz. providing 8gb of rigorously-screened dram on a single module allows gamers and performance enthusiasts to build systems with 32gb of high-performance memory.
features
- 8gb module
- each module is tested at 1600mhz
- tested at 1600mhz, vdimm = 1.50v, at latency settings of 10-10-10-27 on intel ddr3-based motherboards.
- 8192 megabytes of ddr3 memory
- lifetime warranty
was £74.99 inc. vat
only £49.98 inc vat.
order now
his hd 7950 3072mb gddr5 pci-express graphics card @ £334.98 inc vat
the world's first 28nm gpu. the revolutionary new gcn architecture. ready for directx 11.1. pci express 3.0. the amd radeon™ hd 7950 is your personal checklist for ground-breaking technology. the next generation of amd eyefinity technology is here, featuring all-new support for stereo 3d, universal bezel compensation and brand new display configurations. face it: the best just got better. armed with the new pci express 3.0 standard, multi-gpu configurations with amd crossfire™ technology are just another way to obliterate the competition with the revolutionary amd radeon™ hd 7950. leave no performance behind. get higher clocks and faster gaming with amd powertune technology on amd radeon™ hd 7950 graphics. fold and mine faster than ever with amd app acceleration powered by the unprecedented 28nm gcn architecture. the market isn't ready for 4k video, but radeon™ is. with full support for 3ghz hdmi 1.4a and displayport 1.2 hbr2, the amd radeon™ hd 7950 is set for quad hd.
- core clock: 800mhz
- memory: 3072mb gddr5
- memory clock: 5000mhz (effective)
- memory interface: 384-bit
- processing cores: 1792
- bus type: pci-express 3.0
- display connectors: 1x dual link dvi, 1x hdmi & 2x mini-displayport
- hdcp capable
- directx 11 support
- opengl 3.2 support
- ati crossfire ready
- ati eyefinity technology
- ati avivo hd
- ati stream technology
- ati hd3d technology
- warranty: 2 years
was £349.99 inc. vat
only £334.98 inc vat.
order now
his hd 6970 iceq turbo 2048mb gddr5 pci-express graphics card with free deus ex pc game @ £269.99 inc vat
the ati radeon hd 6970 uses a new gpu architecture from amd which features dual graphics engines in one chip with 24 simd engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. its core clock speed of 900mhz, together with a dedicated high speed interface to 2gb of gddr5 memory running at 1400mhz (5.6gb/s effective) delivers the highest performance in this series. new tesselation engines bring up to three times the performance of the previous generation, and new enhanced quality aa and filtering modes bring the highest image quality ever achieved.
features:-
- core clock: 900mhz
- memory: 2048mb gddr5
- memory clock: 5600mhz (effective)
- memory bandwidth: 176gb/sec
- processing cores: 1536
- texture units: 96
- rops: 32
- bus type: pci-express 2.1
- display connectors: 1 dual link dvi-i and 1 single link dvi-d, 1 hdmi & 2x mini-displayport
- hdcp capable
- shader model 5.0 support
- opengl 4.0 support
- ati avivo hd
- maximum power consumption: 250w (typical 190w)
- 1x 8pin and 1x 6pin pci-e power connectors required (power adapters included in box for older psu's)
- 500w minimum psu recommended
- warranty: 2 years
- supplied with free deus-ex pc game (subject to availability)
was £279.95 inc. vat
only £269.99 inc vat.
order now
msi hd 6970 oc lightning 2048mb gddr5 pci-express graphics card with free deus ex pc game @ £281.99 inc vat
nonl2br
<img src="http://marketing-uk.msi.com/images/amdlightningstatic.jpg" alt="msi lightning" /><br>
<br>
these cards are specifically designed to handle the extreme overclocking which eager gamers and media outlets around the world have been waiting for. industry-leading power4 architecture and twin frozr iii dual-fan cooling with innovative propeller blade technology brings together a solid power supply with advanced cooling technology. this results in huge boosts to overclocking potential and stability, enabling the air-cooled 6970 lightning to break the 1ghz core clock barrier with ease. the lightning series of graphic cards is designed to offer the ultimate in overclocking capabilities and is the superior choice for overclocking enthusiasts seeking to set new world records! <br>
<br>
<font size="5"><b>key features</b></font><br>
<br>
<img src="http://marketing-uk.msi.com/images/power4.png" width="210" align="left" alt="power4" /><b>industry-leading power4 architecture for overclocking reliability</b><br>
inheriting the impressive power4 architecture from previous lightning cards along with improved components and design in four areas. the pwm module is twice as large as before and provides double the amount of current to the gpu. memory has its own independent power supply using an 8-pin connector for minimum interference to greatly increase overclocking potential. the next-generation proadlizer capacitor increases signal stability by leaps and bounds while coppermos, the industry's best mosfet, provides the gpu with a large and stable power supply. combined, these features provide ordinary users as well as extreme overclocking enthusiasts with a more stable operating environment and the best performance out there. <br>
<br>
<img src="http://marketing-uk.msi.com/images/lightningsplit.png" width="210" align="right" alt="cooling" />
<br>
<b>twin frozr iii and propeller blade technology takes cooling to the next level</b><br>
the all new twin frozr iii cooling design utilizes the innovative propeller blade technology to double the amount of airflow compared to conventional fans. the airflow also covers a large surface to remove heat quickly and effectively, and when you add in twin 9cm pwm fans, superpipe technology, and the form-in-one heatsink, the result is gpu operating temperatures 26°c lower than the reference board when the 6970 lightning are operating under full loads. fan noise is also 11db lower in addition to having much higher overclocking potential.<br>
<br>
<img src="http://marketing-uk.msi.com/images/afterburner.png" align="left" alt="afterburner" /><br>
<b>overclocking potential unleashed with gpu/memory/pll triple overvoltage</b><br>
the msi 6970 lightning graphic cards come with the latest version of msi's exclusive afterburner v2.1.0 overclocking utility. the utility not only adjusts gpu and memory clock but also manage the gpu/memory/pll(vddci) voltages to maximize overclocking potential. thanks to triple overvoltage, the overclocking potential of 6970 lightning is much higher than the reference board and offers enthusiasts ultimate performance.<br>
<br>
<br>
<br>
<b>king of extreme overclocking</b><br>
for hardware enthusiasts, the msi 6970 lightning graphic cards come with exclusive extreme overclocking features. apart from v-check points and v-switch for monitoring and adjusting the gpu/memory/pll(vddci) voltages in real time, dual bios switches help to effectively prevent potential problems stemming from liquid nitrogen cooling. pwm clock tuner also helps to increase overclocking potential. all of these come together to make the 6970 lightning the ultimate graphic cards for extreme overclocking<br>
<br>
<img src="http://marketing-uk.msi.com/images/mcii.png" align="right" alt="military class" /><b>carefully selected materials</b><br>
the msi 6970 lightning graphic cards use top-quality military class ii components including all solid cap for overclocking and full-speed operation, sfc for 10% higher efficiency, and 30% increase in maximum current, as well as hi-c cap with tantalum core which boasts 8 times the lifetime of conventional solid capacitors. these high-quality components not only increase the graphic cards' overall service life but also enhance gpu stability.
<br>
<br>
<img src="http://marketing-uk.msi.com/images/musthave.png" alt="kit guru gold" /><img src="http://www.vortez.co.uk/contentteller.php?ct=content&action=file&id=21" width="200" alt="vortez gold" />
<br>
<br>
<font size="5"><b>specifications</b></font><br>
<br>
<b>stream processors</b> - 1536 units<br>
<b>core clock</b> - 940 mhz<br>
<b>memory clock</b> - 5500 mhz<br>
<b>memory size</b> - 2048mb gddr5<br>
<b>memory bus</b> - 256 bits<br>
<b>output</b> - mini displayport*2 / hdmi / dvi*2<br>
<b>tdp</b> - 269 w<br>
<b>card dimension</b> - 310x127x40mm<br>
<b>form factor</b> - atx<br>
<b>directx 11</b> - y<br>
<b>opengl 4.0</b> - y<br>
<b>crossfirex</b> - y<br>
<b>eyefinity</b> - y<br>
<b>avivo hd</b> - y<br>
<b>powerplay</b> - y<br>
<b>hdcp</b> - y<br>
<br>
- world’s first 18 phase pwm on hd 6970.<br>
- independent memory power support. <br>
- copper mos with 2x high current capacity. <br>
- proadlizer*4 to optimized power supply. <br>
- twin frozr iii thermal design with 26c cooler & 11db quieter. <br>
- propeller blade technology for 20% more airflow. <br>
- dual 9cm fans with dual 8mm superpipes for best heat dissipation. <br>
- form-in-one heatsink covers memory and modules to dissipate heat efficiency.<br>
- support voltage adjustment of gpu/memory/vddci<br>
- military class ii components for longer product lifespan. <br>
- lpl (lightning power layer) for the stable power supply.<br>
- usage of the micro/dip switches on rear of card voids warranty - for extreme/expert overclockers only!<br>
<br>
<b>- now with three year warranty</b><br>
<img src="http://emm.msi.com/admin/temp/newsletters/1226/3yearfinal.jpg" width="250" alt="3 year warranty" /><br>
was £299.99 inc. vat
only £281.99 inc vat.
order now
sapphire hd 6950 "dual fan edition" 2048mb gddr5 pci-express graphics card with free deus ex pc game @ £209.99 inc vat
the sapphire hd 6950 dirt3 special edition is a new sapphire original model with a special cooler using a new dual fan configuration. based on the latest high end amd gpu architecture, it boasts true dx 11 capability and the powerful configuration of 1408 stream processors and 88 texture processing units. with its clock speed of 800mhz for the core and 2gb of the latest gddr5 memory running at 1250mhz (5 gb/sec effective), this model speeds through even the most demanding applications for a smooth and detail packed experience.
a dual bios feature allows enthusiasts to experiment with alternative bios settings and performance can be further enhanced with the sapphire overclocking tool, trixx, available as a free download from http://www.sapphiretech.com/ssc/trixx/
features:-
- memory bandwidth: ??gb/sec
- processing cores: 1408
- texture units: 88
- rops: 32
- display connectors: 1 x dual-link dvi-i, 1 x single-link dvi-d, 1 x hdmi, 1 x displayport
- hdcp capable
- ati avivo hd
- 2x 6pin pci-e power connectors required (power adapters provided)
- 450w minimum psu recommended
- warranty: 2 years
was £223.99 inc. vat
only £209.99 inc vat.
order now
xfx hd 6970 2048mb gddr5 pci-express graphics card with free battlefield 3 pc game @ £257.99 inc vat
the ati radeon hd 6970 uses a new gpu architecture from amd which features dual graphics engines in one chip with 24 simd engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. its core clock speed of 880mhz, together with a dedicated high speed interface to 2gb of gddr5 memory running at 1375mhz (5.5gb/s effective) delivers the highest performance in this series. new tessellation engines bring up to three times the performance of the previous generation, and new enhanced quality aa and filtering modes bring the highest image quality ever achieved.
features:-
- core clock: 880mhz
- memory clock: 5500mhz (effective)
- memory interface: 256-bit
- display connectors: 1x dual-link dvi, 1x single-link dvi, 1x hdmi & 2x mini-displayport
- hdcp capable
- opengl 4.1 support
- ati avivo hd
- warranty: 2 years
- bf3 game
was £269.99 inc. vat
only £257.99 inc vat.
order now
ocuk hd 6850 oc 1024mb gddr5 pci-express graphics card @ £99.98 inc vat
prepare to experience a riveting high-definition gaming experience with the ati radeon hd 6800 series graphics processors. expand your visual real estate across up to three displays and get lost in the action with revolutionary ati eyefinity technology. using ati stream technology, accelerate even the most demanding applications and do more than ever with your pc. the first to deliver full support for microsoft directx 11, these gpus enable rich, realistic visuals and explosive hd gaming performance so you can dominate the competition.
