YOUR BASKET
1 x Gigabyte GeForce GTX 770 WindForce 3x OC 4096MB GDDR5 PCI-Express Graphics Card £299.99
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £167.99
1 x Gigabyte Z87X-SLI Intel Z87 (Socket 1150) DDR3 ATX Motherboard £98.99
1 x Corsair Carbide 300R Mid Tower Case - Black £65.99
1 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit £55.99
1 x Corsair CS650M 650W Semi-Modular 80+ GOLD Certified Power Supply £67.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £43.99
1 x OcUK 20x DVD±RW SATA ReWriter (Black) - OEM £16.99
1 x BenQ RL2455HM 24" Widescreen LED Monitor - Black/Red £169.99
Total : £987.91
I've pretty much settled on the above build, and was just looking for a bit of advice.
1. First things first, does all the above work together? This is my first build so it would obviously be a disaster if it was delivered and something wasn't compatible.
2. I've opted for the GTX 770 4GB. It was a toss up between this and the R9 280X 3GB, but I've decided to go with the GTX 770 for features like Shadowplay. It also seems that the R9 280x will perform better on one game, and then the GTX 770 on the other - so it's pretty much even performance wise.
My main worry is did I need the 4GB? For £40 cheaper, I could get the same GTX 770 but with 2GB instead. Would that be a better option? Is the 4GB going to be bottlenecked by my CPU? My thinking was that for £40, it's probably better to future proof myself a bit.
3. You'll notice that I don't have a CPU cooler. I'm not planning on overclocking anytime soon, so decided to save £20-£30.
Is that suicide, or do I really need one?
Total : £987.91
