Thoughts on a failed overclock?
18 Jan 2006
Norwich
Hiya,
Trying to get my 3700+ to 2.8ghz (What the previous owner had on stock volts). Temps have never been a problem, but I've trashed the Windows install once already. The settings that trashed the Windows install were as follows:
HT- 250
Divider- 166mhz
Mem @ 2T, 3,4,4,8 (GEIL Value)
What these gave me was a POST/ Linux boot stable overclock, but flickering on Windows boot. Dumped the power in a hurry, and it had junked the registry.
Anyone with any thoughts on where I went wrong please?- Mem was stable @ 215mhz on initial testing (15mins memtest).
Mobo is a MSI K8N SLI-Platinum.
RAM etc. were left at pretty much the default settings.
Starting to think it might want a little more voltage for the CPU? Northbridge temps are also a bit of a concern- Fan was replaced with a Zalman passive, which is hot to the touch at stock (Warm road), but I have no temp sensor for this.
I've done some simple checking, and as far as I can see the RAM should be OK & running at 200mhz?
Thoughts appreciated.
-Leezer-
Hi mate
If its the one you had off me, it was 2.75Ghz i had it at on stock volts. (250x11 )
It will need a bit more voltage for 2.8, i never tried it tho, i was happy at 2.75.
I have the same chip and 2.75 seems to be the limit at stock. I had to push the volts to max 1.55 to get 2.8 on my a8n sli premium to get it fully stable. But whats the point? I reverted back to 2.75 which actually outperforms the FX57 in Sandra on dry/whetstone, so Im happy.
Edit: you prob have the same stepping as me, so this will be your limit on air, theres another stepping(freely available on Ebay, out of America, thats a lot easier to push to 3.00) cannot remember the stepping code, do a search of the forum threads on this subject.
MeatLoaf said:
Hi mate
Yup, thats the one :) (2.8 was the figure off the top of my head lol)
2.75 was where it was when it failed, was basically going in 15mhz hops, & boot testing.
Its totally stable ATM at 2.35ghz, but don't want to start pushing it again until I've figured what the probable cause of the corruption was. (Ghosted the new install now, so trashing isn't so much of a problem)
Very much hoping its not the NB temps limiting this, especially as I have no way of monitoring them.
-Leezer-
Just so you know your ram should do better timings, at the exactley same settings (250 fsb, 166 devider) mine does 2.5,4,4,7 @ 1T
Drat. Sounding very much like the NB temps then :rolleyes:
I was going to start clocking the RAM after I'd dealt with the CPU, but still :p
Will try at 1.65ghz and report back!
-Leezer-
Hiya,
Been poking at some reviews etc. to see if I could find any mobo limits, & I think I know the main problem now :) - The HT multiplier wanted lowering to 4x!
http://www.pcstats.com/articleview.cfm?articleid=1734&page=4
This review says that they ran into problems at 221mhz HT, which is a bit above where its stable ATM, and when it junked it was well above.
Do you reckon I should try putting a few more volts through the NB as well?
Cheers
-Leezer-
try the following;
increase ldt voltage
increase cpu voltage
increase mch voltage
change dram drive strength if you have the option too.
Update- Lowered HTT multiplier to 4x & gave the NB 0.5v, and its now priming at 2.64ghz :)
Will give it an hour or so at this level & then crank it up to 2.75ghz
Current CPU-Z:
Cheers
-Leezer-
OT: Yup, got a whole collection of that sort of thing :D
Are you a train-simmer by any chance?- I can be found at any of the main train-simming sites, and I have done some route building for BVE. (Simmers will know what I'm talking about ;) )
/OT
Anyway, back on topic got prime errors at 2750, which I suspect was probably due to setting the RAM to 1T. I've backed off to 2700 & 2T and am currently priming.
Cheers
-Leezer-
Have you tried upping the cpu voltage from stock?? If you temps are fine then a slight increase might help you get more out of it. I need to put 1.55v through mine and that runs prime stable at speeds in sig.the same volts lets me boot into windows at 3gig and run super pi runs but not prime stable. Temps never went over 40'c during my 20+ hour prime run @ 2.85 and thats with it being cooled by a Gigabyte G-power Pro. Just remember if going above 250fsb then drop the htt multi down to 3x.
Well ATM I've had an hour of prime stable so far, no probs there.
Temps are currently bouncing between 47 & 48 with a Zalman 7700 on the absolute minimum, which I'm fine with (Can crank it up to about triple the speed but starts to whine a bit at the top end). If I can't get the 2.75ghz on stock volts, then 2.7 will do me fine; Very decent overclock, especially at near silent.
-Leezer-
-Leezer-
Thats what you say now, but it's hard to resist pushing it that little bit further ;)
I was happy at 2.6 for a week or so then thought sod it and started playing again. Now found that on air with the cpu fan at its lowest, 2.9 is the max I can get prime stable so knocked it back to 2.85 and I'm more than happy with that :D
Drat. Failed after 2hrs with Illegal Sumout.
Have upped the vcore to 1.425 & am priming again in the failed range (Small FTTs), & ATM appears stable.
Not going to be anything to do with me using the PC for net browsing while priming is it?
-Leezer-
Shouldn't make any difference that your browsing whilst priming. Wouldn't advise doing anything intensive but light stuff will be fine.
Have you considered placing a fan over the NB cooler? some airflow will help the temps. I had the board stable @ 312 HTT btw, just so you can rule the board out :)
mine is rock solid stable 24/7 @ 2.7ghz
245 x 11
4 x HTT
I haven't tried pusing it further as i am well happy with 2.7ghz and temps under full load of 41C!
Further update- Gave it an hour priming in the failed range & appeared stable. Have been gaming scince, and no odd appearances etc.
With regards to the NB cooling, the only thing that could possibly fit is a 40mm fan as the whole things rather jammed into a VF700. Posted on wanted looking for one a little while back, but no response, so I've given up ATM.
Still, I think its pretty stable @ 2.7ghz which will do me ATM.
Next up is an extended session of BF2 this evening, and then hopefully a replacement GFX card tomorrow (Uber clocking BFG 7600GT, stock cooling which is being replaced with the VF700)
-Leezer-