- core clock: 790mhz
- memory: 1024mb gddr5
- memory clock: 4000mhz (effective)
- processing cores: 960
- display connectors: 1 dual link dvi-i and 1 single link dvi-d, 1 hdmi & 1 displayport
- hdcp capable
- ati avivo hd
- 2x 6-pin pci-e power connectors required
- warranty: 3 years
was £103.99 inc. vat
order now
asus hd 6670 silent edition 1024mb gddr3 pci-express graphics card @ £64.79 inc vat
packed with the latest gpu technologies, the radeon™ hd 6670 graphics processors offer advanced video and display features, eyefinity multi-display technology, as well as amd’s 2nd generation support for directx® 11 to give you the ultimate in “visual immersion” for your pc.
the flattened copper heat-pipe contacts gpu directly for 0db cooling experience. super alloy power technology uses special alloy formula in critical power delivery components for a 15% performance boost, 35°c cooler operation and 2.5 times longer lifespan. intelligent system monitoring for efficient overclocking with an intuitive slide bar. real-time overclocking, benchmarking and video capturing in any pc game!
features:-
- effective and quiet directcu silent 0db thermal design
- pump up graphics performance with super alloy power that delivers 15% performance boost, 2.5 longer lifespan, 35c cooler operation
- memory: 1024mb gddr3
- memory clock: 1800mhz (effective)
- memory interface: 128-bit
- processing cores: 480
- display connectors: 1 dual-link dvi-i, 1 hdmi
- hdcp capable
- ati avivo hd
- warranty: 3 years
was £69.95 inc. vat
only £64.79 inc vat.
order now
sapphire hd 6570 ultimate edition 1024mb gddr3 pci-express silent graphics card @ £53.99 inc vat
the hd 6570 ultimate from sapphire features a single slot low profile card with silent heatpipe cooler. with its 480 stream processors, engine clocks of 650mhz and 1gb of ddr3 memory clocked at 900mhz (1.8ghz effective) this is an ideal solution for htpcs or general purpose pcs where silent operation is an advantage. outputs are hdmi, dvi-d and vga.
the amd radeon™ hd 6570 graphics processors offer advanced video and display features, as well as 2nd generation support for directx 11 to offer the ultimate in versatility for the everyday computing desktop.
features
- fanless silent design
- core clock: 650mhz
- display connectors: 1x dual-link dvi-i, 1x hdmi, 1x d-sub
- hdcp capable
- ati avivo hd
- dimension 169(l) x 19(w)x94(h) mm size.
- warranty: 2 years
was £64.99 inc. vat
only £53.99 inc vat.
order now
ocuk geforce gtx 580 3072mb gddr5 pci-express graphics card with free mafia 2 pc game @ £407.99 inc vat
the world's fastest gpu has arrived with the nvidia geforce gtx 580. experience blockbuster games like call of duty®: black ops and tom clancy's h.a.w.x® 2 in their full glory with everything cranked to the max. not only does the nvidia geforce gtx 580 rip through the latest games, it also runs quieter than the previous generation. and as you have come to expect from the geforce gtx gpu, the gtx 580 packs support for all the premium gtx gaming technologies such as nvidia surround, 3d vision, physx and sli. with all these features and more, it is easy to see how the nvidia geforce gtx 580 obliterates the competition.
features:-
- core clock: 783mhz (fermi gf110)
- 64 tmus (gtx 480 had 60 tmus)
- uprated quiet cooling solution
- memory clock: 4020mhz (effective)
- processing cores: 512
- shader clock: 1566mhz
- bus type: pci-express 2.0
- display connectors: 2x dual-link dvi-i & 1x mini-hdmi 1.4a (includes hdmi & vga adapters)
- sli ready (upto 3-way sli supported)
- hdcp capable
- physx enabled
- cuda enabled
- 3d vision enabled
- nvidia surround enabled
- lower power consumption compared to gtx 480, only 244 watts
- warranty: 3 years
- supplied with free mafia 2 pc game download code (subject to availability)
was £419.99 inc. vat
only £407.99 inc vat.
order now
zotac geforce gtx 570 amp! edition 1280mb gddr5 pci-express graphics card with free mafia 2 pc game @ £269.99 inc vat
amplify your gaming experience by adding stunning visual realism and clarity with the zotac® geforce® gtx 570 amp! edition graphics card powered by nvidia® fermi architecture. the zotac® geforce® gtx 570 amp! edition graphics card delivers a phenomenal gaming experience with microsoft® directx® 11 technology for unprecedented immersion.
features:-
- core clock: 780mhz
- stream processors: 480
- shader clock: 1560mhz
- memory: 1280mb gddr5
- interface: pci express 2.0 x16 (compatible with 1.1)
- display connectors: 2x dual-link dvi-i & 1x hdmi 1.4a
- includes dvi-to-vga adapter
- sli ready (3-way sli supported)
- hdcp ready
- opengl 4.2 support
- nvidia® 3d vision surround ready
- nvidia® physx technology
- nvidia® cuda technology
- game bundle: assassin's creed™ brotherhood
- warranty: 5 years extended
order now
asus geforce gtx 560ti directcu ii top 1024mb gddr5 pci-express graphics card **supplied with battlefield 3 pc game** @ £185.99 inc vat
asus is proud to introduce the new asus engtx560 ti dcii top to all our users. using the unique asus directcu ii cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the gpu core to speed up heat dissipation for a 20%* cooler performance compared to reference. keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
the card also boasts super alloy power which can create a 15% performance increase, 2.5 longer product life span and a 35?c cooler operation. in addition to this, the engine clock runs at a pre overclocked 900mhz, allowing users to enjoy high speed and an unprecedented gaming experience. super alloy power is a special blend of elements formed using an asus exclusive formula, under extreme pressure and temperatures. the metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
super hybrid engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. this in turn can provide up to 15% improved performance. furthermore the gtx560 offers a sap cap; this is back-to-back with the gpu to provide most efficient power supply for increased stable overclocking of up to 28%.
with exclusive voltage tweak technology also being a key feature of this product, the engtx560 ti dcii top/2di/1gd5 covers users for every possible over-clocking and over-volting scenario. with the complete package offered by this card users can easily boost their performance by up to 50%!
features:-
- memory clock: 4200mhz (effective)
- processing cores: 384
- shader clock: 1800mhz
- display connectors: 2x dual-link dvi-i & 1x hdmi 1.4a (includes hdmi & vga adapters)
- sli ready
- hdcp capable
- physx enabled
- cuda enabled
- 3d vision enabled
- warranty: 3 years
- supplied with battlefield 3 full pc game download voucher!
was £194.99 inc. vat
only £185.99 inc vat.
order now
evga geforce gtx 560ti dual shock superclocked 1024mb gddr5 pci-express graphics card (01g-p3-1567-kr) @ £179.99 inc vat
discover the incredibly detailed world of directx 11 with the egva geforce gtx 560ti graphics card. with up to 3x the performance of previous generations and loaded with the latest gaming technologies with evga geforce gtx 560 ti ds delivers polished performance.
- core clock: 900mhz;
- memory clock: 4212mhz;
- shader clock: 1800mhz;
- cuda cores:384;
- bus type: pci-e 2.0;
- memory detail: 1024mb gddr5;
- memory bit width: 256 bit;
- memory speed: 0.4ns;
- memory bandwidth: 134.8gb/sec;
- texture fill rate: 57.6 gt/s;
- warranty: 3 year warranty (extended to 10 years if card is registered with evga within 30 days of purchase);
was £193.99 inc. vat
order now
ocuk geforce gtx 560ti 2048mb gddr5 pci-express graphics card @ £199.99 inc vat
with explosive performance and an innovative thermal design, nvidia® geforce® gtx 560 rips through the latest games like world of warcraft®: cataclysm, call of duty: black ops, and tom clancy's h.a.w.x.® 2 with quiet operation. as you've come to expect from a geforce gtx gpu, gtx 560 packs support for all the premium gtx gaming technologies such as directx 11, nvidia® surround, 3d vision™, physx®, and sli®. geforce gtx 560ti - arm yourself for battle.
with 2x memory size, palit geforce® gtx 560 ti 2gb support better performance at maximum resolution monitor while gpu works alongside the cpu to drive fantastic graphics performance. you can enjoy the extreme performance while playing the latest dx10/dx11 pc games under hd large screen with palit geforce® gtx 560 ti 2gb.
features:-
- core clock: 822mhz
- memory clock: 4008mhz (effective)
- shader clock: 1645mhz
- sli ready
- hdcp capable
- physx enabled
- cuda enabled
- 3d vision enabled
- warranty: 2 years
- upto 220% faster than 1gb version in bf3: http://forums.overclockers.co.uk/showthread.php?t=18344290
was £215.99 inc. vat
only £199.99 inc vat.
order now
lg ch10ls28 bd-rom 10x bluray rom / dvdrw sata-ii optical drive - black (retail) @ £47.99 inc vat
lg internal, bare with software, super multi dvd rewriter, blu-ray reader with serial ata.
- capable of reading and writing all current file formats
- lightscribe labelling technology
- compatible with windows xp, vista & 7
- 4mb buffer
- 16x dvd write speed
was £59.99 inc. vat
only £47.99 inc vat.
order now
lg bh10ls38 10x bluray-rw / 16 x dvd±rw lightscribe drive - black (retail) @ £67.19 inc vat
read and write blu-ray discs at 10x with the bh10ls38 blu-ray rewriter that allows you record files, photos, or business documents onto a single dual layer bd-r blu-ray disc. play hd content from bd video discs or record up to nine hours of high definition video. sata interface technology allows for easier integration and ultimately faster performance while lightscribe gives you the added feature of etching customized labels onto a special coated lightscribe discs (sold separately). get into the blu with the bh10ls38 by lg.
write speeds
- bd-r: 10x
- bd-re: 2x
- dvd-r: 16x
- dvd-r dl: 8x
- dvd-rw: 6x
- dvd-ram: 12x
- dvd+r: 16x
- dvd+r dl: 8x
- dvd+rw: 8x
- cd-r: 48x
- cd-rw: 24x
read speeds
- bd-rom: 10x
- bd-r: 6x
- bd-r: 6x
- bd-re: 8x
- dvd-rom:16x
- dvd-r: 12x
- dvd-rw: 10x
- dvd+r: 12x
- dvd+rw: 10x
- dvd-ram: 5x
- dvd-video: 8x
- cd-r/rw/rom: 40x
- cd-da: 40x
- 80 mm cd: 16x
was £79.98 inc. vat
only £67.19 inc vat.
order now
lg bh10ls38 10x bluray-rw / 16 x dvd±rw lightscribe drive - black (oem) @ £62.39 inc vat
read and write blu-ray discs at 10x with the bh10ls38 blu-ray rewriter that allows you record files, photos, or business documents onto a single dual layer bd-r blu-ray disc. play hd content from bd video discs or record up to nine hours of high definition video. sata interface technology allows for easier integration and ultimately faster performance while lightscribe gives you the added feature of etching customized labels onto a special coated lightscribe discs. get into the blu with the bh10ls38 by lg.
write speeds
- bd-r: 10x
- bd-re: 2x
- dvd-r: 16x
- dvd-r dl: 8x
- dvd-rw: 6x
- dvd-ram: 12x
- dvd+r: 16x
- dvd+r dl: 8x
- dvd+rw: 8x
- cd-r: 48x
- cd-rw: 24x
read speeds
- bd-rom: 10x
- bd-r: 6x
- bd-r: 6x
- bd-re: 8x
- dvd-rom:16x
- dvd-r: 12x
- dvd-rw: 10x
- dvd+r: 12x
- dvd+rw: 10x
- dvd-ram: 5x
- dvd-video: 8x
- cd-r/rw/rom: 40x
- cd-da: 40x
- 80 mm cd: 16x
was £69.98 inc. vat
only £62.39 inc vat.
order now
ocuk 22x dvd±rw sata rewriter (black) - oem @ £14.39 inc vat
these great value drives deliver reliable reading and writing time after time.
write speed
- dvd-r: 22x
- dvd-r: 22x
- dvd-r dl: 12x
- dvd+r dl: 16x
- dvd+rw: 8x
- dvd-rw: 6x
- dvd-ram: 12x
- cd-r:48x
- cd-rw: 4x
read speed
- dvd-r: 16x
- dvd+r: 16x
- dvd-r dl: 12x
- dvd+r dl: 12x
- dvd-rw: 12x
- dvd+rw: 12x
- dvd-ram: 12x
- cd-r: 40x
- cd-rw: 40x
was £17.99 inc. vat
only £14.39 inc vat.
order now
samsung sh-s222bb/bebe 22x dvd±rw sata rewriter (black) - oem @ £15.59 inc vat
the sh-s222 drive offers a powerful over-speed performance feature that enables consumers to burn data at high speeds - even on low speed media. with over-speed recording, users can write at 22x speeds on 16x media and 12x speeds on 8x media. as lower speed media is more cost-effective, users can save money while burning discs at faster speeds.
the sh-s222 drive provides blazing recording speeds across a gamut of different data media types including 22x dvd±r recording, 12x dvd-ram recording, 16x dvd+r dual layer recording, 12x dvd-r dual layer recording, 8x dvd+rw recording and 6x dvd-rw recording. it enables consumers to burn 4.7gb on a dvd±r disc in approximately 4 minutes and 26 seconds, a 6 percent increase in speed compared to a 20x dvd writer. it also takes less than 12 minutes to burn 4.7gb in dvd-ram format, which is a 30 percent increase in speed over a 20x dvd drive.
