Thoughts on XSPC EX360 Crossflow
  • Thread starter Thread starter LiE
  • Start date Start date
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
Their good radiators and are copper and brass core same as the EK, although not sure what aluminum housing means in the EK description.
EK radiators have a shell on the outside (like most brands). It's just that they're removable for cleaning, painting etc. So maybe that's why EK have chosen to specify. I think the shell is usually steel or aluminium.
Had one on my previous build. Worked perfectly fine. They're quite long though, so take into account their a bit longer than a standard 360mm rad.
I've used the 280mm version of the XSPC X-Flow rad, all worked well enough and exactly as in the OP's use case, this really helped cut down on tubing runs and neatened things up.
