This weekend's Focus MK2 Alpine stereo install - random thoughts/questions
  • Thread starter Thread starter Adz
  • Start date Start date
Adz
Adz
18 Oct 2002
Berkshire
"This weekend I have mostly been..."
Upgrading my Focus MK2 stereo :). Anyone who has a MK2 Focus will know that the standard system is dire. Strained, muffled, flat with enough bass to resonate the doors without actually making anything much like music.
It seems that information on MK2 Focus speaker/headunit swaps is quite sparse on the web compared to the plethora of forum posts and guides for the MK1 so I thought I'd post this in case it's of interest. Rather than write an essay I thought a few succict bullet points would be more appropriate.
  • Standard MK2 Focus stereo is ****, flat/muffled mids/highs yet with enough bass to resonate the doors without making anything which resembles music
  • Standard MK2 stereo near impossible to remove with Halfords supplied keys. Get better keys or ask your dealer. Start a swear jar, it'll pay for Christmas.
  • Cheapo eBay fascia adapter looks totally crap but I have a cunning plan for this - if it works I'll post pics :)
  • Alpine X305 headunit (car audio direct) is bloody brilliant. It uses its own DAC rather than the iPod/iPhone's built in DAC which helps it not to sound ****. Track selection brilliant. Equaliser/bluetooth require addon modules.
  • Alpine G series 6.5" components are pretty good. Tons of bass once fitted properly. Still positioning the tweeters. I can't help feeling that spending £300 rather than £100 would have achieved better quality.
  • Focus MK2 door speakers are RIVETED in!! Had to drilll them out and use bolts/washers/nuts to fix speaker adapters. I wasn't expecting that.
  • Cheap eBay speaker adapters are cheap and flimsy
  • On the test fit, the new components rattled the doors like hell all the way through Firestarter. Ended up adding a layer of flashing tape between speaker adapter and door as a buffer. Job done.
  • Tons of flashing tape (or Dynamat if you want to pay 4x as much for the same thing) in the door cavity massively improves the sound of the system. Don't miss this out on a modern car with doors made of tin foil. Don't use so much that your electric window fouls it!
I must admit I'm quite pleased. I probably would have achieved a better result having it done professionally but I enjoyed the experience having never set up a system myself.
The question now is do I...
a) Amp the fronts or
b) Add a subwoofer or
c) Add 2 subwoofers
d) Do all 3
I might be exaggerating slightly for dramatic effect but I found the standard system to be pretty crap. The new one so good, I keep finding excuses to go back out to the car for another listen.
If you do decide to upgrade, don't ask me to help. I still haven't managed to get the door cards to sit quite as they were before :(.
[*]Tons of flashing tape (or Dynamat if you want to pay 4x as much for the same thing) in the door cavity massively improves the sound of the system. Don't miss this out on a modern car with doors made of tin foil.
Good to see someone not missing out this point! Its amazing how much difference proper sound deadening makes! :)
I'd say just go for a sub and then amp the fronts, should sort it out nicely..
I have the standard system and it is terrible.
Some accompanying pictures would have been really good.
I did think of this but sadly not until I'd finished :(.
If you do give it a shot and get stuck at any point, just ask and I might be able to give you some pointers. However, if you really care about the car I'd strongly advise getting a professional to fit it. I just fancied a project and took the risk of it all going horribly wrong ;).
When are the 'Car audio SOS' arriving :D???
