- 29 May 2020
Hi, I finally decided to mod my Lian Li O11DXL with a front intake (see my other post). That makes me have (all fans are bequiet! silentwings 3 120mm pwm) 3 of them for intake and one of them for exhaust (2 will replace the 140mm Zalman CPU cooler).
Now I kinda gave up the idea of a vertical GPU mount. Basically, contrary to my initial thoughts (and the rationale of buying the Lian Li raiser kit), most tests I've seen conclude there's almost no difference in temps and that it's basically an esthetic issue, to "show off your graphics card"...
. I couldn't care less.
Now, i do intend to replace the stock heatsink with a morpheus II core one (that will drop the temps !), but would like to be able to have access to the remaining PCIe slots on the mobo (which I shan't have if I do a regular GPU installation in the 16x PCIe slot under the CPU heatsink).
So... i was wondering : why not simply clip the GPU (radeon VII) +morpheus on 2 or 3 120mm fans that I pin directly to the bottom (which is perforated anyway and has dust filters I could simply take out to improve the airflow) and use that as a direct exhaust ?
I'm aware that most people would use these fans for intake, in order to have the air getting directly to the pcb, but that would have the hot GPU air whirl up and get to the CPU before getting to the back exhaust...
Anyway, in my proposed configuration, the GPU would still get (some) fresh air from the 3 front fans anyway and as all hot air will be pulled down directly (I thought of 3 fans instead of 2 just so that the exhausted hot air can't get back in through the 'hole' that'd be left in the bottom) and can't get in the case nor the CPU in any way...
This would have course imply I need to buy a long enough PCIE4 raiser cable (if anyone knows of a good one, feel free to let me know), so it could still get over the other PCIe cards I would like to install...
The only drawback I see, is that the GPU isn't very much solidly attached to any frame that keeps it in place (just the two clips of the fans). So, maybe some sort of mounting rail or frame that'd allow for such a horizontal mount that I could fix to the bottom plate might be a good idea ? I simply don't know of any such beast on the market, so here again, if anyone knows of such a solution, please feel free to share it !
Personally I've only found these ones :
https://www.amazon.com/dp/B07Y43C9XD
https://www.amazon.com/dp/B07Y449XHG
Thanks for any feedback on all of this...
Here's a pick to make sense of it all :
https://imgshare.io/image/N5Yery
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