samsung's sh-s222 drive supports sata interface, the dominant interface for pcs.
as with samsung's complete writemaster optical disc drive lineup, the sh-s222 features specific technology that ensures best-of-breed performance including sat1 (speed adjustment technology), tac2 (tilt actuator compensation) and double opc3 (optimum power control). buffer under run free technology4 supports stable writing under high speed, and magic speed5 and abs (automatic ball balancing system) 6 technologies reduce vibration and noise. the sh-s222 is also eco-friendly designed and is rohs compliant.
write speed
- dvd-r: 22x
- dvd-r: 22x
- dvd-r dl: 12x
- dvd+r dl: 16x
- dvd+rw: 8x
- dvd-rw: 6x
- dvd-ram: 12x
- cd-r:48x
- cd-rw: 4x
read speed
- dvd-r: 16x
- dvd+r: 16x
- dvd-r dl: 12x
- dvd+r dl: 12x
- dvd-rw: 12x
- dvd+rw: 12x
- dvd-ram: 12x
- cd-r: 40x
- cd-rw: 40x
was £18.98 inc. vat
only £15.59 inc vat.
order now
lg e1951s 18.5" widescreen led monitor - glossy black @ £71.99 inc vat
clear contrast of light and colour enables display of subtle differences. even now can be observed blacks, is considered the most difficult to visualize the before. intelligent led technology saves energy and lg monitors provides clear and vivid images
specification:-
- screen dimensions: 18.5in
- screen type: led tn 16.7 million colours
- aspect ratio: 16:9
- hd support: yes
- resolution (native): 1366 x 768 pixels
- brightness: 250cd/m2
- view angle: 170° (horizontal - max) x 160° (vertical - max)
- contrast ratio: 5,000,000:1 (dynamic)
- response time: 5ms
- anti-glare / anti-static: anti-glare, 3h
- vga in: 1 x 15-pin d-sub
- plug and play: yes
- voltage/frequency: 100 to 240vac
- power consumption: 17w (max) / 0.5w (standby)
- case colour: black
- dimensions: 44.94cm (w) x 3.35cm (d) x 27.90cm (h) - weight 1.60kg
- 3yr warranty
was £76.99 inc. vat
only £71.99 inc vat.
order now
benq g2222hdl 21.5" widescreen led monitor - black @ £98.39 inc vat
the benq led monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. the g2222hdl provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. it offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. with a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- led backlit
- screen size: 22" widescreen
- resolution: 1920x1080
- contrast ratio: 5000000:1
- brightness: 250cd/m²
- viewing angles (h/v): 170°/160°
- colours: 16.7 million
- inputs: 1x analogue & 1x dvi-d
- vesa compliant
- dimensions: 504.6mm x 392.9mm x 175.0mm
- weight: 3.8kg
- warranty: 2 years on-site
only £98.39 inc vat.
order now
ocuk e2250swda 22" widescreen led monitor - black @ £83.99 inc vat
the ocuk 22" monitor has an industry leading ultra-fast 5ms response time making it perfect for blur-free video and gaming. with it's 20,000,000:1 contrast ratio and digital connectivity there is no other led that can match the combination of value and performance.
features
- screen size: 21.6" widescreen
- contrast ratio: 20,000,000:1
- multimedia speakers
- warranty: 3 years on-site
was £89.99 inc. vat
only £83.99 inc vat.
order now
lg d2342p 23" passive 3d widescreen lcd monitor - black with assassins creed pc game @ £161.99 inc vat
redefine standards with the lg d42p, a full hd led wall mountable 3d monitor, with a stylish slim design created for a new level of experience. using its 3d player you can transform photos, home
videos or even movies, from 2d to 3d at the touch of a button. the d42p revolutionises the way you watch home content; giving you the power to watch 3d at will.
get ready for the most cinema 3d entertainment you're ever experienced - in the comfort of your home. forget the heavy, uncomfortable glasses and the dizzying picture quality of conventional 3d technology. you can now enjoy what 3d was meant to be, just like at the movies. the lg cinema 3d monitor, the standard in 3-dimensional excellence!
features:-
- screen size: 23" widescreen
- fpr 3d glasses included
- inputs: 1x dvi-d & 1x hdmi
- vesa compliant
was £167.99 inc. vat
only £161.99 inc vat.
order now
asus vh242h 24" widescreen lcd multimedia monitor - black @ £137.99 inc vat
23.6” 16:9 widescreen with 1920×1080 resolution enables borderless full hd 1080p full-screen video display. embedded hdmi simplifies cabling and provides pristine and stunning clarity multimedia experience together with pc, game consoles, blu-ray disc players, etc. built-in hidden stereo speakers and spdif audio output enable audio enjoyment together with true-to-life full hd visual.
ascr (asus smart contrast ratio) technology automatically adjusts the luminance of the backlight for better displays according to the image contents, and improves the contrast ratio to 20000:1 – resulting in more realistic depictions of night scenes during games or movies.
aspect control function allows users to select a preferred display mode among full and 4:3 for true-to-life full hd 1080p gaming or movie watching without any data loss or image distortion.
splendid™ video intelligence technology is built upon a color engine that automatically analyzes and determines the nature of the user’s current task, thereafter adjusting the display’s parameters accordingly to ensure the best possible color and image fidelity.
with the five preset modes (standard, game, scenery, night view and theater) of splendid™ video intelligence technology, you will enjoy optimized colors for various multimedia entertainment scenarios.
features:-
- tft-lcd panel panel size: 23.6“ wide screen
- true resolution: 1920x1080
- pixel pitch: 0.272mm
- brightness(max): 300 cd/?
- contrast ratio (max.): 20000 :1 (ascr)
- display color: 16.7m
- viewing angle (cr?10): 170°(h)/160°(v)
- response time: 5 ms
- video features splendid video intelligence technology
- splendid video preset modes (5 modes)
- skin-tone selection (3 mode)
- hdcp support
- color temperature selection(5 modes)
- audio features stereo speakers 2wx2 stereo rms
- convenient hotkey splendid video preset mode selection
- auto. adjustment
- brightness adjustment
- volume adjustment
- input selection
- input / output pc input: dvi-d/d-sub
- pc audio input: 3.5mm mini-jack
- video input: hdmi
- av audio input: hdmi
- audio output: spdif
- earphone jack: 3.5mm mini-jack
- signal frequency analog signal frequency: 30 ~ 83 khz(h)/50 ~ 75 hz(v)
- digital signal frequency: 30 ~ 83 khz(h)/50 ~ 75 hz(v)
- power consumption power consumption < 55 w
- power saving mode < 2 w
- mechanical design chassis colors: black
- tilt: +20°~ -5°
- vesa wall mounting: 100x100mm
- security kensington lock
- dimension (wxhxd mm) phys.dimension(wxhxd): 562mm x 416mm x 220mm
- box dimension(wxhxd): 638mm x 171mm x 491mm
- weight net weight (esti.): 5.8 kg
- gross weight (esti.): 8.2 kg
- accessory dvi cable
- vga cable
- audio cable
- power cord
- quick start guide
- support cd
- warranty card
- regulation approval energy star®, ul/cul, cb, ce, fcc, ccc, bsmi, gost-r, c-tick, vcci, psb, j-moss, rohs, weee, whql
was £149.99 inc. vat
only £137.99 inc vat.
order now
benq g2420hdbl 24" widescreen led monitor - black @ £125.99 inc vat
the benq led monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. the g2420hdbl provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. it offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. with a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- led backlit
- screen size: 24" widescreen
- vesa compliant
- dimensions: 570.0mm x 412.6mm x 183.9mm
- weight: 4.4kg
was £139.99 inc. vat
only £125.99 inc vat.
order now
benq xl2410t 24" true 120hz 3d widescreen led monitor - black @ £239.99 inc vat
benq, proudly announced the release of their 23.6” (16:9 aspect ratio) led gaming monitor xl2410t. benq understands that to lead and become a true and professional gaming monitor provider, they have to understand the mindset and needs of gamers. in order to achieve this goal, benq co-worked with zowie, a professional gaming gear manufacturer. benq have zowie’s gamer teams join in during the product development and testing stages. with their assistance, xl2410t can truly be a professional led gaming monitor – with a set of gaming display modes which includes the fps mode (first person shooting), co-developed by two legendary counter-strike players – emil “heaton” christensen and abdisamad “spawn” mohamed.
every serious gamer know that lag will cause you to lose a game; xl2410t is made to have a quick response to action, hardware lag will no longer be the cause for your headshots. xl2410t has a fast refresh rate of 120hz for higher precision; a low input lag so the shots made is more in sync with the visual on-screen; a quick 2ms gtg (overdrive) meaning users can see the edge of the enemies clearly and without motion blur, and dynamic contrast ratio of 10,000,000:1 for detailed images and clarity in both darkened and brightened situations, this complemented with benq’s gaming tuning technology becomes a huge advantage for gamers.
xl2410t has a smart design, for one purpose – to win. the monitor has two hotkeys available; the first changes the display mode: full; aspect; overscan; 1:1; 17”; 19”; 19” widescreen and 22” widescreen. whereas the second hotkey is smart scaling, which lets the users adjust picture size in original input to the screen’s limit. together with display mode function, users can play in the resolution size they are used to with their previous monitor, or adjust their screen size to what their teammates are using for easier communication and reference. from benq’s gaming display modes options, users can choose from fps mode, made possible by co-working with the gaming heroes -heaton and spawn as the best setting for personal shooting games, or from the two user game modes for more dedicated and personalized settings.
for extreme entertainment, xl2410t is the led monitor to go for. 3d-ready (nvidia 3d vision certified); picture by picture (pbp); connectivity values (d-sub; dvi-d-dl, hdmi) and height adjustment feature are offered for users’ enjoyment and comfort. picture by picture (pbp) is a feature that enables users to show two programs side-by-side on the screen. feel like camping once in a while for fun? watch a movie while you do it!
- led backlit
- screen size: 23.6" widescreen
- contrast ratio: 10000000:1
- brightness: 300cd/m²
- response time: 2ms
- inputs: 1x analogue, 1x dvi-d & 1x hdmi
- vesa compliant
- weight: 6.0kg
- height adjustable stand / swivel 45/45 left/right
order now
dell ultrasharp u2412m 24" widescreen led monitor - midnight grey @ £239.99 inc vat
enjoy widescreen performance, any way you want it. with a 24" 16:10 panel, ips technology and led backlight, the u2412m provides a brilliant view, plus amazing adjustability to suit any style. powerful:
- experience ips technology, featuring a wide viewing angle with high-quality color representation for a peerless viewing experience.
- flexible: pick the view that works best for you with an almost unlimited range of tilt, swivel, pivot and height adjustments.
- customizable: change your energy usage settings, text brightness and color temperature with the touch of a button to help conserve energy with this eco-designed arsenic-free and mercury-free panel.
whether for work or for play, the dell ultrasharptm u2412m can deliver an unmatched viewing experience.
- clearly outstanding: watch your graphics come to life on a vast 24" (61cm) led-backlit screen featuring a crystal-clear 1920x1200 resolution on a 16:10 widescreen aspect ratio so you can’t lose screen area just because your customized applications support a different resolution.
- contrasting view: get ready for blur-free viewing with 2 million:1 (typical) high dynamic contrast ratio and 8ms with overdrive gray-to-gray (typical) response time that helps ensure crisp, sharp and ghost-free images.
- colorful character: enjoy an amazing range of rich, dramatic and accurate colors, thanks to ips technology designed to give you color consistency across a broad viewing angle and a wide color gamut at 82% (typical).
