Thread stuck in device driver
19 Feb 2004
Stoke-on-Trent
Hi all I was wondering if you could help. I am receiving the following blue screen error when playing games after a period of time "Thread stuck in device driver"
Anyone have any ideas what could be causing this?
Hello,
When did the issue start? was it after upgrading the gpu drivers or putting in a new gpu?
i take it your on windows 10?
First thing i would try is to make sure your bios is up to date and use DDU to do a clean install of the gpu drivers and then re install the latest drivers from AMD\Nvidia.
see if the issue still occurs
If it does list the PC specs etc and can go from there
Sorry for the late reply.
Thanks for the advice. I've updated my bios and run DDU and updated the drivers and it looks like its worked :)
Thanks ED209
