Thoughts on this system
24 Mar 2004
Hey guys
Not built a system in ages and just put together some bits and pieces. It's going to be used for main office pc doing tasks and advanced photoshop tasks using a dual monitor set up.
Looking to built a top spec machine to last beyond 5 plus years.
I have a 2nd 2TB HDD here already so only needing a SSD for the system drive.
Any advice on the system along with anything you think i may have missed. thanks
Intel 4820K 3.70GHz (Ivybridge-E) Socket LGA2011 Processor - Retail (BX80633I74820K) Intel 4820K 3.70GHz (Ivybridge-E) Socket LGA2011 Processor - Retail (BX80633I74820K) £249.86
(£208.22) £249.86
(£208.22)
Crucial 32GB (4x8GB) DDR4 PC4-17000C16 2133MHz Quad Channel Kit (CT4K8G4DFD8213) Crucial 32GB (4x8GB) DDR4 PC4-17000C16 2133MHz Quad Channel Kit (CT4K8G4DFD8213) £224.99
(£187.49) £224.99
(£187.49)
Asus X99-S Intel X99 (Socket 2011) DDR4 ATX Motherboard Asus X99-S Intel X99 (Socket 2011) DDR4 ATX Motherboard £224.99
(£187.49) £224.99
(£187.49)
OcUK GeForce GTX 770 "NVIDIA Reference" 4096MB GDDR5 PCI-Express Graphics Card OcUK GeForce GTX 770 "NVIDIA Reference" 4096MB GDDR5 PCI-Express Graphics Card £199.99
(£166.66) £199.99
(£166.66)
Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E500B/EU) Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E500B/EU) £155.99
(£129.99) £155.99
(£129.99)
Antec High Current Gamer M 750W "80+ Bronze" Modular Power Supply Antec High Current Gamer M 750W "80+ Bronze" Modular Power Supply £89.99
(£74.99) £89.99
(£74.99)
OcUK 24x DVD±RW SATA ReWriter (Black) - OEM OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £19.99
(£16.66) £19.99
(£16.66)
Zalman T1 Plus Mini-Tower USB 3.0 - Black Zalman T1 Plus Mini-Tower USB 3.0 - Black £19.99
(£16.66) £19.99
(£16.66)
Hi.
The CPU+board are incompatible.
The 4820K uses the older 2011 socket and the X79 chipset with DDR3.
You want a 5829K or better which is using the 2011-3 socket (that X99 board and DDR4).
You can get these as bundles,
https://www.overclockers.co.uk/productlist.php?groupid=701&catid=6&subid=2858
And claim cashback - https://toptechcashback.com/uk/en/pages/cpumb/qualifying
You need a heatsink for all theses CPUs they do not come with one, not even the retail ones do.
The case is totally unsuited as its mATX support only (unless you want the gigbayte mATX X99 bundle).
Instead here are some alternatives,
YOUR BASKET
1 x Antec P100 Mid Tower Case & HCG-620M 620W 80+ Bronze Modular PSU Bundle £120.91
1 x Antec VSP5000 Silenced Tower Case - Black £39.95
Total : £175.86 (includes shipping : £12.50 Ex.VAT).
Both have more fans than the Zalman and are noise dampened.
Your choice of PSU is strange unless you plan on going SLI, but even then I would look at a higher rated unit as X99 uses more power than average or you can get away with a slightly lower powered PSU for a single GFX card.
A GTX960 is cheaper and models such as the ASUS Strix or MSI gaming run passive at low load.
Lastly that DVD is a bit expensive, there is a LG model instock at £13.
A budget might help, maybe I can do you a nice epic spec.
hey stulid
really appreciate the response and it was exactly the type of reply i was looking for to weed out any obvious incompatibilities.
This the updated basket i have went with using your recommendations. I do however need some help in picking a graphics card and a heatsink/fan.
This machine will not be used for overclocking or gaming in anyway, having dual monitor set up is the key feature needed.
It would need to have x2 DVI and if possible x2 HDMI outputs for when the monitors are upgraded to HDMI. I'm not precious for either Nvidia or AMD.
It's seems a pain that even the retails cpus don't ship with heatsinks, i just need something basic that gets the job done as no overclocking will be done.
Cheers
Asus X99-S - Intel Core i7 5820K Six Core CPU & Motherboard Bundle ***£30 Saving*** Asus X99-S - Intel Core i7 5820K Six Core CPU & Motherboard Bundle ***£30 Saving*** £514.98
(£429.15) £514.98
(£429.15)
Crucial 32GB (4x8GB) DDR4 PC4-17000C16 2133MHz Quad Channel Kit (CT4K8G4DFD8213) Crucial 32GB (4x8GB) DDR4 PC4-17000C16 2133MHz Quad Channel Kit (CT4K8G4DFD8213) £229.99
(£191.66) £229.99
(£191.66)
(£129.99) £155.99
(£129.99)
Antec P100 Mid Tower Case & HCG-620M 620W 80+ Bronze Modular PSU Bundle Antec P100 Mid Tower Case & HCG-620M 620W 80+ Bronze Modular PSU Bundle £113.87
(£94.89) £113.87
(£94.89)
LG 24x DVD±RW SATA ReWriter (Black) - OEM GH24NSC0.AUAA15B LG 24x DVD±RW SATA ReWriter (Black) - OEM GH24NSC0.AUAA15B £13.99
(£11.66) £13.99
(£11.66)
Heres two coolers,
YOUR BASKET
1 x Alpenföhn Brocken ECO CPU Cooler - 120 mm £24.95
1 x Raijintek Themis Black Heatpipe CPU Cooler PWM - 120mm £19.99
Total : £54.54 (includes shipping : £8.00 Ex.VAT).
GFX cards,
YOUR BASKET
1 x KFA2 GeForce GTX 960 EX OC "Black Edition" 2048MB GDDR5 PCI-Express Graphics Card - Retail (96NPH8DVD9XX) £164.99
1 x OcUK GeForce GTX 770 "NVIDIA Reference" 2048MB GDDR5 PCI-Express Graphics Card £149.99
1 x Palit GeForce GTX 750 KalmX SILENT 2048MB GDDR5 PCI-Express Graphics Card £99.95
Total : £424.52 (includes shipping : £8.00 Ex.VAT).
They all have two DVI and one HDMI, you would need a DVI - HDMI converter/cable to get a 2nd HDMI.
Thanks stulid, i'm going to get this ordered shortly
Heres two coolers,
YOUR BASKET
GFX cards,
YOUR BASKET