- premium panel guarantee: 100% replacement of dell ultrasharp series monitors sold if any bright pixel is found, valid within the warranty1 period.
specification:-
- 24" (60.96 cm) viewable area
- widescreen (16:10)
- panel type, surface: ips (in-plane switching), anti glare with hard coat 3h
- 1920 x 1200 at 60 hz
- 1000 : 1 (typical)
- 2,000,000:1 (dynamic)
- 300 cd/m2 (typical)
- 8ms (gray to gray) typical
- 178º / 178º
- 16.7 million colors
- color gamut: 82% (cie 1976)
- 0.27 mm
- 1x digital visual interface connectors (dvi-d) with hdcp
- 1x displayport(dp)
- 1x video graphics array (vga)
- 1x usb 2.0 upstream port
- 4x usb 2.0 downstream ports
- dc power connector for dell soundbar
- height-adjustable stand, tilt , swivel , pivot and built in cable-management
- flat panel mount interface
- vesa mount
- warranty: 3 years on-site (dell premium guarantee - you will receive a replacement ultrasharp monitor should even one bright defective pixel appear on the screen)
was £249.95 inc. vat
order now
ocuk 2436vwa 24" widescreen lcd monitor - black @ £119.99 inc vat
the ocuk 24" monitor has an industry leading ultra-fast 5ms response time making it perfect for blur-free video and gaming. with it's 60,000:1 contrast ratio and digital connectivity there is no other lcd that can match the combination of value and performance.
features
- contrast ratio: 60,000:1
- colors: 16.7 m
- hdcp compatible: yes
- usb: 1up / 1down
- vesa 100x100mm
was £124.99 inc. vat
only £119.99 inc vat.
order now
aoc e2795vh 27" widescreen led monitor - black @ £185.99 inc vat
no compromises: the e2795vh is perfect for office and action. this full hd large-screen monitor with integrated speakers not only looks fantastic. the generous 16:9 display area offers ample space for complex charts, double-page spreads, image editing, games, videos or movies. high contrast and brightness values in combination with wide viewing angles and a fast response time provide an excellent image quality without blurring from almost every perspective. thanks to dvi-d and hdmi inputs (with hdcp) high-resolution content from numerous video sources is displayed flawlessly. with electricity-saving led backlights and a mercury-free manufacturing this flatscreen is also easy on the environment.
features:-
- screen size: 27" widescreen
- contrast ratio typical 1.200:1
- pixel / dot / pitch 0.3114 (h) x 0.3114 (v)
- display area 597.6 (h) x 336.15 (v)
- special features: dcb,e-saver,i-menu,kensington security lock,screen+,srs,usb,wide view angle
- vesa compliant
was £199.99 inc. vat
order now
benq g2750 27" widescreen led monitor - black @ £179.99 inc vat
an enjoyable addition to your everyday home or work life, the g2750 gives you crisp and accurate viewing at all times. the g2750 comes with a dynamic contrast ratio of 50000:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games. the g2750 supports the full hd 1080p with 16:9 aspect ratio - allowing the subtlest details to stand out with richer, more realistic colors, making your viewing experience even more absorbing. experience the truest colors of the world with the benq senseye® human vision technology. with the help of its six proprietary calibration techniques, senseye® 3 delivers only the best viewing quality in each of its six pre-set viewing modes –standard, movie, game, photo, srgb, and eco – with the eco mode especially designed to save power and money. the g2750 has passed windows® 7 certification and are fully compatible with windows® 7 color systems. plug in the g2750 to your computer, and windows 7 will recognize it instantly, making setup and connection effortless.
- screen size 27"w
- resolution (max.) 1920 x 1080
- pixel pitch 0.276 mm
- brightness 300 cd/m2
- contrast ratio 1200:1
- dcr:50,000:1
- response time (tr/tf) 5 ms
- display area 597.6 x 336.15 mm
- display color 16.7 million
- viewing angle (l/r;u/d) (cr>=10) 170 / 160
- terminals d-sub / dvi-d
- horizontal frequency (max) khz 30 ~ 83
- vertical frequency (max)hz 50 ~ 76
- video bandwidth (mhz) 205
- colour temperature reddish / normal / bluish / user mode
- power consumption 52w (max)
- auto switching power supply built-in
- features senseye® human vision technology (plus senseye 3)
- hdcp support
- osd language: 17 languages
- windows 7® compatible
- k locker: yes
- adjustments tilt (down / up) -5 / 15
- dimensions (hxwxd) 488.5 x 654.4 x 191.2 mm
- weight net weight: 6.4 kg.
- gross weight: 8.12 kg.
- accessories (standard) vga
- product colour glossy black
- vista certification premium
- vesa wall mounting 100 x 100 mm
- 2yr warranty
was £191.99 inc. vat
order now
dell ultrasharp u2711 27" widescreen lcd monitor - midnight grey @ £527.99 inc vat
with its amazing colour accuracy and versatile connectivity, the high-performance dell u2711 monitor delivers stunning detail, depth and responsiveness. premiercolour technology allows the dell u2711 monitor to deliver reliable, true-to-life colour without the need for extensive calibration. 12-bit internal processing enables 1.07 billon colours and helps distinguish very low grayscale tones to deliver greater level of details in dark areas. factory-tuned adobe rgb and srgb modes minimize the need for further colour calibration; each monitor arrives with a certified colour-calibration factory report. 100% srgb and 96% adobergb meets the needs of professional users involved in colour-centric work such as graphic design, cad/cam, gaming and media creation.customize your viewing experience with the height-adjustable stand and tilt/swivel features - or save valuable desktop space by detaching the panel from the stand for wall mounting.
- height adjustable
- swivel & tilt stand
- screen size: 27" ips widescreen
- resolution: 2560x1440
- contrast ratio: 80000:1
- brightness: 350cd/m²
- response time: 6ms
- viewing angles (h/v): 178°/178°
- colours: 1.07 billion
- inputs: 1x analogue, 2x dvi-d, 1x hdmi, 1x displayport, 1x composite & 1x component
- 4-port usb hub
- 8-in-1 card reader
- vesa compliant
- dimensions: 646.71mm x 427.83mm x 199.95mm
- weight: 7.72kg
- warranty: 3 years on-site (premium panel guarantee)
was £559.99 inc. vat
only £527.99 inc vat.
order now
dell ultrasharp u3011 30" widescreen lcd monitor - midnight grey @ £849.98 inc vat
experience amazing wide-angle viewing and color consistency with the delltm ultrasharptm u3011 30"w monitor with premiercolor. extensive connectivity features and customization via customcolor mode make the u3011 an ideal choice for professionals in cad/cam, graphic design, gaming and other fields where color precision matters.
features:-
- ips (in-plane switching) technology for minimal color deviation across a wide viewing angle
- 30" (76cm) display with 2560x1600 resolution and 16:10 aspect ratio for clear images and exceptional multitasking
- 117% (cie 1976) color gamut with excellent adobergb and srgb coverage for rich, lifelike visuals
- easy, versatile adjustability and some of the latest connectivity options, including hdmi, displayport, dvi-d, usb ports and a 7-in-1 media card reader
specification:-
- 30" widescreen
- about 52.5% more screen area than dell 2407wfp-hc
- the only 4 mega pixels monitor that shows true resolution of mega pixel pixel photos
- higher definition than hd television to meet the most stringent video needs
- 2560 x 1600 (wqxga) optimum resolution (dual link capable dvi-d graphics card required)
- 1.07 billion colours
- 100,000:1 contrast ratio
- 7ms response time (7ms grey-to-grey)
- 370 cd/m2 brightness
- two dvi-d input with hdcp support
- two hdmi input
- one display port input
- one analogue input
- component connectors
- height adjustable stand, tilt and swivel (100mm travel)
- vesa mounting compatible / security slot : yes (100mm) / yes
- integrated powered usb 2.0 hub : 4 downstream / 1 upstream ports
- integrated powered 9-in-2 card reader: compact flash 1&2, secure digital, mmc, smart media and microdrive
- warranty : 3 year next business day exchange supplied by manufacturer. (call dell on 0870 9080800 and have the work number from the original packaging handy, request to speak to the dell warranty monitor line)
was £899.99 inc. vat
only £849.98 inc vat.
order now
hanns.g hz281hpb 27.5" widescreen lcd monitor - black @ £227.99 inc vat
the hanns.g 27.5" has an industry ultra-fast 3ms response time making it perfect for blur-free video and gaming. with it's 15000:1 contrast ratio and excellent viewing angles there is no other tft that can match the combination of quality, value and performance. making the large screen affordable to all this 27.5" is ideal for gamers and home cinema use due to its huge size and 1920x1200 resolution.
- screen size: 27.5" widescreen
- resolution: 1920x1200
- contrast ratio: 15000:1
- brightness: 400cd/m²
- response time: 3ms
- vesa compliant
- dimensions: 653.0mm x 523.0mm x 254.0mm
- weight: 8.5kg
only £227.99 inc vat.
order now
hazro hz30wie 10-bit 30" lcd widescreen professional monitor - black @ £695.99 inc vat
the hazro hz30wi is ideal for graphics and visual media, where professional grade technology meets revolutionary design. the massive 4mp (2560x1600) wqxga resolution brings a new dimension to on-screen graphics. s-ips display technology delivers unsurpassed levels of colour saturation. it results in image clarity that allows for colours to be easily differentiated to bring unheard of precision and accuracy in visual reproduction. wherever you need it most, the hazro hz30wi performs with consistency and clarity to optimise your visual experience. the hazro hz30wi recognises groundbreaking technology without compromising efficiency, whilst tailoring to the needs of the discerning, professional, user. the masterful design outside augments the genius within, with the hazro hz30wi collating top industry-spec innovation with rock-solid dependability to perform when you need it most, time and time again. with the hazro hz30wi, you can view perfectly rendered images without compromising on the space you need to take your creation from conception to fruition. view an uncompromisingly crisp, and sharp, output that won't strain your eyes in a resolution and pixel pitch that'll inject life into your work with piercing detail. the hazro hz30wi offers three times the workspace of a standard 19" monitor and 77% more workspace than a 24" [16:9] display - allowing creative freedom and practicality. with quicker access to colour tools, palettes and document windows, the hz30wi is proven to increase efficiency and output. anyone can see the tangible results of being able to view two application windows side-by-side. whether it's to look at a website and its code simultaneously, or if it's to streamline data-entry processes, the final result will still be improved efficiency - and, in the case of businesses, an impact on their bottom line.
features:-
- lcd panel: 30" wqxga colour lcd s-ips active matrix
- type: 16:10 aspect ultra wide gamut tft-lcd
- bit depth: hz30wie: 10bit 1.07billion colors
- viewing area: 641.28 mm (h) x 400.8 mm (v)
- resolution: 2560 [h] x 1600 [v]
- pixel pitch: 0.2505mm x 0.2505mm
- contrast ratio: 1000 : 1(typ.)
- refresh rate: 59 ~ 60 hz
- response time: 6ms [grey-to-grey]
- color gamut: wide gamut 117% (cie 1976) ntsc [100% adobergb and srgb coverage]
- brightness: 370 cd /m² (center 1 point)
- viewing angle: r/l : 89°/ 89°u/d : 89°/ 89° (178°/ 178°)
- surface treatment: hard coating(3h), anti-glare treatment of the front polariser
- vesa hole configuration: vesa 100x100 & 200x100
- dimensions: approx: 690(l) x 445(w) x 65mm(d) (excluding stand)
- weight: approx 11 kg before packaging and excluding stand [approx]
- power consumption: in operation: <150w
- dpms / off: <2w
- energy saving mode: vesa dpms [display power management signaling]
- power input/output: dc input: ac 100v-240v, 50~60hz, dc output: dc 24v / 6.3a [approx]
- inputs: 24v dc jack, 1 x dual link dvi-d;
- accessories: 1 x dual link dvi-d cable; 1 x iec 3 pin ac power cable;
- 1 x dc power adapter; instruction manual
- 3yr warranty
- read the tft central review here of 8-bit version: http://www.tftcentral.co.uk/reviews/hazro_hz30wi.htm
was £739.99 inc. vat
only £695.99 inc vat.
order now
samsung s27a750d 27" 120hz 3d widescreen ultra thin led monitor - glossy black @ £443.99 inc vat
samsung’s 750 and 950 series 3d desktop 3d monitors feature high refresh rate, incredibly thin bezel and stylish design. these monitors are able to analyze and render 2d content in real-time to 3d, supporting pc content, blu-ray films and gaming consoles. the monitors feature a built-in glasses sync emitter, and they are packaged with a pair of 3d active shutter glasses.
viewers will experience deep, rich colours and image clarity with samsung’s new ultra clear panel technology, which combines the vibrancy of a glossy display while maintaining the ease of viewing afforded by an anti-glare matte finish. the led-backlit panel boasts 100% srgb coverage to produce realistic colour reproduction.
features:-
- 3d active glasses are included
- true 120hz
- 2d - 3d conversion technology
- response time: 2ms (2d) / 2ms (3d)
- inputs: 1x hdmi, 1x displayport
was £469.99 inc. vat
only £443.99 inc vat.
order now
samsung s27a950d 27" 120hz 3d widescreen ultra thin led monitor - glossy black @ £469.98 inc vat
features:-
- true 120hz
- inputs: 1x hdmi, 1x displayport, 1x dual link dvi
was £491.99 inc. vat
only £469.98 inc vat.
