- 30 Jul 2007
Hi
i need 2x9 10Gbe UTP connections (over 2 stacked switches) for my core - supporting backup server and all flash 4 node vsan cluster .
i cant find anything in the enterprise Cisco stable that provides a good solution for 10Gbe utp (cat 6)....i am not even sure Cisco provide an SFP module for UTP?
then i came across the SG550 range, seems perfectly good enough with UTP ports...
I dont require much functionality, no routing protocols, just static routing and access lists between a few vlans and 10GBit UTP ports for the servers with stacking and redundant power. Dont care about no IOS particularly if they do the job. The vsan PCI NVME nodes consume ~ 3Gbps peak per port, across 4 storage links and 4 data links any one time, peak. Most of time they are idling.
any thoughts on SG550 and choices for 10GB UTP. Any real reasons not to consider SG range. Cisco do their level best to hide the range.
Am considering SG range for access switches (4x48 port POE (30W)) as well.
thanks for feedback.
