Thoughts on this rig
3 May 2007
Shopping Basket
Hiper HPU-4M580 Type R 580W ATX2.2 PSU - Black £44.99
Lian-Li PC-60 PLUS £59.99
Creative X-Fi Xtreme Gamer 7.1 Soundcard £39.99
OcUK GeForce 8800 GTS 320MB GDDR3 HDTV/Dual DVI (PCI-Express) £144.99
GeIL 2GB (2x1GB) PC6400C4 800MHz UltraLowLatency DDR2 £56.99
Gigabyte GA_965P_DS3P (Socket 775) PCI-Express DDR2 Motherboard £74.99
Western Digital Raptor 150GB WD1500ADFD 10,000RPM SATA 16MB £121.99
Pioneer DVR-212 18x18 DVD±RW Serial ATA Dual Layer ReWriter £19.99
Intel Core 2 Duo E6420 "LGA775 Conroe" 2.13GHz (1066FSB) - Retail £107.99
Thinking of buying this from overclockers, these are basically the specs i'm after, I have a 300gig HD to go with the raptor.
Not soo sure about the case and PSU, any suggestions or recommendations would be much appreciated.
Thanks
Looks good, only a few things i would change:
The PSU to the Corsair 520:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-005-CS&groupid=701&catid=123&subcat=823
The Case to this one, very similar:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-038-LL&groupid=701&catid=7&subcat=187
The memory to the Crucial 5300C3, great Ram, overclocks like the bomb:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-088-CR&groupid=701&catid=8&subcat=144
I also would recommend an After mart Cooler like this one if your overclocking:
http://www.overclockers.co.uk/showproduct.php?prodid=HS-002-NC&groupid=701&catid=57&subcat=821
Also is their really any need for the Raptor? i was just thinking if you dont get the Raptor and go for a Normal Hard Drive i.e, the Seagate 320GB:
http://www.overclockers.co.uk/showproduct.php?prodid=HD-078-SE
You would also be able to get a better soundcard:
http://www.overclockers.co.uk/showproduct.php?prodid=SC-044-CL
Wow thanks for the really quick response.
I think i'll probably take up most of your suggestions, no real need for the raptor I just like having 2 hard drives in my system and thought i'd treat myself to one of the quicker ones for my programs and OS.
Isn't the BFG 8800GTS 320Mb cheaper? I was looking at this the other day and I could swear blind it is, I'll go check.
Edit: No, I'm talking out of my arse! It's just short of £200! Ignore me
I have several components which has been mentioned so i can talk off experience.
Definitely get the Corsair HX 520W PSU
i personally own the 620W one and its amazing ;)
As for cases i would go for the Lian-Li PC-7 PLUS Aluminium Midi-Tower Case
http://www.overclockers.co.uk/showproduct.php?prodid=CA-054-LL
I again also have this case and it rocks.
As for RAM definitely get the Crucial Ballistix 2GB, the overclocking potential is amazing.
Hope this helps and enjoy your new rig :D