order now
acer aspire 5552-n956g64mnkk 15.6" led tft, amd phenom ii x4 2.1ghz, 6gb ddr3, 640gb hdd, dvd-supermulti - windows 7 home premium 64-bit @ £419.99 inc vat
the aspire 5552 meets your daily computing needs with excellent processor performance and impressive graphics. hd media playback offers richer entertainment at home or on the road, while boundary-free wireless communication keeps you in touch with family and friends all the time. what's more, acer's special 16:9 home touch design provides simple usability for more relaxed computing.
features:-
- processor amd phenom ii x4 (n950) 2.1ghz 2mb cache & 3600mhz bus speed
- memory (maximum) 6144mb (1066mhz ddr3 sdram)
- hard disk 640gb (1 x 640gb) 5400rpm hard drive
- uma graphics
- screen 15.6in hd acer cinecrystal led 16.7 million colours
- optical drive type dvd super multi dl
- operating system microsoft windows 7 home premium (64-bit)
- case colour black
- dimensions 38.1cm (w) x 25.3cm (d) x 2.6kg
- 1yr warranty
was £449.99 inc. vat
only £419.99 inc vat.
order now
acer aspire 5560g-6346g50mnkk 15.6" led tft, amd quad core a6 1.4ghz, 6gb ddr3, 500gb hdd, dvd-supermulti, ati hd 6470m - windows 7 hp 64-bit @ £539.99 inc vat
the aspire series offers a diverse range of notebooks that give you the performance, graphics and communication tools to step up your digital entertainment, complete your daily computing tasks, and stay in touch with everyone you know, whether you're at home or away.
with dedicated onboard ati hd 6470 graphics makes the acer 5560g ideal for gamers with plenty of power on hand to play the latest games without issue further backed up by the extremely powerful amd a6 quad core cpu.
with the abundance of graphics-intensive multimedia and sharing applications available these days, smooth multitasking is more vital than ever before. keeping this in mind, aspire series notebooks pack today's best processors and memory options so your system always runs efficiently. this series also provides ample storage for all the multimedia files you may wish to keep
high-resolution displays in a variety of sizes present intense imagery from first-rate graphics options. movies, internet video, pictures and more shine brilliantly on aspire series notebooks, and hdmi connectivity extends the spectacle to larger displays
aspire series notebooks are attractive, ergonomic and durable. slim profiles, cool aesthetic accents, and eye-catching colours abound, while easy-access controls ensure effortless handling. a variety of environmentally sustainable materials with inviting textures and sturdy construction endow the aspire series with a unique and solid feel
features:-
- processor: amd quad core a6 (3400m) 1.4ghz 4mb cache
- chipset: amd a60m fch
- memory: 6144mb
- hard disk: 500gb (1 x 500gb) 5400rpm hard drive
- screen: 15.6in hd cinecrystal led lcd colours
- optical drive type: dvd supermulti dl
- graphics device: amd radeon hd 6470m with 1024mb vram total memory
- vga port: 1 x 15-pin d-sub
- hdmi port: 1 x hdmi
- rj-45 ports: 1 x rj-45
- removable flash memory media 5-in-1 card reader
- network (wireless) wireless system acernplify
- rf network standard ieee 802.11 b/g/n
- webcam hd webcam
- camera resolution 1.3 megapixel
- battery lithium-ion (6cells)
- case colour black
- dimensions 38.16cm (w) x 25.30cm (d) x 3.32cm (h)
- weight 2.60kg
only £539.99 inc vat.
order now
msi wind u230 12.1" wled tft amd neo 1.6ghz, 2gb ddr2, 250gb hdd, ati graphics, win7 home premium - pink @ £239.99 inc vat
this stylish msi wind u230 12.1in laptop is designed for both maximum comfort and security. this is emphasised by its msi ergonomic de-stress keyboard which increases the typing surface area and face-recognition software which creates a login from your facial features for added security. please note: this product does not have a cd/dvd drive. cpu and memory: amd athlon neo. processor speed 1.6ghz. 2gb ddr2 ram. 250gb hard drive. display features: 12.1in display. resolution 1366 x 768 pixels. graphics: ati radeon. interfaces and connectivity: multi-media card (mmc) compatible. 3 usb ports. 1 hdmi port. b/g/n wireless/wifi enabled. multi-media features: 1.3mp built-in webcam. built-in mic. operating system and software: microsoft windows 7 premium. preloaded manufacturers applications included: music. photo. movie. business. tuition. gaming. general features: up to 5 hours battery life. weight 1.3kg.
features:-
- amd athlon neo.
- processor speed 1.6ghz.
- 2gb ddr2 ram.
- 250gb hard drive.
- display features: 12.1in display.
- resolution 1366 x 768 pixels.
- graphics: ati radeon.
- multi-media card (mmc) compatible.
- 3 usb ports.
- 1 hdmi port.
- b/g/n wireless/wifi enabled.
- multi-media features:
- 1.3mp built-in webcam.
- built-in mic.
- operating system and software:
- microsoft windows 7 premium.
- up to 5 hours battery life.
- weight 1.3kg.
- 1yr warranty.
was £249.98 inc. vat
order now
htc flyer 7 inch 16gb android 3.20 tablet pc with wifi @ £239.99 inc vat
serious gaming wherever you go--a powerful processor and gorgeous graphics lets the htc flyer handle rich, immersive games with ease.
it’s not just the visuals that are impressive. htc flyer comes with dual speakers for a much richer listening and entertainment experience. enjoy high fidelity sound with srs wow hd™ virtual surround sound.
fly through the web with your friends, wherever you are
conveniently compact and light enough for you to travel around, yet amazingly powerful, the htc flyer tablet with a 7-inch display and a super speedy 1.5 ghz processor is perfect for web browsing at home, in the car or on a business trip. to make it just that little bit better, it even comes equipped with adobe flash support, multi-window browsing with pinch to zoom capability, and a clever quick look-up that allows you tap into wikipedia, youtube and other web resources as you wish.
have you ever had a camera with a 7-inch view finder? it’s an eye opening experience for sure! take great shots with the 5mp camera and capture life in hd with the 720p hd camcorder.
there’s no need to carry epic novels around with you anymore with a built-in library of classics at your fingertips. flick through titles, and even highlight and explore a word or phrase through wikipedia, google, youtube or the dictionary. the htc flyer lets you download your favorite books and take them anywhere.
take family photos to another level with our new snapbooth. you can change lenses or add effects to make moments more memorable. and when you’re done taking the photo, use the pen to re-touch it, name it or turn your picture into a birthday card.
no more hunting around for stuff, anything you want is only a swipe and a tap away. photos, entertainment, weather, calendar, mail, friends smoothly roll around at your fingertips, front and center, while giving you a sneak peak of what’s to come.
with htc watch, htc flyer transforms into a portable cinema featuring a wide selection of the latest hollywood blockbusters for on-demand viewing. and with an expansive 7-inch screen and superb srs virtual surround sound, you can immerse yourself in the cinematic experience whether it'’s on a short break or a long drive.
transform your htc flyer into a fun, safe and secure playground for your kids. kid mode opens up a world of brainy games, story books - that let you tell a bedtime story even when you’re not there and art mode that incorporates the magic pen and lets their artistic side run wild.
features:-
- the htc flyer’s magic pen transforms anything. it can draw, paint, write, and even retouch pictures
htc flyer transforms into a portable cinema for your viewing pleasure
- comes equipped with dual speakers for a much richer listening and entertainment experience
- take great shots with the 5mp camera and capture life in hd with the 720p hd camcorder
- take family photos to another level with htc’s new snapbooth
- updated to android 3.20 o.s.
technical details:-
- android 3.20 with htc sense
- 7 inch touch-sensitive screen with 1024 x 600 resolution
- 420 grams (14.82 ounces) with battery
- 1.5 ghz
- 5 megapixel color camera with auto focus
- 1.3 megapixel front camera
- internal storage: 16 gb
- ram: 1 gb
- microsd™ memory card (sd 2.0 compatible)
- 3.5 mm stereo audio jack
- standard micro-usb (12-pin micro-usb 2.0)
- ambient light sensor
- g-sensor
- digital compass
- bluetooth® 3.0 with a2dp for wireless stereo headsets
- internal gps antenna
- wi-fi®: ieee 802.11 b/g/
- video supported formats: playback:.aac, .amr, .ogg, .m4a, .mid, .mp3, .wav, .wma (windows media audio 9)
playback:.3gp, .3g2, .mp4, .wmv (windows media video 9), .avi (mp4 asp and mp3), .xvid (mp4 asp and mp3)
audio supported formats: playback:.aac, .amr, .ogg, .m4a, .mid, .mp3, .wav, .wma (windows media audio 9)
recording:.amr, .aac
- 1yr warranty
only £239.99 inc vat.
order now
thermaltake vk90001n2z element t case - black @ £34.98 inc vat
thermaltake have donned the gloves to challege the rest. aimed at the mid-budget range this case is simple and crisp looking with an aura of quality and stlye. built with a top mounted red led fan for optimal cooling this case can be the perfect skin for your overclocked gaming rigs.
- excellent thermal performance with optimal air flow
- folding edge design to strengthen structure and prevent cutting
- front (intake): 120 x 120 x 25mm (optional) or 140 x 140 x 25mm (optional) or 200 x 200 x 20 (optional)
- rear (exhaust): 120 x 120 x 25 mm turbofan, 1400 rpm, 17 dba
- top(exhaust): 200 x 200 x 20 mm red led fan, 800 rpm, 14 dba
- vga (intake): 230 x 230 x20mm (optional) or 120 x 120 x25mm (optional)
- i/o ports: 2 x usb2.0 and 1 x audio
- drive bays: 3 x 5.25", 6 x 3.5" and 1 x 2.5" ssd/hdd bay
- dimensions: 525 (h) x 210 (w)x 480(l) mm
was £39.98 inc. vat
only £34.98 inc vat.
order now
ocuk monolith full tower case - black @ £139.98 inc vat
big and brash! the new ocuk monolith case offers the best of the best for any extreme pc build. supporting room for two power supplies and room for an sr2 system and a full water cooling accompaniment.
- drive bays: external 5.25" drive bays: x 4
- internal 3.5" drive bays: x 10
- front i/o access usb 3.0 x 2 / usb 2.0 x 2 / audio x 1 / mic x 1
- expansion slots: 10 slots
- mainboard: hptx, xl-atx, eatx, atx, micro-atx
- front cooling: 1 x 140mm front fan
- rear cooling: 1 x 140mm rear fan
- water cooling support : x7
- dimensions: 619mm (d) x 229mm(w) x 567mm (h)
was £159.98 inc. vat
only £139.98 inc vat.
order now
fractal design core 1000 midi tower case - black @ £29.99 inc vat
the core 1000 brings many features usually only seen in more expensive and larger cases. it supports long graphics cards up to 350mm due to the innovative, vertical and removable hdd mounting bracket. the front panel is also easily removable and pre-fitted with fan filters to ensure a dust free interior. the sleek black interior is matched and contrasted with white expansion slots. it is similar to the define series in that all the hdd trays are fitted with anti-vibration silicon grommets for optimal silence.
- simple yet elegant front panel with mesh and filter
- optimised for micro atx form factor with multiple cooling options
- a total of 3 fan slots, one fan supplied
- innovative hdd-tray which mounts the hdds vertically with anti-vibration silicon grommets
- supports graphic cards with lengths up to 350mm
- motherboard: miniitx and microatx
- gpu compatibility: up 350mm long
- rear cooling: 92mm fan (optional)
- side cooling: 120mm fan (optional)
- front cooling: 120mm fan (with filter)
- 4 expansion slots
- front i/o ports: 2 x usb2.0 and 2x audio
was £32.99 inc. vat
only £29.99 inc vat.
order now
corsair obsidian 650d gaming midi tower - black @ £139.98 inc vat
nonl2br
the obsidian series 650d mid-tower case is manufactured with strong, stamped steel parts for increased rigidity, and coated in a black textured paint. the front panel features a beautiful black brushed aluminum faceplate to bring a subtle elegance to your next build.
a large, black 200mm intake fan hides behind the front dust filter, quietly pushing vast amounts of air over your hard drives and video cards. the air is then exhausted by a second 200mm fan on top of the case, and a rear 120mm fan. the top fan can be replaced by dual 120mm or 140mm fans, and is pre-spaced for a dual radiator if you’re interested in watercooling. and all fans are controlled by a three-mode, four-channel fan controller should you want to make your own choice between noise and performance.
