Im considering changing my fans. For those how dont know im currently running a ut60 420 and ut60 280 off the standard nzxt fans that come with the switch. These however are case fans and have about .80 static pressure. I believe this is whats causing my slightly higher than normal temps in my loop and id like to get that fixed.
Ive seen these
http://www.overclockers.co.uk/showproduct.php?prodid=FG-045-BX
Which going by the specs are 2.8 mmh2o and so have 3.5 times the static pressure of my current fans.
Are they any good? Will they work well?
Im currently running push / pull with 2 extra fans one on each rad which has helped a little with air pressure, would i still need to do that with these?
Thanks
Ive seen these
Thanks
