thoughts please?
21 Jan 2012
Hereford, UK
Hi guys in process of watercooling but need advice please
1.can I mount rad in bottom of case and have fans sucking In? I have bitfenix colossus with good air flow or will having rad lower than pump res be a issue
2. I am also cooling mobo and have 120mm rad which was gonna put on rear exhaust recommended or not?
To recap worried pump wont cope having to pump up from bottom of case but I have more room in bottom also its a D5 pump which im sure will cope but just checking water cooling noob so wanna double check
Loop order pump/res - bottom rad - cpu - 120mm rad - mobo - pump/res? ?