- motherboard support: atx / matx
- expansion slots: 8
- drive bays: 5.25" x 4 & 3.5"/2.5" x 6
- cooling: 2 x 200mm fans and 1 x 120mm fans
- front i/o ports: usb2.0 x 2 / usb3.0 x 2 / firewire x 1 / audio x 2 / 4-channel fan controller
- dual 200mm fans provide outstanding cooling for even the hottest components
- easily accessible dust filters make maintenance simple and hassle-free
- quick-release side panels make it easier than ever to upgrade your hardware
- integrated fan controller lets you quickly adjust cooling performance and noise levels
- four tool-free optical drive bays and up to six ssd-ready hard drive trays provide plenty of expansion
- cpu backplate cutout makes it easy to upgrade your cpu cooler
- brilliant cable routing system provides a way to keep your system neat and tidy
- adjustable drive cages can be removed and relocated to accommodate large video cards
- room for long power supplies gives you peace of mind for future upgrades
- dimensions: 546mm (l) x 229mm (w) x 521mm (h)
was £145.99 inc. vat
order now
cooler master cosmos ii ultra tower case - black @ £319.98 inc vat
the flagship case of cooler master - cosmos ii, is defined as the “ultimate platform for extreme performance”. its streamlined design with aluminum and mesh makes this product incomparably stylish and luxurious. it supports up to 10 fans, 13 hdds, and 4 way sli/cf; also features an advanced control panel for fan speed adjustment with led indicators. the rich i/o includes 2 high speed usb 3.0 ports for quicker data transfer. the combination of its elegant looks, numerous expansion options, and functionality make the cosmos ii a definite choice for a user’s “dream case”.
- stylish and streamlined race-car inspired design
- brushed aluminum and steel for strength and elegance
- airflow optimized design
- supports up to 10 fans and 13 hdds (2 from x-dock)
- supports 4 way sli/cf
- supports xl-atx / ssi ceb / ssi eeb boards
- advanced control panel:
- 4 channel fan speed control
- materials appearance: aluminum, mesh, plastic/ case body: steel
- dimensions: 344(w) x 704(h) x 664(d)mm / 13.5 x 27.7 x 26.1 inch
- weight: 21.5kg
- m/b type: micro-atx, atx, e-atx, xl-atx, ssi ceb, ssi eeb
- 5.25" drive bay: 3
- 3.5" drive bay: 13 (2 from x-dock, middle cage for 5 hdds, bottom cage for 6 hdds:
- 2.5”/3.5" drive bay 11 (converted from 3.5" bay)
- i/o panel: usb 3.0 x 2, usb 2.0 x 4, e-sata x 1, audio in and out
- expansion slots: 10+1
- front cooling: 200mm led fan x 1 (converted from 120/140mm x 1)
- top cooling: 120mm black fan x 1 (converted from 200mm fan x 1/ 140mm fan x 2 / 120mm fan x 3)
- rear cooling: 140mm fan x 1
- side cooling: 120mm fan x 2 (optional)
- hdd: 120mm fan x 3 (2 for bottom hdd / 1 for mid. hdds)
- maximum compatibility: cpu cooler height: 190mm / gpu card length: 385mm
vortez review : http://www.vortez.net/articles_pages/cooler_master_cosmos_2_review,1.html
Was £339.98 Inc. VAT
Only £319.98 inc VAT.
ORDER NOW
Antec 300 Three Hundred Ultimate Gaming Case - Black @ £41.99 inc VAT
Impressively spacious and unbeatably reliable, the Antec Three Hundred is an unbeatable enclosure. Despite its eminently portable frame, the Three Hundred has enough room for most of the latest flag-ship graphics cards, as well as six hard drives and a standard ATX motherboard. A cable management compartment keeps your system organized and the airflow unobstructed. A 120mm rear fan and 140mm top fan ensure that the case runs cool even when playing the most demanding games, while the sleek black finish gives it an extra stylish edge.
- External 3 x 5.25"
- Internal 6 x 3.5" for HDD
- 1 rear 120 x 25 mm TriCool™ Fan with 3-speed switch control.
- 1 top special 140 x 25 mm TriCool™ Fan with 3-speed switch control
- 2 front (optional) 120 mm fans to cool the hard drives
- 1 side (Optional) 120 x 25 mm Fan to cool graphic cards
- Washable air filters reduces dust build up in your system, which helps keep your system cooler
- Perforated front bezel for maximum air intake
- 7 expansion slots
- Top mounted I/O ports for easy access
- 2 x USB 2.0
- Dimensions: 458mm (H) x 465mm (D) x 205mm (W)
- HDA & AC’97 Audio In and Out
Was £44.99 Inc. VAT
Only £41.99 inc VAT.
ORDER NOW
Antec TruePower New Modular 650W '80 Plus Bronze' Power Supply @ £86.99 inc VAT
New features. Same true power. The TruePower New series by Antec offers users an advanced power supply solution, striking the perfect balance of reliability, efficiency and quality. With DC to DC voltage regulator modules, a 120mm PWM fan, and 80 PLUS® Bronze certification, TP-650 is the ideal solution for elite system builders and quality-minded enthusiasts alike.
- NVIDIA™ SLI™ - ready certified
- 80PLUS® Bronze Certified saves energy and lowers your electric bill
- DC to DC voltage regulator modules for greater system stability
- 120mm PWM fan runs up to 50% quieter than standard fans
- Advanced Hybrid Cable Management improves airflow and reduces clutter
- Double layer PCB optimizes cooling efficiency and allows for heavy duty components
- Universal Input and Active Power Factor Correction
- Supports dual GPUs and dual/quad core CPUs
- 4 +12V output circuits provide stable power
- ATX12V v2.3 and EPS12V v2.91
- 1 x 6 pin and 1 x 8 (6+2) pin PCI-E graphics card connectors for TP-550
- 2 x 6 pin and 2 x 8 (6+2) pin PCI-E graphics card connectors for TP-650, TP-750 and - Industrial grade protection
- Safety approval: UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick, BSMI
- Dimensions: 86mm (H) x 150mm (W) x 150mm (D)
Was £89.99 Inc. VAT
Only £86.99 inc VAT.
ORDER NOW
Antec High Current Gamer 900W Quad Rail '80 Plus Bronze' Power Supply @ £108.98 inc VAT
Making quad rail power and highly advanced power supply design available at a popular wattage, the HCG-900 features special High Current connectors and heavy-duty cabling, earning it NVIDIA® SLI®-Ready and ATI™ CrossFire™ certifications. At the same time the HCG-900 is also 80 PLUS® Bronze certified for efficiency, and features active PFC with a swift, quiet 135 mm double ball bearing fan so you know you're getting not only High Current, but also high efficiency and excellent cooling. If loads of power, High Current engineering and exceptional efficiency are what you're after, the HCG-900 is the perfect PSU for you.
- 900 watts of Continuous Power
- NVIDIA&® SLI®-Ready certified, ATI CrossFire™ certified
- 80 PLUS® Bronze certified - up to 88% efficienct
- Quad High Current +12V rails with high maximum load for better graphics card compatibility
- Quiet 135mm double ball bearing cooling fan with low start voltage
- Four gold-plated 8 (6+2)-pin PCI-E connectors for multiple-graphics card configurations
- All Japanese brand capacitors for reliability
- ATX12V version 2.3 and EPS version 2.91 compliant
- Gold-plated High Current terminals for optimal conductivity
- Universal Input - works on any 100V - 240V grid
- Active PFC with PF: 0.99 - less harmonic pollution, greater efficiency
- Full suite of industrial grade protection:
- Over current protection (OCP)
- Over voltage protection (OVP)
- Short circuit protection (SCP)
- Over power protection (OPP)
- Over temperature protection (OTP)
- MTBF: 100,000 hours
- Meets 2010 EUP requirement: 5Vsb < 1W
- Safety: cUL, TUV, CE, CB, FCC, C-TICK, CCC, BSMI, Gost-R
- AQ5 Antec Quality 5-year limited warranty on parts and labor
Was £114.98 Inc. VAT
Only £108.98 inc VAT.
ORDER NOW
Cooler Master Silent Pro Modular 600W '80 Plus Bronze' Power Supply @ £64.98 inc VAT
The Silent Pro series is a new range of single rail power supplies from Cooler Master that's addressing a growing market demand for powerful single rail 12V PSUs. With up to 50A on the 12V rail, the SilentPro series deliveries where it count and won't have any problems powering even the most demanding SLI or CrossFire system,.
The SilentPro series is also the first power supply from Cooler Master to feature flat modular cables for improved airflow and cable management. It also comes with anti-vibration silicon pads to remove possible vibrations from the PSU.
- High Quality Japanese made capacitors
- 85% efficiency
- Copper and Aluminum heat pipes for high efficiency cooling
- Silicon shock absorption rubber pads around the edges of the power supply
- Modularized flat cable design to eliminate clutter and improve airflow inside the chassis
- Two 6+2 PCI-E connectors to support various graphic card setups
Was £69.98 Inc. VAT
Only £64.98 inc VAT.
ORDER NOW
OCZ ZS Series 650W '80 Plus Bronze' Power Supply @ £59.99 inc VAT
The OCZ ZS Series PSU is the superlative solution for driving today's value oriented gaming systems, and can power both NVIDIA® SLI™ and ATI CrossFire™ modes. Enthusiast-grade yet designed with gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and compact form factor. Kept ultra-cool with a load-controlled 135mm fan, the OCZ ZS Series PSU was engi-neered to be the quietest PSU available in its class, elimi-nating distracting noises from your PC. Highly efficient, featuring up to 86.72% efficiency at typical load and up to 83% at full load, this leading-edge power supply remains rock solid and powerful while retaining superior efficiency under load.
This PSU is backed with OCZ’s 3-year “power swap” warranty, the OCZ ZS Series PSU gives you the ultimate power and peace of mind to ensure the stability, low noise, optimized air flow, and efficiency of your gaming system.
- OCZ PowerWhisper™ Technology
- Internal 135mm ball-bearing fan
- Can power SLI™ and CrossFire™ GPU configurations
- 150 x 160 x 86mm (W x L x H)
- ATX12V v2.2 and EPS12V
- 86% Efficiency (Typical Load)
- Overvoltage/Overcurrent/Short-Circuit protection
- Active PFC
- 3 year warranty backed by OCZ’s exclusive PowerSwap™ replacement program.
Was £64.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
XFX Pro 850W Core Edition '80 Plus Bronze' Power Supply @ £89.99 inc VAT
XFX PSUs are designed to deliver tight DC voltage regulation with minimal AC ripple, giving you safer, cleaner power which, along with XFX’s new EasyRail™ Technology allows you to connect numerous devices without worrying about running out of power before reaching the maximum wattage. EasyRail™ optimizes it all for you. Available in 650W, 750W and 850W, XFX ProSeriesPSUs with EasyRail™ Technology gives you one continuous rail of power covering the total maximum wattage. EasyRail™ Technology Provides Maximum Power Unique, continuous EasyRail™ technology enables you to maximize available power and makes set-up easy.
- Fixed FDD: 1
- Fixed Peripheral: 7
- Fixed 6+2-pin PCI-E: 2
- Fixed 6-pin PCI-E: 2
- Fixed ATX12V / EPS12V: One 4+4-pin
- Fixed Motherboard Connector: 20+4 Pin
- Fixed SATA: up to 11
Was £94.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Razer Lachesis Refresh 5600 DPI Gaming Mouse @ £64.98 inc VAT
The Razer Lachesis™ takes on the same lethal traits as its namesake that will send shivers down your enemies’ spines. It knows no rules and takes no hostages. Victory beckons –move in for the kill. The RazerLachesisreigns supreme with a high precision 5600dpi 3.5G Laser sensor, which enables movement speeds of 7 times that of a standard 800 dpi optical infrared sensor. Fragginghas never been that easy. The Razer Lachesis allows programming of every single button with reduced latency for optimum gameplaydue to Razer’sHyperesponsetechnology. With its ambidextrous form all nine buttons are comfortable to reach for both left and right-handed gamers. Customize the look of the RazerLachesishowever you want. With the new multicolor-LED you get a unique look and style on your favorite gaming weapon. The new multicolor-LED allows for personalization of the look of the RazerLachesis–choose from 16 million colors to create unique styles and looks, even independently changing the colors of the mouse wheel and Razerlogo. Its symmetrical shape and ambidextrous form factor allows the RazerLachesisto be wielded equally lethally by left as well as right-handed gamers. Personal mouse settings are saved to 60KB of built-in memory on the RazerLachesis. Make use of the same configuration regardless of whether the computer has installed drivers.
