Thoughts and opinions pls
25 Oct 2014
Hi there,
Please help me out with some advice as to the below basket.
I want a good powered machine and also want it to be aesthetically pleasing;)
I can salvage 2TB HD from my old decrepit Dell machine but would like to know what is missing from the build.
TIA
YOUR BASKET
1 x Asus GeForce GTX 970 DirectCU II OC Strix 4096MB GDDR5 PCI-Express Graphics Card £299.99
1 x "Steamroller Asus X99" - Intel Core i7 Haswell-E DDR4 Configurable Bundle £230.04
- 1 x Phanteks PH-TC12DX CPU Cooler - Black £44.98
- 1 x Avexir Platinum 16GB (4x4GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit (AVD4U24001604G-4M) £194.99
- 1 x Intel 5820K 3.30GHz (Haswell-E) Socket LGA2011-V3 Processor - Retail (BX80648I75820K) £289.99
1 x SuperFlower Leadex Platinum 1200W Fully Modular "80 Plus Platinum" Power Supply - White £169.99
1 x Crucial MX100 512GB SATA 2.5” 7mm SSD + 9.5mm Adapter CT512MX100SSD1) £154.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Arctic White (CC-9011048-WW) £104.99
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £77.99
Total : £1,577.54 (includes shipping : £8.00).
Riiiiiight
You are going way over the top. Haswell-E is completely pointless for this tbh, there's looking good and there's overkill :)
An i5 will do well once overclocked in Arma 3, as it is a CPU intensive game. Something like the GTX 770, R9 280X or even the GTX 780 @ £215 will play Arma 3 well, again as it is a CPU intensive game
1200W is unnecessary, that will run on a good 550W :)
You can make the PC look great but it doesn't need to be expensive
Thoughts?
I thought it was a little bit overkill but was hoping to make it last a good few years.
Really want to keep the B&W theme going with the case, mbo and PSU.
A little? Massive mate :) This i5/i7 will last a fair few years also, probably longer for just web browsing etc
Here's a try;
YOUR BASKET
1 x Gigabyte Z97X-UD3H-BK - Devil's Canyon Core i7 4790K CPU & Motherboard Bundle **£35 Saving** £367.98
1 x Corsair Hydro H105 Extreme Performance Liquid CPU Cooler (CW-9060016-WW ) £89.99
1 x SuperFlower Leadex GOLD 850W Fully Modular "80 Plus Gold" Power Supply - Black £89.99
1 x TeamGroup Xtreem LV "Frost Edition" 8GB (2x4GB) DDR3 PC3-21300C11 2666MHz Dual Channel Kit £59.99
1 x BitFenix Alchemy Premium Modding LED Strip - Connect White 30cm £16.79
1 x Silverstone Cable Extension Value Bundle - White £10.8
1 x No Molex to SATA Adapter Required £0
1 x Silverstone 8-pin PCIe 6+2 Pin 25cm PCIe Extension - White £3.29
1 x Silverstone 6-pin 25cm PCIe extension - White £4.26
Total : £1,212.65 (includes shipping : £8.00).
What do you think?
This is a bit overkill too but it'll last :)
Free shipping - http://forums.overclockers.co.uk/showthread.php?t=18630207
Black Edition Board Deal - upgrade within 3 years for free! :) - http://forums.overclockers.co.uk/showthread.php?t=18631511
Thank you very much for the quick response and also for the little touches you have thrown in to keep the theme. You have shaved a good few quid off the build for me too.
Is there any need for me to throw 16GB ram in there or will 8 be fine?
I like the white cable bundle. I hadn't considered this. Is there any partiucular reason for it?
Overall to my untrained eye it looks really good.
16GB RAM is fairly pointless for your uses :)
The cables will just set it off, along with the LEDs. The main PSU cables go behind in the PSU compartment and the braided cables attach to the end of them, extend and you should put the white cables through the case so it looks good :)
Something like this but white cables :) - http://cdn.overclock.net/6/67/6749832d_SAM_1372_zps26ce7ec4.jpeg
Thank you both for the input. It will help me fine tune the build.
I appreciate the specs are OTT for what i need but i don't mind having that little bit extra oomph if my needs were to change down the line.
I like things to tick over and not be stretched hence the probably silly spec'd original build.
Do you ever think that the uses will ever change?
This will do pretty much everything you want it to with similar numbers, and still looks good
YOUR BASKET
1 x KFA2 GeForce GTX 780 3072MB PCI-Express Graphics Card - Retail (78XNH5DN9IST) £215.99
1 x Intel Core i5-4690K 3.50GHz (Devil's Canyon) Socket LGA1150 Processor - Retail £179.99
1 x Gigabyte Z97-HD3 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £79.99
1 x Raijintek EreBoss High Performance CPU Cooler Black £29.99
Total : £960.65 (includes shipping : £8.00).
http://www.overclockers.co.uk/showproduct.php?prodid=FS-021-OG&groupid=43&catid=2475&subcat=2485
This is highly upgradeable, (drop in an i7, new GPU, more RAM in the future should you need)
Under £900, no need to go Intel.
Can't say I agree with that, cause for £850 built I'd be looking at Intel ideally - there's no upgrade paths at all with AM3+ anymore really, and I *think* Arma 3 doesn't use all cores so I'd want those cores to be as strong as possible (intel)
YOUR BASKET
The price is going down. I likes :D Thanks for the help.
Is the 970 not a more modern GPU? I see the 780 is a bit cheaper though i don't mind spending a little more. Is there much difference between them?
http://www.anandtech.com/bench/product/1036?vs=1355
Not too much, it's up to you whether to spend the extra
I think all the bling stuff adds up the money, so without that I think the total would be less i.e. I went for that board as it's quite dark so goes with the scheme
