Building a new computer, before I order, can a few of you give your opinions and suggestions. I have a few concerns and questions about it, but before I ask them, here is the build:
YOUR BASKET
1 x Asus GeForce GTX 560Ti DirectCU II TOP 1024MB GDDR5 PCI-Express Graphics Card **Supplied with BattleField 3 & Batman: Arkham City PC game** £194.99
1 x Radon 720a AMD Phenom II X6 1055T 2.80GHz @ 3.80GHz Overclocked Bundle £194.99
1 x Antec TruePower New Modular 550W '80 Plus Bronze' Power Supply £59.99
1 x BitFenix Merc Alpha Gaming Case - Black £32.99
1 x Sony Optiarc AD-7280S 24x DVD±RW SATA ReWriter (Black) - OEM £19.99
5 x Akasa AK-191-BL Blue Ultra Quiet 120mm Fan - 3 Pin £29.95
1 x Akasa AK-MX002 PSU and Fan Noise reduction Kit £3.98
1 x Akasa AK-TK-02 Cable Tidy Kit £2.99
Total: £791.32 (Inc. DPD Next Day Parcel Shipping of £13.75)
GFX - I'm torn between the 560 and 6870. Comparison websites show the 560 is better, and the one in my build has better specs and comes with BF3 (I want!). But the 6870 is cheaper, opinions?
CPU Cooler - The one provided in the bundle isn't that good and is loud, would it be worth investing in a better air cooler or Antec Watercooler?
PSU - Seems fine, am I right? I've always thought the quality of the PSU is what counts, but I haven't used Antec PSU's so I am blind as to how they perform.
Case - Looked at a few reviews, but would it be worth going the extra mile and buying a CM 690-II?
Noise Reduction.. - I want to try keep a quite PC, has anyone used these?
That is all, thanks for reading, any advise or suggestions are more than welcome!
YOUR BASKET
Options applied to the above product:
1 x Gigabyte 970A-UD3 AMD 970A (Socket AM3+) DDR3 Motherboard £86.99
1 x Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit £39.98
1 x Corsair A50 CPU Cooler £00.00
1 x Corsair Force Series 3 120GB SATA 6Gb/s Solid State Drive £133.99 1 x Gigabyte 970A-UD3 AMD 970A (Socket AM3+) DDR3 Motherboard £86.99
I was thinking about an i5 bundle before, but was taken by the whole 6 cores and a bout 100 quid cheaper thing. So i5 is better? I defo do want speed!
. Also get the Antec Kuhler H20 cpu cooler, rest is really up to you graphics , memory, also forget the SSD for now get yourself a decent hardrive (I know they have gone up in price but still some okay ones on OcUK's site and if you shop around). Also the money you save on the SSD stick that on the graphics card (you are then into gtx 570 type cards), you will see more benefits that way, SSDs are future upgrades really, that is if you really need it after setting the system up you may find it is more then fast enough as it is, as I have found with mine.
Do we know when they are instock? Kind of wanted to order my PC on monday..