- 5600dpi Razer Precision 3.5G Laser Sensor
- Adjustable multicolor-LED
- 60KB Razer Synapse onboard memory
- Nine independently programmable Hyperesponse buttons
- 1000Hz Ultrapolling/ 1ms response time
- No drift control
- Tracking up to 200 inches per second
- Seven-foot, lightweight , non-tangle cord
- Approximate size in mm: 129 (L) x 71 (W) x 40 (H)
- Approximate weight: 128g
- System & Hardware Requirements
- PC with USB port
- Windows 7 / Windows Vista / Windows XP
- Internet connection (for driver installation)
- 35MB of free hard disk space
Was £74.99 Inc. VAT
ORDER NOW
Steelseries Sensei Pro Laser Gaming Mouse (62150) @ £66.98 inc VAT
Based off the critically acclaimed Xai gaming mouse, the SteelSeries Sensei is a top of the line laser gaming mouse dedicated to suiting tournament level players. It features a highly sophisticated firmware that allows for multiple adjustments of the sensor functionality, as well as complex macros to customize the mouse to the user’s specific desires. With the SteelSeries Engine and illumination present on the design, the Sensei has a new look, both on the outside and on the inside. At the same time though, the Sensei still retains all the features that the original Xai is known for such as its ambidextrous design, the ability to save different profiles on board, and the LED panel to customize the
mouse on the fly.
- Programmable macro buttons
- Ambidextrous shape
- Driverless plug-and-play
- User defined bitmaps for the on mouse LCD
- SteelSeries ExactSens
- SteelSeries FreeMove
- Menu system on the mouse
- SteelSeries ExactAim
- 7 Programmable buttons
- SteelSeries ExactLift
- Gold-plated USB connector
- 16 million colors of illumination
- Three zone lighting
- Scroll Wheel
- CPI Indicator, and Logo
Was £69.98 Inc. VAT
Only £66.98 inc VAT.
ORDER NOW
Cherry Black CyMotion Expert (USB/PS2) Keyboard - Black @ £17.99 inc VAT
The ideal keyboard for anyone who values reliability and perfect handling without superfluosus show effects. Coffee on the keyboard... dirt between the keys... life is hard, but the CyMotion can take all this and more! Thanks to its special construction, this capable, extremely robust cabled keyboard in the new, elegant CyMotion design is nearly indestructible and offers reliable top performance and precise actuation even after many years. Perfect ergonomics and numerous clever additional features are other convincing arguments.
!!<<img src="green.gif">>!!
Was £19.99 Inc. VAT
Only £17.99 inc VAT.
ORDER NOW
Logitech K300 Compact Keyboard (920-001488) @ £15.98 inc VAT
Control your media and smarten up your space with the Logitech® Compact Keyboard K300. Its stylish, backlit media controls provide an elegant and easy way to access to your music, videos and e-mail, with keys that blend cleanly into the streamlined styling. The K300 features a space-saving design with full-size keys that frees up space on your desk – and makes the keyboard easy to store or take with you. A full-size, integrated number pad makes data entry fast and effortless. The ultra-flat profile helps you type comfortably with keys move quietly and feel great, shifting your wrists toward a more neutral position. Plus, setup is easy: the K300 works right out of the box, with no software to install.
- Backlit media controls
- Full-size number pad
- Space-saving design
- Ultra-flat profile
- Easy setup
Was £17.99 Inc. VAT
Only £15.98 inc VAT.
ORDER NOW
Xebec Media Line LightWeight Keyboard @ £12.98 inc VAT
The Media Line keyboard is a true revelation. Not only is it extremely light- weighing in at just 760g with a super slim design and an integrated ergonomic wide palm rest, but it also boasts 18 multi-media hotkeys. Making fast switching between applications effortless, no longer need to run to the start menu to open an application!
- OS compatibility: Windows 98/2000/XP/Window7/Vista
- Working Temperature: 0-45°C
- Keystroke Lifetime: 10 million strokes per key
- Multi-media quantity: 18 keys
- Dimensions: 450mm x 190mm x 13mm (LxHxD)
- Weight: 760g
- 12 months included warranty, extended 12 months after registering
- Soft silent keys
- 18 multi-media hotkeys in total
- 7 media specific hotkeys: Play/Pause, Stop, Previous track, Next track, Volume down, Volume up, Mute
- 4 internet specific hotkeys: Favourites, Refresh, Home, Mail
- 7 general hotkeys: Page up, Page down, Search, My computer, Calculator, Sleep, Multi-media start
- Plug n Play installation
- Connects to PC via simple USB cable
- Unique super-slim shape
- Light
- Durable
- Super Slim design
Was £14.99 Inc. VAT
Only £12.98 inc VAT.
ORDER NOW
Corsair Vengeance K90 Mechanical Gaming Keyboard @ £104.99 inc VAT
Cherry® MX Red key switches are the best of the best — they provide the sensitivity and low operating force that professional gamers love. Reaction times are ulra-fast and responsive for quicker double and triple taps. The action is predictable and linear unlike lesser gaming keyboards that have a tactile bump or the annoying click of a typist’s keyboard.
Easily access to your most frequently used macros, presets and key combinations even during the most intense action. You can record up to 54 programmable functions accessible from three separate banks, ideal for grouping macros by function, or access. Macros can be created on-the-fly, customized, and activated with a single keystroke.
Our expertly designed anti-ghosting technology provides flawless control even when you're pressing multiple keys at once. The K90 has individual switches with dedicated diodes for each switch so every key press results in an input and is 100% ghost free without tradeoff or compromise.
Typical USB gaming keyboards are limited to the USB standard six-key rollover. The K90 features increased performance with a 20-key rollover implementation on USB at a blazing fast 1ms (1000 reports per second) reporting rate.
The rugged aluminum chassis provides increased durability and stability compared those that are primarily plastic. The stiff suspension chassis and the laser etched keys are made for durability so they won't degrade over time. And the K90 has over 90 LEDs that provide outstanding illumination even in dim light.
Create up to 50 profiles and share, import and export macros with the Vengeance keyboard gaming software. It's a free download at corsair.com.
On-board memory lets you take it with you
36Kb of memory built into the K90 lets you take your customizations and profiles with you and use them on any system.
- Light, responsive Cherry MX Red Mechanical switches for fast, efficient gaming action
- 45g actuation force
- 2mm to actuation and 4mm to bottom
- Rated for 50 million operations
- Gold contacts
- Three banks of eighteen G Macro Keys with Macro Record and Bank Select hot keys
- 36Kb of onboard memory for storing up to three sets of eighteen G keys for gaming on the go
- On-the-fly, macro recording
- Laser-etched, backlit keys with four illumination levels (off, 66%, 75%, and full illumination) selectable from the keyboard
- Six multimedia keys — Stop, Previous, Play/Pause, Next, Mute, Volume Up/Down — with Solid metal, weighted volume “drum roller”
- Windows Lock key for uninterrupted game play
- Metal top plate for increased strength, durability and rigidity
- USB pass-through connector giving easy access to a USB port on the back of the keyboard (USB 2.0/1.1/1.0)
- USB Connector with gold plated contacts
- Selectable report rate: 1000Hz/500Hz/250Hz/125Hz (1ms/2ms/4ms/8ms) response time
- 2m non-tangle cable
- Adjustable feet tilt for optimum personalization and positioning
Only £104.99 inc VAT.
ORDER NOW
Cherry G80-3000 Mechanical Keyboard @ £61.98 inc VAT
The timeless keyboard for high-volume data input and for the most demanding requirements. Durable, reliable and sure switching action. Proven millions of times over. The G80-3000 standard PC keyboard is based on the reliable MX technology with the patented MX Blue Switches. This is the top of the Cherry keyboard range and features MX Technology (individual keys with gold crosspoint contacts). The key action is very precise and positive with a perfect key weighting and the positive click that Cherry are famous for. This keyboard is ideally suited to applications where high volumes of data are to be input, each key has a life expectancy of more than 50 million
- Cherry MX Blue Switches
- Connectivity technology: Wired
- Keyboard number of keys: 105
- PS/2-or USB Interface.
- High-quality keyboard for professional users.
- Precision switching.
- Keycap symbols are wear-resistant and easy to clean.
- Individual keys have long service life: >50 million operations.
Was £64.99 Inc. VAT
Only £61.98 inc VAT.
ORDER NOW
OcUK Black Gaming Keyboard (5105GU) @ £8.99 inc VAT
Gamers who like first person shooters will enjoy this keyboard. The Emprex 5105G series keyboard is regular sized and has standard keycaps. Its 104 keys are provided with low noise and high touch sensitivity. There are 3 hotkeys for volume up, down and Windows Logo Lock Key.
- Anti-ghosting capability for up to 11 keys
- 20 million keystroke life
- Windows Logo Lock Key to prevent interruption of gaming sessions
- LED indicators for Caps Lock, Scroll Lock, Num Lock & Win Lock
Was £10.99 Inc. VAT
Only £8.99 inc VAT.
ORDER NOW
TT eSports Challenger Gamers Keyboard @ £29.99 inc VAT
This keyboard offers a unique cooling solution for your hands when the heat of the battle takes its toll on you. Allowing you to game under many different conditons you will be razor sharp at all times.
- Interface: USB
- Operational systems: WindowsR 7/Vista/XP
- Number of Macro keys: 6
- Number of Multimedia keys: 7
- 2.0 USB port: 1
- Switch lifecycle: 10 Millions
- Cable length: 2m
- Body dimension (LxWxH): 480x 205.5x 25mm
- Fan Speed: 6,000 RPM(±15%)
- Max. airflow:2.7CFM
- Noise level:21.7dB
- Rate voltage: DC 5.0V
- Life expectancy: 50,000 HRS
- Body dimension (LxWxH): 30x30x10mm
Was £36.98 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Zowie Celeritas Pro Gaming Mechanical Keyboard - UK Layout @ £99.98 inc VAT
The ZOWIE CELERITAS is a groundbreaking mechanical keyboard designed for competitive gaming. To ensure the best overall durability and most comfortable feeling during use, the ZOWIE CELERITAS features 18K gold-plated Cherry MX Brown switches and nylon key caps.
Developing competitive gaming gear which satisfies demanding gamers through FPS, RTS and Racing games is a challenge. To overcome this challenge, the ZOWIE CELERITAS was developed in cooperation with professional gamers Abdisamad 'SpawN' Mohamed, Young Ho 'Flash' Lee and Ho Jun 'Ho-Jun' Moon.
The ZOWIE CELERITAS features the newly developed ZOWIE RTR™ technology which allows the user to define the repeat-response of their presses to be 1x, 2x, 4x or 8x of the normal repeat-response for a keyboard. RTR™ allows gamers to gain a higher responsiveness from their keys and increase the pace of movement in FPS and Racing games or possibly even increase the APM in RTS.
With just 0.2 second response-time, the ZOWIE CELERITAS has the fastest reactions of any mechanical keyboard on the market. It supports all keys anti-ghosting through PS/2 and 6 keys through USB. To avoid accidently hitting the Windows key, we developed a function to define the Windows key as Ctrl, allowing RTS-gamers to increase their reach and APM.
USB Functions
- 6 keys Anti-Ghosting through USB
- 18K Gold Plated mechanical switches and USB connectors
- Ability to change the "Windows"-key to "Ctrl"
- Multimedia controls
- Highly durable metal inner chassis
- Ergonomic design saves space and offer full comfort during use
- Connector: USB / PS2 (by USB to PS2 converter)
- Cable Length: 1.8m / 5.8 ft.
PS/2 functions
- Full Anti-Ghosting with PS/2
- ZOWIE RTR™ technology provides 4 levels of repeat-response (normal, 2x, 4x, 8x) - PS/2
Was £109.99 Inc. VAT
Only £99.98 inc VAT.
ORDER NOW
Logitech Wireless MK520 Desktop (920-002606) @ £43.98 inc VAT
The Logitech® Wireless Combo MK520 puts convenience and control comfortably at your fingertips – whether you use a laptop or desktop. The sleek, full-size keyboard gives you the room you need to type comfortably, while the concave Logitech Incurve keys™ cradle your fingertips. The full-size mouse offers smooth, precise laser tracking and feels good in either hand – hour after hour – thanks to its hand-friendly, contoured design with soft rubber side grips. And your desktop is hassle-free with up to three years of battery life for the keyboard and one year for the mouse*, a tiny Logitech Unifying receiver that you can plug and forget, and Logitech Advanced 2.4 GHz wireless connectivity. * Battery life may vary based on user and computing conditions.
- The keyboard’s full-size layout gives you the room you need to type comfortably – with all the keys where you expect them to be. The concave design and softly rounded edges of the whisper-quiet, low-profile Logitech® Incurve keys™ position your fingers properly and invite your fingertips to glide from key to key, hour after hour. The palm rest gives your hands the perfect place to rest when you’re not typing. And you can store your keyboard standing up to free up space on your desk when you’re not using it.
- The full-size mouse feels good in either hand – even after long hours of use – thanks to its hand-friendly, contoured design with soft rubber side grips. And laser precision means you'll enjoy smoother tracking on just about any surface so you can say goodbye to the frustrations of basic mice and tricky touchpads.
- Up to three-year keyboard and one-year mouse battery life. Better power management practically eliminates the need to replace batteries**.
- The tiny Logitech® Unifying receiver is small enough to stay in your laptop and connects both the included mouse and keyboard, so they're ready to use whenever you need them. Plus, you can easily add another compatible mouse, keyboard or number pad – without the hassle of multiple USB receivers.
- Logitech® Advanced 2.4 GHz wireless connectivity gives you the reliability of a cord plus wireless convenience and freedom – fast data transmission, virtually no delays or dropouts, and 128-bit AES encryption.
Was £45.98 Inc. VAT
Only £43.98 inc VAT.
ORDER NOW
Microsoft Wireless Desktop 2000 (M7J-00020) @ £31.98 inc VAT
Unlike standard keyboards, this one features Advanced Encryption Standard (AES), which can help protect your personal and business information by encrypting what you type. Enjoy the classically designed keyboard, with a pillow-textured palm rest for support and comfort. The desktop is completed with a wireless, full-size mouse that features enhanced side grips, four-way scrolling and Blue Track technology. Not only is this desktop secure, comfortable and convenient – it’s simple to use—just plug in the transceivers and you’re ready to go!
- Advanced Encryption Standard (128bit)
- Taskbar Favourite for Windows 7
- Windows Start Button
- Pillow Texture Palm Rest
- Comfort and control for either hand
- BlueTrack Technology
- Battery Status Indicator
- Wireless Freedom
Was £35.99 Inc. VAT
Only £31.98 inc VAT.
ORDER NOW
OcUK Air Duster Compressed Air (400ml) @ £5.99 inc VAT
AIR DUSTER MT2607 is a compressed air in a container with a capacity of 400 ml. Includes an intensive blower to remove dust and dirt from the most inaccessible places. Perfect for all the surfaces, especially those where you cannot use wet or chemical cleaning. Ideal for computers, office equipment, printers, accessories, photographic, precision mechanics, electronics, etc.
Was £6.98 Inc. VAT
Only £5.99 inc VAT.
ORDER NOW
Akasa AK-CC4008HP01 Venom Voodoo CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3 @ £41.99 inc VAT
nonl2brVenom Voodoo, this cooler is definitely rock and roll. Venom Voodoo delivers ultra high performance enabling serious system overclocking. The 12cm killer Viper yellow fan uses S-Flow blades providing 30% more airflow than a standard fan at the same speed. PWM function ensures quiet operation during normal system use and performance cooling under load.<br>
<br>
The Black cover and copper heatpipes combined with the Viper yellow elements creates a striking combination which adds pazazz to any system. Six high capacity heatpipes with direct CPU contact provide rapid heat transfer from CPU to high grade aluminium profiled fins. Anti-vibration rubber fan mounting pins provide easy installation and help to eliminate a lot of fan noise. Adjustable mountings ensure full compatibility with all current AMD and Intel CPU’s.<br>
<br>
Dual 12cm viper fans giving extreme performance in a push-pull setup where the first fan “pushes” air through the heatsink’s cooling fins, at the same time the second one “pulls” air through from the other side. The combined airflow of two 12cm fans results in more efficient heat dissipation and consequently lower CPU temperatures.<br>
<br>
- Dual 120mm PWM fans in killer viper yellow<br>
- Six high capacity 6mm heatpipes with direct CPU contact<br>
- Award winning S-FLOW fan blades provide 30% more airflow<br>
- Rubber fan mounts for easy install and quiet performance<br>
- Fan Dimensions: 120 x 120 x 25mm<br>
- Fan Speed: 600 - 1200 RPM<br>
- Max Airflow: 83.63 CFM<br>
- Noise Level: 6.9 - 28.9dBA<br>
- Cooler dimensions: 131 (W) x 129.5 (D) x 163.5 (H) mm <br>
<br>
<center><iframe width="560" height="315" src="http://www.youtube.com/embed/Rq3OJ5Jss_w" frameborder="0" allowfullscreen></iframe>
Was £44.99 Inc. VAT
ORDER NOW
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939/AM2/AM3/775/1155/1156/1366) @ £17.99 inc VAT
The Freezer 7 Pro Rev.2 is the upgraded version of the renowned Freezer 7 Pro. With the flexible mounting design, this version is compatible with the Intel Core i7, Core i5, as well as AMD Socket AM3. Featuring an ultra quiet 92mm fan and 6 heatpipes, the Freezer 7 Pro Rev.2 is one of the most efficient and quiet CPU coolers for power users.
The unique heatsink design consists of 42 fins, which significantly increase the heat dissipation area to distribute massive amount of heat faster and more efficient. Featuring a 92mm PWM fan , 6 heatpipes and pre-applied ARCTIC MX-2.,the Freezer 7 Pro Rev.2 offers performance far beyond stock coolers and achieves 130 Watts cooling capacity – becoming one of the most efficient CPU coolers for power users.
- Compatable Sockets: 939 /AM2 /AM2+ / 775 / 1155/ 1156 / 1366
- Compatible with Intel Core i7 and Core i5, as well as AMD sockets
- Excellent cooling performance - 130 Watts
- Ultra quiet 92mm PWM fan
- 6 heatpipes and 42 fins for efficient heat dissipation
- Patented vibration absorption to eliminate buzzing sounds
- Pre-applied ARCTIC MX-2
- Easy installation
Was £19.99 Inc. VAT
ORDER NOW
Zalman CNPS9900-MAX Blue LED CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/AM2/AM2+/AM3) @ £35.99 inc VAT
Optimally designed pure copper fins effectively disperse heat away from the CPU via composite heatpipes, while the high capacity 135mm fan quickly cools the heatsink for stable operation of high performance CPUs. CNPS9900 MAX utilizes Composite heatpipe which is 50% more effective in transferring heat compared to ordinary heatpipes. An ultra quiet 135mm fan is incorporated for minimized noise. The entire copper heatsink of CNPS9900 MAX is ‘Black-Pearl’ Nickel Plated for long-term corrosion resistance, while the deep ‘Black-Pearl’ tone along with the high intensity Blue / Red LEDs reinforce its powerful aesthetics.
- Dimensions: 94(L) x 131(W) x 152(H)mm
- Weight: 755g
- Materials: Pure Copper/Black-Pearl Nickel Plated
- Dissipation Area: 5.4cm
- PWM Fan Controlller
- Fan Bearing: Long life bearing
- Fan RPM: 900 - 1900
- Fan Noise: 18 - 30dBA
- 300w Cooling Performance
- Includes ZM-STG2 Thermal Grease
Was £39.98 Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
Zalman CNPS9900-MAX Red LED CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/AM2/AM2+/AM3) @ £35.99 inc VAT
- Weight: 755g
Was £39.98 Inc. VAT
ORDER NOW
Corsair Flash Survivor® 8GB USB3.0 Flash Drive (CMFSV3-8GB) @ £19.19 inc VAT
Your files are important — that's why you're taking them with you. Flash Survivor USB 3.0 helps keep them safe. The anodized, aircraft-grade aluminum housing is waterproof to 200 meters, vibration-resistant, and shock-resistant.
- Capacity: 8GB
- Read: 80MB/s
- Write: 40MB/s
- Interface: USB3.0
- Warranty: 5 Years
Was £21.95 Inc. VAT
Only £19.19 inc VAT.
ORDER NOW
Corsair Flash Survivor® 16GB USB3.0 Flash Drive (CMFSV3-16GB) @ £23.99 inc VAT
- Capacity: 16GB
- Read: 80MB/s
- Write: 40MB/s
- Interface: USB3.0
- Warranty: 5 Years
Was £27.95 Inc. VAT
Only £23.99 inc VAT.
ORDER NOW
Corsair Flash Survivor® 32GB USB3.0 Flash Drive (CMFSV3-32GB) @ £35.99 inc VAT
- Capacity: 32GB
- Read: 80MB/s
- Write: 40MB/s
- Interface: USB3.0
- Warranty: 5 Years
Was £37.99 Inc. VAT
ORDER NOW
Corsair Flash Voyager 16GB USB3.0 Flash Drive (CMFVY3S-16GB) @ £17.99 inc VAT
"Get faster read speeds and rugged reliability with the Corsair Flash Voyager USB 3.0 flash drive. USB 3.0 read speeds let you access movies, pictures and large files up to 4x faster than traditional USB 2.0 drives and the durable rubber design is water resistant and shockproof to keep your data safe.
Fast – Access videos, pictures and large files up to 4x faster read speeds than traditional USB 2.0 drives
Durable – Corsair's proprietary all-rubber housing is extremely durable, water resistant and drop-tested for worry-free transport of your valuable data.
Shock Proof – Solid state storage makes Flash Voyager drives virtual shock proof.
Convenient – Just plug it in and go! Works with Windows, Mac OS X and even Linux without drivers.
Compatible – Designed for USB 3.0, backward compatible with USB 2.0
Backed by Corsair – A respected name with a passion for quality and customer service.
- Fast USB 3.0 connectivity;
- Durable rubber housing;
- Water resistant;
- Shock proof;
- 5 Year Manufacturer Warranty;
Was £19.99 Inc. VAT
ORDER NOW
Corsair Flash Voyager 32GB USB3.0 Flash Drive (CMFVY3S-32GB) @ £27.59 inc VAT
- Water resistant;
- Shock proof;
Was £29.99 Inc. VAT
Only £27.59 inc VAT.
ORDER NOW
Corsair Flash Voyager GT 16GB USB3.0 Flash Drive (CMFVYGT3-16GB) @ £19.19 inc VAT
Premium performance, high-capacity USB 3.0 flash drives with renowned Flash Voyager durability and high-speed file transfers even on USB 2.0 systems. The unique all-rubber housing is extremely durable, water resistant and drop-tested for worry-free transport of your valuable data.
The Flash Voyager GT USB 3.0 really takes advantage of the performance of USB 3.0, with up to 8x the speed of a typical USB 2.0 flash drive. But even when used on a USB 2.0 port it’s one of the fastest drives on the market. The unique all-rubber housing is extremely durable, water resistant and drop-tested for worry-free transport of your valuable data. Just plug it in and it works, with Windows, Mac OS X and even Linux. The Flash Voyager GT USB 3.0 is backed by Corsair, a respected name with a passion for quality and customer service.
- Unformatted Capacity: 16GB;
- Max Read (USB 3.0): 135 MB/sec;
- Max Write (USB 3.0): 41 MB/sec;
- Interface Type: USB 3.0;
- Shock: 40G;
- Warranty: 5 Years Manufacturers Warranty;
Was £21.95 Inc. VAT
ORDER NOW
Corsair Flash Voyager GT 32GB USB3.0 Flash Drive
- CMFVYGT3-32GB @ £40.79 inc VAT
- Unformatted Capacity: 32GB;
- Shock: 40G;
Was £43.99 Inc. VAT
Only £40.79 inc VAT.
ORDER NOW
Corsair Flash Voyager GT 64GB USB3.0 Flash Drive
- CMFVYGT3-64GB @ £83.99 inc VAT
- Unformatted Capacity: 64GB;
- Max Read (USB 3.0): 135 MB/s;
- Max Write (USB 3.0): 83 MB/s;
- Shock: 40G;
Was £89.99 Inc. VAT
Only £83.99 inc VAT.
ORDER NOW
These TP Link homeplugs might be getting a buy if the stories are true about terrible wireless from vm superhub when its installed sat :/
Is there really only a 3p saving on the TDK 50pack? Whilst I'm all for saving, it's not a great deal for a TWO?
I can honestly say they are. I have a superhub and the signal only just reaches the floor above. Plugged in a £25 netgear G router into it with the superhub on "modem only mode" signal reaches me three floors up.
I have it all wired now though, but the wireless signal for the superhub really is shockingly bad!
Also, just realised the 8GB single stick is under dual channel on the webby not single channel
Great price cuts as usual!
I noticed though that the OCUK HD 6850 is priced at £99.98 but the page it links to says it's at £89.99?
Trust me if your using the Superhubs wireless you will end up buying a set of TP Link homeplugs.
i lasted less than a week with the superhub's wireless signal.
never in my life have i used such a bad wireless signal,been using homeplugs now for 6 months and not one problem,solid as a rock :)
What a shame, just as I manage to scrape enough money together for a shiny new i5 2500k and Z68 motherboard the 2500k isn't on sale. It's £20 cheaper elsewhere as well.
